rear pinion play
trevor78
rear pinion play
Post by trevor78 » Sat Jun 21, 2014 7:48 am
I had noticed a clunk going into gear rev or drive. Check to see if it was a you joint,t-box,etc I found that the rear pinion has about a quarter turn back and forth moving from rev to drive. Hopefully one of you guys have seen to can tell me if its normal with the 4.56 gears. There is no side to side play in the pinion bearing, there is no play in and out of the bearing, and there seems to be no exsive noise from the gears. WTF hopeing this in normal and not the start of a axle build, truck only has 84k and stock for the most part
2006 power wagon quad cab (im keeping this one)
2007 BMW 530xi sold (cars just arent me)
2005 power wagon quad cab. silver. #633. sold
2005 quad cab CTD sold
2005 quad cab hemi sold
2003 guad cab hemi sold
SheepdogOutdoorsman
Re: rear pinion play
Post by SheepdogOutdoorsman » Sat Jun 21, 2014 7:53 am
My '07 1500 did the same thing and so does my '13 PW. I think it's normal ... At least I hope so
Post by TwinStick » Mon Jun 23, 2014 12:38 am
Keep us posted please.
Alakablamo
Post by Alakablamo » Mon Jun 23, 2014 8:42 am
That's normal. You can do the same thing to the front driveshaft.
