The transfer case dash indicator light pretty much tells me what it wants to whenever it wants, and up until this week it wasn't much more than a distraction.
Right now, however, I am helping a buddy move off very remote property with a 4WD trail for access, and I have discovered that since the t-case switch doesn't work, neither do the lockers & the bar, which I have REALLY needed (Towing an M715 up a steep, loose road was needlessly stupid because these things didn't work).
Any ideas for changing that switch? It looks like I'll need a huge crow's foot to do it.
And where do get one? Neither Rock Auto or Auto Parts Warehouse has it listed.
Thanks.
Transfer Case Indicator Switch Problems
'08 Flame Red Quadcab with Spyntec & Teraflex hubs, Mag Hytec pan & covers, Carr rock rail steps, Warn wireless winch controller, Hawk Performance brake pads, Ranch Hand crossover box, and Turbolined bed.
Re: Transfer Case Indicator Switch Problems
If you do a locker bypass you tell the transfer case what you want it to know. It eliminates the sensor. At least the one I made for my truck did
This has been tossed around quite a bit on here check out this thread literally should answer everything question you have and it has pictures lol. You may have to double check part#
http://forum.powerwagonregistry.org/vie ... tch#p10790
I had the same problem on my 07 here's my thread with all the gory details the PN should be the same as your 08.
http://forum.powerwagonregistry.org/vie ... 947#p41845
Transfer Case Position Switch:
Mopar PN: 05083138AA
Thanks guys!
The hard work is done at this point.
I'd share some pix, but apparently PWR & Tapatalk don't play nice in that area.
When mine failed, it failed open. Light on the dash just stayed on.
My mechanic had to get it from the dealer.
Big-ass wrench (1.5" iirc?) but it's a fairly simple fix with moderately easy access...
