High Mileage PW Help-Issues
Posted: Sat Aug 16, 2014 7:02 am
by MidnightPW
Looking at a clean 05 PW locally with 146,000 miles, seems clean and straight, no mods except dual exhaust and new tires a size bigger. Anyone out there got their PW to 150,000 miles and up and what have you had for issues?
Any common problems I could be overlooking even if it runs out strong?
Thanks in advance for any guidance..........
Re: High Mileage PW Help-Issues
Posted: Sat Aug 16, 2014 7:22 am
by RustyPW
Make sure the lockers and smart bar work. Look at the seals for the pinions on both diffs and front axle shafts. Make sure it still has the winch on it.
Posted: Sat Aug 16, 2014 9:48 am
by fyrfytr704
It also wouldn't be a bad idea to get an engine oil sample from it and send it for analysis. That may be able to give you an indication of how healthy the internals are. Other than that, the hemi engine is really reliable, so if the lockers and smart bar work, and the trans and transfer case is smooth, go for it!
Posted: Sat Aug 16, 2014 9:51 am
by fyrfytr704
Oh, and in case you've never checked into this, Amsoil and Blackstone are two reliable places to get it done.
http://www.amsoil.com/shop/by-product/o ... -services/
http://www.blackstone-labs.com/what-is-oil-analysis.php
Let us know if you end up bringing it home...
Posted: Sat Aug 16, 2014 10:46 am
by flattire
Rusty covered the most common areas. I might also add steering / front end. Drive over some "bumps" checking for "death wobble".
Posted: Sat Aug 16, 2014 1:32 pm
by MidnightPW
thanks guys, does 15 grand some fair if the truck is straight and all checks out with that mileage??
Posted: Sat Aug 16, 2014 10:37 pm
by coder
MidnightPW wrote:thanks guys, does 15 grand some fair if the truck is straight and all checks out with that mileage??
It would be an okay price if everything works, if not you could be looking at some pricey repairs, the engine and transmission if maintained could give you another 100k miles.
The front-end if orginal will need most parts replaced. The lockers, sway-bar and winch, as already indicated, are subject to water contamination in the connectors, which can get expensive real fast.
Is it from an area that is subject to a lot of rust? If so plan on replacing some front axle u-joints if they are the originals.
Posted: Sun Aug 17, 2014 7:40 am
by RustyPW
Also check the front ball joints for wear. And front axle u-joints.
Posted: Mon Aug 18, 2014 8:55 am
by leo72987
I purchased my 2005 Power Wagon with 156,000 miles on it for 12,000. Everything was tight and leak free except the power wagon equipment didn't work yet it was all there!!! I fixed everything myself so it was well worth it. Another thing to keep your eye out for are the control arm bushings.... Mine are shot and i'm currently saving up to buy some good aftermarket ones.
Posted: Mon Aug 18, 2014 11:54 am
by BlkWgn
I had a 2004 2500 that I bought with 17 miles on it and sold it with 185k with no issues, did not even do a tune up on it (hate to admit to that) Bought the 06 PW with 72k miles on it and now have 150k. Only issue is the sway bar quit engaging. Tried opening it up and giving it some lubrication and no luck, finally just ignored it for a year and a half and all of a sudden it is working agian. At Least so far, they have both been pretty solid trucks
Posted: Mon Aug 18, 2014 7:26 pm
by MSCH2112
that sounds high for that mileage, even if everything works. better be a mall crawler for that price. you can alway haggle them down on price.
mike
Posted: Mon Aug 18, 2014 8:40 pm
by Mr.Smith
Posted: Wed Aug 27, 2014 11:06 am
by lastmanalliance
I got 150,xxx on mine and the problems I'm having now is that my drivers side front hub is going out and my exsaust manifold gasket has a leak
Posted: Sat Oct 18, 2014 4:27 pm
by pdavey
Same problems with mine at 170K. Just ordered two new hubs. Will be replacing them out shortly.
Sent from my SM-T800 using Tapatalk
