control arm replacement one at a time
rws5040
Post by rws5040 » Fri Feb 14, 2014 10:11 am
well i thought i needed ball joints. turns out i need new bushings in the lower control arms. I have the rancho pw lift been installed for six years or so now. Whats the thoughts on doing one arm at a time, pull replace bushings reinstall. safe to do or am i thinking crazy. Obviously truck and axle would be supported as needed. I may replace them all together with either the carli standard arms or bds long arm. Same process though one arm at a time. What do you guys think.
myoung84
Re: control arm replacement one at a time
Post by myoung84 » Fri Feb 14, 2014 10:26 am
One arm at a time would be fine. The use of a ratchet strap will help to pull the axle forward or backwards for easier installation. I'd recommend some new Carli arms, they are very well made.
Post by 05PWrockcrawler » Fri Feb 14, 2014 10:29 pm
Change the arms and one at a time would work. Good luck.
