How does one remove the center portion of the dash?
RAM4ROKS
Post by RAM4ROKS » Sat Jul 05, 2014 4:30 pm
I want to remove the center portion of my dash (the area around the radio and HVAC controls, on down to the floor console) so that I can figure out a CB mount but, I have no clue how to take apart the center section and don't want to just go breaking stuff trying to remove it not knowing how. Does it just pop into place or does it have fasteners, or what? Thanks!!!
myoung84
Re: How does one remove the center portion of the dash?
Post by myoung84 » Sat Jul 05, 2014 6:39 pm
There's two torx screws on the top under the rubber mat and one behind the cover for the 110v outlet (if you have it). Then just pull.
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Sat Jul 05, 2014 8:36 pm
I have pics on my build thread if that helps ...
RAM4ROKS
Post by RAM4ROKS » Sun Jul 06, 2014 7:26 pm
Awesome!!! Thanks y'all!!!!
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Sun Jul 06, 2014 7:38 pm
I know it's not exactly what you're looking for, but did that help at all?
bryanh416
Post by bryanh416 » Sun Jul 06, 2014 10:26 pm
Will you post pics once you have it mounted? I was looking at that area for a CB mount also.
Corsa DB Exhaust
Westin HDX Grille Guard
K&N Cold Air Intake
DiabloSport Trinity T1000
AVS Side Window Deflectors
DayStar 1" Leveling Kit
RAM4ROKS
Post by RAM4ROKS » Mon Jul 07, 2014 1:51 pm
myoung84- Exactly what I needed to know, thanks!
SheepdogOutdoorsman- a HUGE help actually, I am planning to route my wires through the firewall like you did but, I forgot who's thread showed how! (yours!)
bryanh416- will do! Hopefully be doing it later this week!
bryanh416
Post by bryanh416 » Fri Oct 31, 2014 3:41 am
Did you ever get that CB installed?
Corsa DB Exhaust
K&N Cold Air Intake
Timgco
Post by Timgco » Fri Oct 31, 2014 9:06 pm
I'm curious on this as well. I have a small Cobra 75WSXT that I plan to mount. Since the cleanest power is straight to the battery, I'll sneak the power through the drsd firewall. Than I need to find a place for a quick release to mount the antenna.
2016 Laramie Power Wagon
...www.idontworkforaev.com...
verdesardog
Post by verdesardog » Sat Nov 01, 2014 2:12 am
The best performing EASY antenna would be a mag mount on your roof.....just run the cable over the weather strip. That's what I'm doing with my 75watt 2 meter and it works fine.
I do have the power through the firewall directly to the + and - battery.
bryanh416
Post by bryanh416 » Sat Jun 27, 2015 9:20 pm
Well I'm just gonna bring the thread back from dead for a minute. I installed my CB radio today. There's a cubby hole under the dash where I imagine the ash tray would normally go. I cut the back out for wiring and shoved it in there as far as it would go. It sticks out a little farther than iwould like, but I think it looks pretty good.
Corsa DB Exhaust
K&N Cold Air Intake
