Page 1 of 2
Aftermarket wheels for 2014+PW
Posted: Thu Dec 11, 2014 11:43 pm
by Kbhowe1
Hi all, new here but have owned my 2014 PW for about 4 months now and have around 12k miles on the truck. I have had quite a bit of problems with the duratrac tires that come stock and I am thinking of getting either toyo mt or nitto trail grapplers in 10ply. I am hoping to go a little bigger and would like to get aftermarket wheels. Thinking of 295/70/r17 or 285/75/r17. So my question is what kind of offset and backspacing for an aftermarket wheel should I be looking at? And will I still be able to disconnect the sway bar and articulate the truck without damaging anything?
BTW love the truck, it's like driving a big 4 wheeler and just won't get stuck!!!
Re: Aftermarket wheels for 2014+PW
Posted: Fri Dec 12, 2014 10:49 am
by 04Ram2500Hemi
Welcome to the PWR. The only wheel that I'm considering right now is one of the AEV Wheels that should be released early 2015. The AEV Rim is a 17x8.5 with a +27mm offset while the Power Wagon Rim is a 17x8 with a +38mm offset.
I made a thread about the Power Wagon Rim Offset a while back, here's a link to it. This actually really helped me, and I'm really "Offset Challenged."
http://forum.powerwagonregistry.org/vie ... 817#p38817
Posted: Fri Dec 12, 2014 11:30 am
by Kbhowe1
Thanks for the reply I will take a look.
Posted: Fri Dec 12, 2014 11:54 am
Are you wanting aftermarket wheels mainly for looks? Cause those size tires will fit perfectly on the stockers.
Also, what issues are you having with the duratracs?
Posted: Sat Dec 13, 2014 12:39 am
by Kbhowe1
Yeah wheels just for looks, but would like a little more ground clearance. I have had 3 flats now within 2 weeks. 1 tire was torn and had to be replaced (under warranty). 2 tires for sure we're punctured by rocks and 1 was maybe a metal culvert (but likely a rock), and all 3 tires were torn between tread. So I just think these tires are weak for a heavy truck and I want to get 10 plys, also very hard to keep balanced. Even more so than the toyo Mt's and cooper sst's I have had on other trucks.
Posted: Sat Dec 13, 2014 10:46 am
by Mpersicke87
You really can't beat the stockers....
Posted: Wed Dec 17, 2014 8:58 pm
by MTpwrwgn
I put 35x12.5x17 Toyo RT on stockers and its great. No rubbing no probs at all. Didn't bother the 6.4 at all power wise. I like the tire its quiet and looks tough. Mine is currently in getting a new PCM. Several of the folks at dealership have commented to the effect that Power Wagons should come w/ 35's...
Posted: Wed Dec 17, 2014 10:14 pm
MTpwrwgn wrote:I put 35x12.5x17 Toyo RT on stockers and its great. No rubbing no probs at all. Didn't bother the 6.4 at all power wise. I like the tire its quiet and looks tough. Mine is currently in getting a new PCM. Several of the folks at dealership have commented to the effect that Power Wagons should come w/ 35's...
Where's the pics!?
Posted: Wed Dec 17, 2014 10:43 pm
by Ducky's Dad
If you must have another set of wheels, consider the Hummer H2s. You'll need to have the hub hole bored to fit the PW hubs, but they are 17x8.5 with an internal bead lock similar to the factory PW wheels. Don't remember the offset, but they work fine on 3Gs, including mine with 35" Toyo AT-IIs. My factory wheels have a set of 35" Toyo MTs that I ran for about 35,000 miles with zero issues. I think I actually prefer the MTs to the ATs, but Toyo has a new tire out that splits the difference in tread patterns. Whatever you get, make sure it's Load Range E.
Posted: Thu Dec 18, 2014 12:04 am
by Skyd Ram
04Ram2500Hemi wrote:Welcome to the PWR. The only wheel that I'm considering right now is one of the AEV Wheels that should be released early 2015. The AEV Rim is a 17x8.5 with a +27mm offset while the Power Wagon Rim is a 17x8 with a +38mm offset.
The +38mm offset is for the 03-13 trucks. It looks like the offset on the new 14's is even greater. I measured the backspace on my '14 2500 wheels and it was around 7" as opposed to the 6.25" backspace that Ram has used on the previous generation trucks. I haven't checked and actual '14 PW wheel but I suspect that it will be the same offset as the standard 2500's.
Posted: Thu Dec 18, 2014 5:59 am
by Will
Let me know if you get new wheels and want to part with your stock ones!
Posted: Thu Dec 18, 2014 8:50 am
by 04Ram2500Hemi
Skyd Ram wrote:04Ram2500Hemi wrote:Welcome to the PWR. The only wheel that I'm considering right now is one of the AEV Wheels that should be released early 2015. The AEV Rim is a 17x8.5 with a +27mm offset while the Power Wagon Rim is a 17x8 with a +38mm offset.
I thought all Power Wagon's ran the same wheel. I know some of the new 2014's have 18" rims and some different options, but I thought all the Power Wagon's were the same.
Posted: Thu Dec 18, 2014 11:14 am
by Timgco
04Ram2500Hemi wrote:Skyd Ram wrote:04Ram2500Hemi wrote:Welcome to the PWR. The only wheel that I'm considering right now is one of the AEV Wheels that should be released early 2015. The AEV Rim is a 17x8.5 with a +27mm offset while the Power Wagon Rim is a 17x8 with a +38mm offset.
