Checked all FAQ's.
Seems no one has posted a Gen 4 locker bypass. Is it possible? Is the wiring the same as Gen 3?
Has anyone done on a Gen 4, and if so, can you post instructions?
Thanks,
Gen 4 Locker Bypass?
Re: Gen 4 Locker Bypass?
Do you want a hard wire installation or a plug and play option?
Either way would suit me fine, although using existing switches would be preferable.
We are in the mud a lot in the 'patch, and need to have my lockers locked in 4 Hi and higher wheel speeds in Lo than allowed by stock programming.
Sucks when lockers want to disconnect when I got my foot in it!
Info either way will be appreciated!
Take a look at this thread on Dodge Talk- this guy did it on his 2012.
http://www.dodgetalk.com/forums/showthread.php?t=348361
