Page 1 of 2
Wireless winch controller
Posted: Mon Aug 25, 2014 10:38 am
by cell4soul
I just bought my 2006 PW and it didn't have the winch controller. Can anyone confirm if the Warn wireless controller will work with this winch. From what I've read on this forum and on. Warn's website, it appears as though it will, but I would like to confirm before ordering. Also, how are people liking their wireless controller? Any issues? Thank you in advance.
Re: Wireless winch controller
Posted: Mon Aug 25, 2014 10:50 am
I got one. No issues with it. Works good. :rockon:
Posted: Mon Aug 25, 2014 11:12 am
by dogcar3
I like mine. Only complaint is that there is a small delay from hitting the button to the winch moving, so you have to plan for this.
Posted: Mon Aug 25, 2014 11:52 am
by vanished
Also use and like mine...
Posted: Mon Aug 25, 2014 4:54 pm
by Cactus Red
Having the ability to work from anywhere within range is so handy. Being able to check the line as things get tensioned for kinks, binding, or being cut on something really helps solo operators.
Sent from my DROID RAZR HD using Tapatalk
Posted: Tue Aug 26, 2014 12:14 am
by cell4soul
Perfect, thank you for the replies gentlemen. Sounds like the wireless controller is the way to go, cheaper than the wired controller.
Posted: Mon Oct 27, 2014 11:49 am
by Fred
Anyone have correct part numbers? Both wireless and wired?
MIne is 2012 PW. Thanks/Fred
In addition the Support team at WARN say that the Chrysler winch "called" warn will not work with the remote. So any info on where you got a working wireless remote and part number is much appreciated.
Thanks
Posted: Tue Oct 28, 2014 7:35 pm
by Will
One of the best things you can do, can get away from the truck, control it from the end of the rope, just way better all around
Posted: Tue Oct 28, 2014 11:22 pm
by Cactus Red
Fred wrote:Anyone have correct part numbers? Both wireless and wired?
Thanks
BS...
It's 100% Warn.
I use the old style remote, WARN 76080 Winch Wireless Control. Works great!
Warn 72567 Remote Control Assy. Should be the wired control.
Sent via Carrier Pigeon
Posted: Wed Oct 29, 2014 12:01 pm
by Will
Posted: Wed Oct 29, 2014 1:54 pm
by TonkaPW
I picked up one of the new style wireless remotes and love it. The receiver plugs in to where the wired one would. Simple plug and play.
Posted: Thu Nov 06, 2014 9:03 am
by Fred
Thanks for the input.
FourWheelParts had the wireless controller WARN 76080.
One minute installation and we were up and running.
Posted: Fri Nov 07, 2014 2:26 pm
by Throttle 8
There is an even newer model out. It is the Warn 90287. I just bought it on Amazon.com for $113.
Posted: Fri Nov 07, 2014 2:58 pm
by 04Ram2500Hemi
Throttle 8 wrote:There is an even newer model out. It is the Warn 90287. I just bought it on Amazon.com for $113.
I just saw that on Amazon. It looks like it's a plug and play kind of thing. Thoughts: http://www.amazon.com/Warn-90287-Wirele ... image_auto
Posted: Fri Nov 07, 2014 5:23 pm
by GunniPWguy
I am going to get that one over the older model with the need for wiring and remote sensor mounting location. You can just unplug it when not in use. Keep it simple.
Posted: Fri Nov 07, 2014 6:21 pm
by 04Ram2500Hemi
GunniPWguy wrote:I am going to get that one over the older model with the need for wiring and remote sensor mounting location. You can just unplug it when not in use. Keep it simple.
Exactly what I was thinking! Looks like I have something to tell my wife I want for Christmas.
Posted: Fri Nov 07, 2014 6:30 pm
by Throttle 8
I like simple! I will review it when it arrives---unless anyone that already has one wants to chime in. :cash:
Posted: Fri Nov 07, 2014 6:50 pm
by Dark84
I love it. Got it about a month ago. Plugs right in out of the box and is ready to go.
Sent from my mind to yours.
Posted: Fri Nov 07, 2014 6:58 pm
by GunniPWguy
DITTO! :idea:
Posted: Sat Nov 08, 2014 3:07 am
by adeluca73
It's sweet, just don't leave the wireless module plugged in all the time. It might work it's way loose, keep it in the glove box till needed. That's the only pro of the older style wireless controllet, you permanently wired & mounted the transmitter to the winch & inside the engine compartment.
Posted: Mon Nov 10, 2014 11:40 am
by Will
adeluca73 wrote:It's sweet, just don't leave the wireless module plugged in all the time. It might work it's way loose, keep it in the glove box till needed. That's the only pro of the older style wireless controllet, you permanently wired & mounted the transmitter to the winch & inside the engine compartment.
That's what I did, I ordered the one that plugs right into the winch but looked at it and said, "I will loose that" so I returned it and got the one with the cable and mounted the receiver portion behind the air box permanently. Put some silicone in the plug and plugged it in for good.
Posted: Mon Nov 10, 2014 9:40 pm
by hammer40
Too cool. Had to buy my truck a return home present.
Thanks for the link.
Posted: Fri Nov 14, 2014 6:28 pm
by Throttle 8
Got my Warn wireless winch controller in the mail today. It works FANTASTIC!
Total install time was 30 seconds----- and that includes the time it took me to drink a beer after I got it hooked up!!!! :chug:
Posted: Thu Dec 25, 2014 1:47 pm
by 04Ram2500Hemi
Just got the new wireless contol for Christmas. Going to have to mess around with it later. Way to go wife!!!
Posted: Fri Dec 26, 2014 2:02 am
by dale dalueg
I love mine
