Thuren front coils
Posted: Tue Oct 27, 2015 5:32 pm
by stubiePW
I've been reading and do not want to beat a dead horse, but I want to bring up the front end a bit (no spacers). I don't have the $$ for shocks just yet. I was thinking 3" coils from Thuren. Or should I just go with the 2"?
Like I said, I know it's been covered. I have a 2012 stock minus the thuren control arms. I am hoping to keep the rub on the sway bar down a bit more.
Thanks guys
Thuren front coils
Posted: Wed Oct 28, 2015 12:07 am
by 2011RPW
2" coils will should level you out (I'm not 100% on this, I've never seen a Hemi/PW with the 2" coils), 3" will require shackles in the back.
I put 3" coils on mine, and I've got the shackles out back, as well, on highest setting. Well worth the money!
Keep in mind, an adjustable track bar is also a must-do, as well.
Re: Thuren front coils
Posted: Wed Oct 28, 2015 7:48 am
by stubiePW
Did you replace the shocks? Just curious. I guess I need to save up some money and make that happen!
Posted: Wed Oct 28, 2015 10:08 am
by leo72987
First things first 2011RPW sexy truck!! As to the 2 inch Thuren coils see below with the estimated lift heights I got these numbers from Don and cjc offroad.
-2.5" of lift on 3rd gen Hemis
-2.5" of lift on 2nd gen diesels
-3" lift on 2nd gen gas
-2" of lift on 3rd gen diesels
http://www.cjcoffroad.com/Thuren-2-Soft ... p/tf2c.htm
With that being said I have no info on 4th gen's just that they are heavier... Carli 3 inch and thuren 2 inch coils apparently give power wagons about an inch lift over stock on average as the argument has been that Wagons come with roughly a 2inch lift from Factory with a 1/2 lift from bigger 33 inch tires.. At least this was the rule of thumb with us 3rd gen guys... The Thuren 3 inch coils would give you about 4 inches of lift making a new track bar mandatory. You could probably stick with stock shocks if you used the 2 inch coils. Anything bigger and your shocks will act like limiting straps LOL.
Posted: Wed Oct 28, 2015 11:22 am
by 2wagons1driveway
Agreed 3" Thuren coils and you should run a new track bar. 3.5-3.75" of lift on a fourth gen truck depending on bumper weight.
Sent from Canada
Posted: Fri Oct 30, 2015 6:54 pm
by Kenadian
I'm running the Thuren 3" coils adjustable track bar rear shackles boogie bumps and overland shocks annnnd the high clearance control arms. Fit 37" tires with ease. And a heavy ass bumper. Sits pretty good I am on mid height on my shackles
I like to break things !!!
Posted: Sun Nov 01, 2015 12:55 pm
by 2011TXPowerWagon
Kenadian wrote:I'm running the Thuren 3" coils adjustable track bar rear shackles boogie bumps and overland shocks annnnd the high clearance control arms.
That is the exact setup I am planning, well minus the boogies. If buying in stages would you recommend the arms first?
Posted: Sun Nov 01, 2015 1:55 pm
by AllanDickerson
I know this is a 4th gen thread but I just put 3 inch coils and track bar on my 05 and I'm sitting about a 3/8 above level.
Posted: Tue Nov 10, 2015 8:56 pm
by Kenadian
2011TXPowerWagon wrote:Kenadian wrote:I'm running the Thuren 3" coils adjustable track bar rear shackles boogie bumps and overland shocks annnnd the high clearance control arms.
Yes arms first. Then you can run the 37" at stock height then add as you go. To get more clearance and better ride.
Posted: Tue Nov 10, 2015 8:57 pm
by Kenadian
That's what I did with mine
Posted: Tue Nov 10, 2015 10:12 pm
by 2011RPW
AllanDickerson wrote:I know this is a 4th gen thread but I just put 3 inch coils and track bar on my 05 and I'm sitting about a 3/8 above level.
Measuring from Bumpstops? Or fenders? Fender measurements aren't accurate, or so I've been told.
Posted: Tue Nov 10, 2015 10:21 pm
by AllanDickerson
From the fenders. That's where I see the difference so I measured there
Posted: Tue Nov 10, 2015 10:42 pm
by olyelr
Yeah fender measurements are not always the best place to measure from, but they are a good start.
I have always figured a truck looks "level" if the lower portion of the body between the front and rear tires is at a level plane, or just a touch lower in the front. My jeep is setup this way and the front fenders are an inch higher than the backs. But it looks level.
Posted: Wed Nov 11, 2015 4:31 pm
by AllanDickerson
I'll have to try that and see where I'm at.
Posted: Fri Nov 20, 2015 5:40 pm
by AllanDickerson
I measured the lower portion of the body. I'm about 3/8 high in the front with thuren 3 inch coils on my 3rd gen with a stock bumper. It still tows great, I towed a boat yesterday on a double axle trailer weighing about 7000 pounds.
