Page 1 of 2
Speedometer calibration for 2014
Posted: Fri Oct 03, 2014 1:21 am
by ScalerFab
I'm looking to put some 285/75/17's on and will need to re-calibrate the computer to the new size. Anyone know what products are available for the 2014 - 6.4L?
Thanks in advance,
Troy
Re: Speedometer calibration for 2014
Posted: Fri Oct 03, 2014 7:12 am
by SheepdogOutdoorsman
The 2014 PW comes with 285's on it already ... You wouldn't need to recalibrate the speedo ...
Posted: Fri Oct 03, 2014 7:27 am
by JBM Power Wagon
When I got my 2014 I went straight to 315/70/17 tires and the dealer bought a Hypertech speedo calibrator that they used. Good news is when I picked up the truck, for some really odd reason, the salesman gave me the Hypertech speedo calibrator and said "I guess this is yours".
Posted: Fri Oct 03, 2014 8:08 am
by ScalerFab
SheepdogOutdoorsman wrote:The 2014 PW comes with 285's on it already ... You wouldn't need to recalibrate the speedo ...
The aspect ratio is different 75 vs 70. 285 is the width. 285/75/17' are 34". The stock 285/70/17's are 33"
Posted: Fri Oct 03, 2014 8:09 am
by ScalerFab
JBM Power Wagon wrote:When I got my 2014 I went straight to 315/70/17 tires and the dealer bought a Hypertech speedo calibrator that they used. Good news is when I picked up the truck, for some really odd reason, the salesman gave me the Hypertech speedo calibrator and said "I guess this is yours".
Do you know the hypertech part#? They gave it to you because it can only be used on (1) VIN at a time...
Posted: Fri Oct 03, 2014 8:12 am
It's only a 14mm difference, which is about a half an inch. 5% of 285 is roughly 14mm. There's roughly 25mm in an inch. I don't think that half an inch is going to throw your speedo off that much.
Posted: Fri Oct 03, 2014 10:58 am
by JBM Power Wagon
ScalerFab wrote:JBM Power Wagon wrote:When I got my 2014 I went straight to 315/70/17 tires and the dealer bought a Hypertech speedo calibrator that they used. Good news is when I picked up the truck, for some really odd reason, the salesman gave me the Hypertech speedo calibrator and said "I guess this is yours".
I have it at home so will post it up later.
Posted: Fri Oct 03, 2014 1:54 pm
by Bill2014
SheepdogOutdoorsman wrote:It's only a 14mm difference, which is about a half an inch. 5% of 285 is roughly 14mm. There's roughly 25mm in an inch. I don't think that half an inch is going to throw your speedo off that much.
In this case the speedometer would be off by 2.23 mph at 65
Posted: Fri Oct 03, 2014 2:06 pm
by Bill2014
These trucks all have GPS capability... Ram should take advantage of that and automatically apply a speedometer compensation periodically. This would keep the speedo's accurate as tire treads wear down AND reset the compensation factor for all the masses that change tire sizes.
After all, the trucks already adjust their engine and shifting tuning based on how it's being driven.
Posted: Fri Oct 03, 2014 3:57 pm
by coder
I got my speedometer calibrator from Hypertech I would give them a call and see if they have one for the 6.4 Hemi.
Posted: Fri Oct 03, 2014 8:35 pm
by adeluca73
Bill2014 wrote:These trucks all have GPS capability... Ram should take advantage of that and automatically apply a speedometer compensation periodically. This would keep the speedo's accurate as tire treads wear down AND reset the compensation factor for all the masses that change tire sizes.
EXACTLY...x2. This is so easy, it should be a built in user feature you can input in the "settings" menu.
Posted: Fri Oct 03, 2014 10:20 pm
by JBM Power Wagon
adeluca73 wrote:Bill2014 wrote:These trucks all have GPS capability... Ram should take advantage of that and automatically apply a speedometer compensation periodically. This would keep the speedo's accurate as tire treads wear down AND reset the compensation factor for all the masses that change tire sizes.
X3!!! That is a GREAT idea!!!
Posted: Sat Oct 04, 2014 2:13 pm
by loveracing1988
It is probably like the tuners and it is Vin locked to your truck.
