2013 Rear End
Posted: Sat Oct 25, 2014 9:34 am
by bones
Are these holes in the rear end center section supposed to have welds in them?
Re: 2013 Rear End
Posted: Sat Oct 25, 2014 10:31 am
by 06wagon
Yea. The axle tubes are pressed into the dif. And then they are plug welded.
It the right situation, you can break the welds and soin the dif up........ Don't ask me how I know that!!! Lol
Re: 2013 Rear End
Posted: Sat Oct 25, 2014 11:22 am
by bones
This was a factory order and they are not welded. Wonder if I should take it to dealer?
Re: 2013 Rear End
Posted: Sat Oct 25, 2014 2:19 pm
by coder
The plugs can come out if it's unpainted inside the hole I bet that's what happenen.
Re: 2013 Rear End
Posted: Sat Oct 25, 2014 4:57 pm
Those holes are for what is called a coconut spreader. It's a tool that has dowel pins that fits into those holes. Used for assembly.
Re: 2013 Rear End
Posted: Sat Oct 25, 2014 5:53 pm
by bones
RustyPW wrote:Those holes are for what is called a coconut spreader. It's a tool that has dowel pins that fits into those holes. Used for assembly.
Thanks, that makes sense!
Re: 2013 Rear End
Posted: Sun Oct 26, 2014 7:09 am
