4wd LO acting funky
Posted: Fri Oct 30, 2015 10:58 am
by lastmanalliance
So when I try to shift into 4 LO it sounds like when you shift without pushing the clutch. It will still engage and it only sounds like that every once in a while. But I'm kinda worried. Has this happened to anyone? Oh and sometimes when 4LO is engaged sometimes the 4WD light on the dash doesn't come on.
Sent from my HTC6525LVW using Tapatalk
Re: 4wd LO acting funky
Posted: Fri Oct 30, 2015 11:39 am
by dodgeman324
To me it sounds like your linkage may have started slipping a little bit to get it "out of alignment". Basically, it seems like perhaps when it is sitting in 4Hi for example, it is barely at the point to go to neutral or 2HI, so when shifting to 4LO, it either isn't accurately pushing into, or going too far. Hard to explain, but that's my thought. I remember a post a couple months back about someones transfer case popping out of 2HI or 4HI over bumps, and they just needed to adjust the nut on the linkage to get it fixed.
Posted: Fri Oct 30, 2015 11:51 am
by lastmanalliance
Okay that makes sense. We use the same linkage set up on the robots I work on. I should be able to look at it and tell if it is wonky or not
Posted: Fri Oct 30, 2015 1:01 pm
by bstefanic
Stupid question....but you have it in neutral when shifting into 4lo, right?
Posted: Fri Oct 30, 2015 1:15 pm
by loveracing1988
bstefanic wrote:Stupid question....but you have it in neutral when shifting into 4lo, right?
You do. I found it is best if you are just barely rolling and go straight from 2hi to 4 low without pausing, just keep pushing until you hear it clunk. If you pause in neutral it makes it kind of a pain to get into 4 low but that might just be me.
Posted: Fri Oct 30, 2015 2:02 pm
by yooper68
on my 2004 (not PW) 2500, I have found that transmission must be in neutral to shift into 4-low. I usually come to a complete stop - it has been working well; haven't tried the barely rolling trick. I do have the lever on floor for 4LO, N, 2HI, 4HI. I have been using 4LO almost all the time I go in the woods lately; I like the throttle response/control much better.
Posted: Fri Oct 30, 2015 2:09 pm
by Will
Same here, it will go in 4lo in drive but it likes it much better with the tranny in neutral, I use a single swift motion like I'm sneaking up on it and then attack it. If you monkey around with it, it will act stupid.
Posted: Fri Oct 30, 2015 2:58 pm
by bstefanic
loveracing1988 wrote:bstefanic wrote:Stupid question....but you have it in neutral when shifting into 4lo, right?
Sorry, I wrote that a little stupid. Was trying to imply that if not putting it in neutral first that could definitely be a reason for the noise
Posted: Sat Oct 31, 2015 9:51 am
by Iamahemi
From the manualShifting Procedure – Manually Shifted Transfer Case
2H ⇔ 4H
Shifting between 2H and 4H can be made with the vehicle stopped or in motion. If the vehicle is in motion, shifts can be made up to 55 mph (88 km/h). With the vehicle in motion, the transfer case will engage/ disengage faster if you momentarily release the accelera- tor pedal after completing the shift. Apply a constant force when shifting the transfer case lever.
2HOr4H⇔4L
With the vehicle rolling at 2 to 3 mph (3 to 5 km/h), shift the transmission into NEUTRAL. While the vehicle is coasting at 2 to 3 mph (3 to 5 km/h), shift the transfer case lever firmly to the desired position. Do not pause in transfer case NEUTRAL.
NOTE:
• Pausing in transfer case NEUTRAL in vehicles equipped with an automatic transmission may require shutting the engine OFF to avoid gear clash while completing the shift. If difficulty occurs, shift the transmission into NEUTRAL, hold foot on brake, and turn the engine OFF. Make shift to the desired mode.
• Shifting into or out of 4L is possible with the vehicle completely stopped, however difficulty may occur due to the mating clutch teeth not being properly aligned. Several attempts may be required for clutch teeth alignment and shift completion to occur. The preferred method is with the vehicle rolling 2 to 3 mph (3 to 5 km/h). Avoid attempting to engage or disengage 4L with the vehicle moving faster than 2 to 3 mph (3 to 5 km/h).
• Do not attempt to shift into or from 4L while the transmission is in gear.
Posted: Sat Oct 31, 2015 8:18 pm
by lastmanalliance
Maybe I am not doing it right. I completely stop the truck and put it in neutral. Then shift it into 4LO. I do kinda pause in the nuetral position on the 4WD. Maybe I just need to slam it in
Posted: Sat Oct 31, 2015 8:35 pm
With mine. I found out if I'm moving about 1 mph. Put the tranny in neutral, the transfer case will pop into low most of the time.
Posted: Sun Nov 01, 2015 1:09 pm
by whitey
I do pretty much the same thing as rusty. I could be wrong but doesn't our drivers manual say we should drift, tranny in neutral then go from 2H to 4LO?
Posted: Sun Nov 01, 2015 3:53 pm
by FirerescuePW
Yep. Goes in smoothly this way. You will get gear clash if you are stopped, not in neutral, or most other methods.
