Leak?
Re: Leak?
Looks like your axle seal is on it's way out... orrr your diff fluid is so diluted with water it's leaking past the seal lol. Not sure if you drive through deep water or not. I'm leaning more towards axle seal.
Re: Leak?
From the pic I'd have to say axle seal as well, does it smell like gear oil and feel viscous? Seems odd having a seal failure on a relatively low mileage newer truck. Need more info
Re: Leak?
Axle seal. Keep an eye on your lube level. Mine used to do that, then it quite. Don't know why.
Re: Leak?
It did smell like gear oil. I made sure because it rained last night. Driver side is dryColibri wrote:From the pic I'd have to say axle seal as well, does it smell like gear oil and feel viscous? Seems odd having a seal failure on a relatively low mileage newer truck. Need more info
Re: Leak?
Unfortunately you have to pull the carrier to replace the inner seal. Not that hard but if you're not mechanically inclined mAy want to pay to have it done. Maybe yours will heal itself like RustyPW's, like the man said, keep an eye on the level
Re: Leak?
RustyPW wrote:Axle seal. Keep an eye on your lube level. Mine used to do that, then it quite. Don't know why.
Its because the fluid is now low from leaking
Re: Leak?
Yea, it's full of water now from Rausch Creek.olyelr wrote:RustyPW wrote:Axle seal. Keep an eye on your lube level. Mine used to do that, then it quite. Don't know why.
Re: Leak?
Both my front and rear pinion seals with leak from time to time, just enough to wet the housing. Then it might not do it again for months. Fluid level is fine, just seeping every now and then. I'd make sure the level was good and no water and just keep an eye on it. Mine began this when I changed the factory gear oil to Amsoil Heavy Duty Synthetic. I've "heard" the synthetic oil molecules are uniform and smaller and will get past seals more easily.
Re: Leak?
I've read the same thing too, about some synthetic lubes.Will wrote:Both my front and rear pinion seals with leak from time to time, just enough to wet the housing. Then it might not do it again for months. Fluid level is fine, just seeping every now and then. I'd make sure the level was good and no water and just keep an eye on it. Mine began this when I changed the factory gear oil to Amsoil Heavy Duty Synthetic. I've "heard" the synthetic oil molecules are uniform and smaller and will get past seals more easily.
Re: Leak?
Same here. Since the switch to Amsoil, my pinions weep from time to time. Plus, I over fill them too, so that's another cause, I'm sure.Will wrote:Both my front and rear pinion seals with leak from time to time, just enough to wet the housing. Then it might not do it again for months. Fluid level is fine, just seeping every now and then. I'd make sure the level was good and no water and just keep an eye on it. Mine began this when I changed the factory gear oil to Amsoil Heavy Duty Synthetic. I've "heard" the synthetic oil molecules are uniform and smaller and will get past seals more easily.
2011