Posted: Sat Oct 04, 2014 2:14 pm
by loveracing1988
ScalerFab wrote:I'm looking to put some 285/75/17's on and will need to re-calibrate the computer to the new size. Anyone know what products are available for the 2014 - 6.4L?
Thanks in advance,
Troy
Diablosport has the intune and Trinity for the 6.4, you can use that to reset the tire size and tune the engine if you want.
Posted: Thu Dec 04, 2014 1:10 am
by ScalerFab
Just installed 315/70/17's and have a message in to Hypertech. The speedo is off a little less than 5%...
If anyone has the part# of the recalibration unit I need, that would be great.
No rub with the 315's on stock wheels...
Posted: Thu Dec 04, 2014 4:23 pm
by ScalerFab
Well, this is the message I sent to Hypertech:
To whom it may concern,
I'm looking to purchase a speedometer re-calibration unit for my 2014 Ram 2500 Power Wagon with the 6.4 Hemi. I just mounted bigger tires and would like the compter to be in sync again.
Please let me know the part# of the product that I need.
Thanks,
Troy Loftus
And, this is the response I received:
Troy
We do not have a tuning device for this make and model, we may eventually but no word as to when at this time. We will not know the availability for a new application until a week or so prior to the release. I've entered your contact information so you'll be notified once ready. Thanks
Jim
So, if anyone knows the part# of the unit that folks have used to recal a speedo on a 2014 with 6.4, that would be greatly appreciated
Posted: Thu Dec 04, 2014 11:22 pm
by JBM Power Wagon
Hi Scaler, when I bought my truck the dealer used a Hypertech speedo calibrator and it worked. I did get your email so when I get a chance I will find it and pull the part number.
Posted: Tue Dec 09, 2014 9:24 pm
by ScalerFab
I found and purchased Hypertech part# 752501 for $163 w/ free shipping, and after updating the unit via the internet, it worked flawlessly. I had to try a few different tire heights to get the speedo corrected according to my phone gps. I actually am using 33.5". The tires I have measure about 34-ish", but when I used those numbers, the speedo was over the correct speed...
Posted: Tue Dec 09, 2014 10:01 pm
by JBM Power Wagon
Glad to hear it worked!!!
Posted: Tue Dec 09, 2014 10:15 pm
by ScalerFab
JBM Power Wagon wrote:Glad to hear it worked!!!
Thanks, man... I appreciate you taking the time to look that up for me. I can't believe that the folks at Hypertech stated that they didn't offer a unit that would work with my truck...
Posted: Tue Dec 09, 2014 11:02 pm
by adeluca73
Question, is the Hypertech good for anything other than reprogramming the speedometer? If not, $163 is awfully expensive to adjust just that one parameter, right?
Posted: Wed Dec 10, 2014 2:19 pm
by ScalerFab
adeluca73 wrote:Question, is the Hypertech good for anything other than reprogramming the speedometer? If not, $163 is awfully expensive to adjust just that one parameter, right?
Just good for gear changes, tire size changes, and reading/clearing DTC's... That's all I needed, so spending $400-$500 on a tuner that I don't want would have been wasting my money in my opinion.
Posted: Thu Dec 11, 2014 9:19 am
by olyelr
I know this does not pertain anymore really as the OP got a set of 315's, but anyway. Your numbers a re a bit off. Your "about a half inch" number should have been doubled, as it is only the sidewall height number (and there are 2 sidewalls in the overall height of the tire). Your picture clearly shows the overall tire height is over 1" taller. Certainly not a big changing factor, but...
Posted: Thu Dec 11, 2014 10:36 am
olyelr wrote:SheepdogOutdoorsman wrote:It's only a 14mm difference, which is about a half an inch. 5% of 285 is roughly 14mm. There's roughly 25mm in an inch. I don't think that half an inch is going to throw your speedo off that much.
The extra height is determined by radius, not diameter. So, "about a half inch" would still be correct.
Posted: Thu Dec 11, 2014 1:11 pm
by FirerescuePW
The extra height of the truck is determined by the radius. The extra height of the tire is determined by the diameter, which is directly related to the circumference, which is what the speedo and related programming uses to determine the speed of the vehicle.
