Differential lock and sway bar
2007 the switch on the dash is flashing yellow axles will not lock. The 2 options for the sway bar adjustment do not work either. Any ideas To correct/repair/fix would be greatly appreciated.
- bigblackdodge
- Model Year: 2010
Re: Differential lock and sway bar
Use the search tool and find literally hundreds of posts on this.
I would start by checking the smart bar connector and both locker connectors. Check the faq page for more in depth discussion. Is the serv4wd light on the dash.
yes the 4wd light is on in goes off when using the 4wd
I'm going to say it's the transfer case position sensor. We had a few members, including on Leif's PW, that had that start to go out and give a wrong reading causing issues like this.
