DT Profab Steering Brace Question
Just got one of these the other day, along with some Kore bump stops. Before I start taking things apart under there, I am wondering if I need additional parts to do the install. I have the Readylift 2" leveling kit on mine. In the DT instructions, it states that if the vehicle is lifted, "special additional parts" are needed to install the brace. Now I'm concerned if I will be able to get it on there with the kit that came, or if I have to order even more parts? Does the 2" leveling coil spacer fall under that category? I looked on DT Profab's site and did not see any "special part" for installing the brace on lifted trucks. Any insight from you guys out there with this brace on your PW? Appreciate any help.
- GunniPWguy
Re: DT Profab Steering Brace Question
Unless I am missing something,the brace attaches to the frame at two points where the swaybar does and then to the steering gear box sector shaft extension nut. None of which change their position whether the truck is lifted or not. Suspension increases or decreases in height should not affect the installation as long as the steering box and the frame mount points stay the same. It could be a situation where the swaybar hits if it is too maxed out in a downward position? Maybe someone else who knows more will chime in.
That's good SA....thanks. I hope you're right, and what you've written makes sense. I just saw that stuff written in the instructions and got a wee bit "skeered"....don't want to screw up my rig by trying to fix it so good that I break it. Hope some otherGunniPWguy wrote:Unless I am missing something,the brace attaches to the frame at two points where the swaybar does and then to the steering gear box sector shaft extension nut. None of which change their position whether the truck is lifted or not. Suspension increases or decreases in height should not affect the installation as long as the steering box and the frame mount points stay the same. It could be a situation where the swaybar hits if it is too maxed out in a downward position? Maybe someone else who knows more will chime in.
Question from a nube- what is the DT Profab Steering Brace for?
Yeah, I saw that in their instructions when I got mine too. Worried me at first because I didn't install with any additional spacers, etc. But, after mine was all done it pretty much just maintained stock PW height even with all the additional weight on the front end so I quit worrying about it.
What others have said here makes sense, but maybe still worth a call to DT to ask them about the additional hardware.
2012 Power Wagon ST
"Born at the junction of form & function"
Carli suspension/steering/Bilstein 5100s|Ranch Hand bumpers/headache rack/rails|Factory spray in bedliner|35/12.5/17 BFG KM2s on factory alloys|Lightforce 240 Blitz HIDs|"chassis cab auxiliary switch bank mod"|Highway Products toolbox|Cobra 75 CB|PROUD AMERICAN FLAG
I think they mean that the spacers are required when you have a drop pitman arm. The brace would interfere if you did.
It reinforces and strengthens the point at which the sector shaft coming out of the steering box connects to the pitman arm. Reduces flex, tightens up the steering feel a little and prolongs the life of the notoriously weak steering box, especially on the earlier 3G PWs. Basically, it reduces the leverage effect on the sector shaft by shortening the effective length of the shaft, and it gives you another grease point.Question from a nube- what is the DT Profab Steering Brace for?
Thanks, Gents.....yeah, I've got a note out to the company asking for clarification.
Ken what are you doing reading the instructions??? You want the
to revoke your "man card" or what?
Rausch Creek Spring '12
06powerwagon06 wrote:Ken what are you doing reading the instructions??? You want theto revoke your "man card" or what?
- Throttle 8
Two words: DUCT TAPE!!!!
"Spare the duct tape---spoil the job!" Red Green
- AceMan
- Site Admin
RTFM is widely used, especially in the IT field. That along with ID10T errors due to neglecting an RFTM.Ken G. wrote:06powerwagon06 wrote:Ken what are you doing reading the instructions??? You want theto revoke your "man card" or what?
I know....mea culpa
.....but not reading them has bit me in the butt more than a few times in the past. I chock it up to my military past.....any time you didn't know something about a piece of equipment, you were always told: "RTFM" (Read The F'n Manual). It kinda stuck with me.
Power Wagon Owner's Club #110
Black '06 PW QC
Black '06 PW QC
I use RTFM all the time. Can't say it if you don't do itKen G. wrote:06powerwagon06 wrote:Ken what are you doing reading the instructions??? You want theto revoke your "man card" or what?
I know....mea culpa
Performance Mods:
Performance Mods:
- AceMan
- Site Admin
I'll use that term, among others, only amongst colleagues but not customers, even though it applies 80% of the time.
Black '06 PW QC
Black '06 PW QC
