Page 1 of 3
swaybar disconnect
Posted: Fri Mar 14, 2014 9:21 pm
by stamm20
Has anyone installed the disconnect from offroad evolution yet? If you have let me know how it works my computer for the disconnect and lockers is shorted and looking to fix it soon.
Re: swaybar disconnect
Posted: Sat Mar 15, 2014 9:24 am
by leo72987
Hey there I'm in the process of installing mine hopefully will be done on Sunday. I will let you know how it turns out.
Posted: Sat Mar 15, 2014 12:49 pm
by twistedpw
If I pay for shipping can you send me all the parts you removed from the sway bar. I am trying to build air operated one just never seem to be able to keep mine apart long enough to get a good go at it
Posted: Sat Mar 15, 2014 1:17 pm
by myoung84
Now that would be sweet. An air operated locker!
Posted: Sat Mar 15, 2014 4:36 pm
by Chiprat1
Careful now, I am Sure Dodge is lurking around here somewhere.... Air Locker for Disconect, AirBag bar for Axle Hop, Hmmmm
Posted: Tue Mar 25, 2014 11:25 am
by stamm20
leo72987 wrote:Hey there I'm in the process of installing mine hopefully will be done on Sunday. I will let you know how it turns out.
Did you finish up the new swaybar disconnect?
Posted: Tue Mar 25, 2014 12:36 pm
by leo72987
Hey there not yet that weekend fell through ended up having to work.... I ended up buying a new smart bar for $250 so I went with that. I will still be installing the manual disconnect on the other one though as a spare. I'm hoping to have some time this weekend stay tuned!
Posted: Tue Mar 25, 2014 1:13 pm
by BlkWgn
Where did you find a sway bar for $250, I need one for an 06
Posted: Tue Mar 25, 2014 3:17 pm
by leo72987
Here's the bad news for you =/ Your 06 uses a different computer design than my 05. I bought mine from
http://www.rtpartsco.com/. However it seems that all 06+ Power wagon sway bars are $1500+ brand new. All 2005 models you can grab for like $250 what's funny is they all do the same thing they just made the 2006+ models out of gold or something.... Here is the price for yours from the place I bought mine
http://www.rtpartsco.com/oemparts/dodge ... 412AB.html
Posted: Tue Mar 25, 2014 5:22 pm
by BlkWgn
leo72987 wrote:Here's the bad news for you =/ Your 06 uses a different computer design than my 05. I bought mine from
I find your answer unacceptable, try again in a fashion that will cost me much less money
Guess I go back to my original plan of hardwired lockers and the Carli Sway Bar, just need the cash
Posted: Tue Mar 25, 2014 7:24 pm
by leo72987
BlkWgn wrote:leo72987 wrote:Here's the bad news for you =/ Your 06 uses a different computer design than my 05. I bought mine from
Haha I figured you wouldn't like my answer seems like the 05's are the cheapest to keep stock LOL. I decided to order it while I could before I couldn't get them anymore which I assume would be on the 10 year mark. When this one fails I will just end up switching of to the disconnect one
Posted: Tue Mar 25, 2014 10:08 pm
by stamm20
Well i went ahead and ordered the Evo disconnect!!!
Ill keep everyone updated when i get it put it in. Seems like a good design we'll see how it holds up
Posted: Wed Mar 26, 2014 6:40 pm
by GunniPWguy
Curious to hear how it works out. I have one sitting in a box waiting until my smartbar dies again. (only a matter of time) Then it will be hard wired lockers and manual swaybar disconnect from then on out.
Posted: Wed Mar 26, 2014 7:29 pm
by fbenross
What is the part number for the 2005 smart bar ??? anyone ??? I might want to buy one to mount on the rear of my truck.
Posted: Thu Mar 27, 2014 9:49 am
by leo72987
Hey there that would be an interesting setup the part # for a 2005 Power Wagon smart bar is 52121238AD
Posted: Mon Apr 28, 2014 7:02 pm
by leo72987
Hey guys I know this is a late update but I just hard wired my lockers and converted the sway bar to manual. I was tired of all the back and fourth working and not working....
Posted: Mon Apr 28, 2014 8:58 pm
by Big Blue
Are you happy with with the manual stabilizer? Did you know how to wire the lockers or did you use some of the info/instructions from the site, or elsewhere? I think I want to hard wire mine but I'm not crazy about doing the wiring myself. I'm definitely not a mechanic. Can do some simple stuff but I'm a little wary of wiring. If there are simple instructions somewhere I'd appreciate you pointing me to them. Thanks.
Posted: Mon Apr 28, 2014 9:07 pm
by stamm20
The manual swaybar is easy to install just three bolts,but I haven't had a chance to test it out yet ill getcha the link to hardwire the lockers I'm about to do that in a couple weeks not excited to tear into the dash
Posted: Mon Apr 28, 2014 9:08 pm
by Big Blue
awesome thanks.
Posted: Mon Apr 28, 2014 9:11 pm
by stamm20
Here's one of the links there's a few threads on dodgetalk about doin it
http://www.dodgetalk.com/forums/showthr ... re+lockers
Posted: Tue Apr 29, 2014 8:27 am
by leo72987
Hey I found the disconnect works great! You turn the knob all the way in hop in the truck and back up and listen for a pop. Almost instantly is disconnects to reconnect turn it all the way out hop in the truck drive around a little bit and you will here it reconnect. I've also attached another useful link for the hardwire details. It's pretty straight forward where you decide to ground it is up to you. I grounded both locker connections using one of the pre existing grounding bolts by the battery.
http://www.dodgetalk.com/forums/showthr ... ost4632642
Posted: Tue Apr 29, 2014 10:30 am
by Big Blue
Good stuff! Thanks a lot.
Posted: Tue Apr 29, 2014 11:04 am
by leo72987
Big Blue wrote:Good stuff! Thanks a lot.
No problem! Any questions feel free to ask!
Posted: Sat May 03, 2014 11:28 am
by Big Blue
Well...I got about 3/4 of the way through wiring my lockers and ran into a slight problem. I found the wiring harness that contains the rear locker wires, found the yellow with white source wire but when I tried to locate the yellow with gray wire I'm not seeing it. I admit I'm somewhat color blind but the wire that was wrapped closely to the yellow/white wire looked a little purple-ish gray.
Is the wire I'm looking for light gray or dark gray? I'm hoping someone says it looked purple-ish to them also.
Posted: Sun May 04, 2014 6:32 pm
by 2wagons1driveway
Here's a question when you hard wire the lockers is the locked icon still displayed on the power wagon panel?? Also how much was the manual swaybar disconnect?
