transfer case plug
w2dodge
transfer case plug
Post by w2dodge » Thu Jul 12, 2012 9:37 pm
dieletric greased a few things...disconnected battery,unplugged the sway bar, cleaned it,found it all in good shape greased it and zipped tied it tight....front and rear diff connections had some moisture on them took care of that with no issues....but..cant get the transfer case connection
apart..how does it come apart?
w2dodge
Re: transfer case plug
Post by w2dodge » Sun Jul 15, 2012 9:25 pm
i got it apart... :cheers:
Post by TwinStick » Mon Jul 16, 2012 4:32 pm
:wtf: Well HOLY COW w2dodge dude, tell us how you did it, where it is located, etc.... LOL :idea: This is something the :winchmob: wants to know !!! :cheers:
w2dodge
Post by w2dodge » Mon Jul 16, 2012 5:29 pm
Twin I was going to use bone collector benchmade and carve it apart , I just put a lot of light up there,jammed my skull as far as it can go to see how this bitch is connected ....just squeeze the top left side and pull up..she came off easy...clean it dielectric it snapped back in. Hope this solves my serv4wd rr light issue....everything works fine without them on
Post by TwinStick » Tue Jul 17, 2012 10:17 am
Thanks.
w2dodge
Post by w2dodge » Tue Jul 17, 2012 5:30 pm
Twin are you looking to take transfer case sensor connection apart ?