I have not seen a Power Wagon with an 18" wheel yet. I was under the impression that all PW wheels were the same 17" for 2014.
Posted: Thu Dec 18, 2014 11:49 am
by 04Ram2500Hemi
My response may have been marginal. What I was saying is I have seen some of the new HD's with 18" wheels, but I've only seen the new Power Wagon's with the 17" rim, which I thought has been the same for all 4th Gen Ram Power Wagon's (I don't know much about the 3rd Gen Wheel, but I think they are pretty much the same).
Posted: Thu Dec 18, 2014 1:25 pm
by Graveltravels
They are a different wheel from '14 up, with an integrated center, vs the plastic hub on the old ones. A little different in looks too, comparatively. I'll have to check the backspacing on these, vs the old ones. I have 315/70/17 BFG AT's on the stock wheels, as I plan to powder coat the '07 wheels and run these as my winter ones. I also have a set of H2 wheels I need to open the hub on, for my MT's for the summer. And no, no PW comes stock with 18" wheels.
Posted: Thu Dec 18, 2014 1:34 pm
by 04Ram2500Hemi
Graveltravels wrote:They are a different wheel from '14 up, with an integrated center, vs the plastic hub on the old ones. A little different in looks too, comparatively. I'll have to check the backspacing on these, vs the old ones. I have 315/70/17 BFG AT's on the stock wheels, as I plan to powder coat the '07 wheels and run these as my winter ones. I also have a set of H2 wheels I need to open the hub on, for my MT's for the summer. And no, no PW comes stock with 18" wheels.
You're right. I forgot about the new intergraded center. Good call!
Posted: Thu Dec 18, 2014 4:07 pm
by djgaston
I have a set of 20" black wheels that I took off my diesel, put Method 17" wheels on with 0mm offset/4.75" backspace. They stick out a little more than what others are running on the newer trucks but my tires don't rub the radius arms, which is just as important to me. I used a heat gun to massage the fender liner enough to clear the tires (37" toyo MTs) and trimmed a little plastic on the flares, but it clears good now. If I stayed with a 35" tire then I would definitely not have any rubbing anywhere. So one thing to keep in mind is that while the higher backspace is good for clearing the fender, you are probably going to rub the radius arms, and so far there is no option to do anything about that. Clearancing the fender is easy and free. Just my 2 cents.
Posted: Thu Dec 18, 2014 5:07 pm
by MTpwrwgn
olyelr wrote:MTpwrwgn wrote:I put 35x12.5x17 Toyo RT on stockers and its great. No rubbing no probs at all. Didn't bother the 6.4 at all power wise. I like the tire its quiet and looks tough. Mine is currently in getting a new PCM. Several of the folks at dealership have commented to the effect that Power Wagons should come w/ 35's...
Where's the pics!?
As soon as I get it back from the dealer I'll post some... Been down a week waiting on a new ECM
Posted: Fri Jul 03, 2015 6:10 pm
by Jack187
Did anyone ever pull a 2014-2015 PW wheel and measure the backspace on it?
Posted: Thu Jul 09, 2015 11:46 pm
by Skyd Ram
Posted: Wed Jul 15, 2015 8:38 pm
by SnakeEyes
I'm not understanding those heat gun pics... Haha sorry but did you just heat the inner fender liner and push the ridge in?
Posted: Wed Jul 15, 2015 9:23 pm
by Jack187
SnakeEyes wrote:I'm not understanding those heat gun pics... Haha sorry but did you just heat the inner fender liner and push the ridge in?
Pretty much. So in the picture, you will see a small channeled portion of the fender liner that runs from top to bottom, extending into the wheel well about 3/4"-1" more than the rest of the liner. It is on the outer portion of the wheel well liner. I am borrowing the heat gun pics from Skyd Ram because it makes it easy to see.
You only need to concentrate on the bottom 6-8 inches really. Once you do it, if you look at the fender from the side, you will no longer see that portion of the fender liner pushing forward towards the tire, but rather the wheel well will appear to be a smooth curve conforming to the fender flares and not protruding in on the tire. Trimming of the flare is also required, as it pushes forward at the very bottom.
You can mount a 37" inch tire without this, but it will likely hit the flare/liner when turning without this modification.
Posted: Wed Jul 15, 2015 10:18 pm
by SnakeEyes
Thanks for clearing that up! Now that I know this I am for sure gonna consider this if someone confirms stock wheels fit the same
Posted: Thu Jul 16, 2015 12:03 am
by Jack187
SnakeEyes wrote:Thanks for clearing that up! Now that I know this I am for sure gonna consider this if someone confirms stock wheels fit the same
I think you would be fine with stockers, assuming you can get the 37" tire of your choice to fit the wheel. At full lock, you are going to have the same slight rubbing issue as all the rest of us 2014+ owners with any 37" I am afraid (unless you get a lift kit that accommodates for it). If the tires I wanted would have fit on a 17x8 stocker , I would have stuck with the stock wheels.
Posted: Thu Jul 16, 2015 12:04 am
Jack187 wrote:SnakeEyes wrote:I'm not understanding those heat gun pics... Haha sorry but did you just heat the inner fender liner and push the ridge in?
How are you liking the new cooper stt pros?!!!??
