I started a thread over DT about my power steering and a few of you said to go with the 2010 gear box. I found this one on ebay its the box and the pitman arm is that all i need to swap it over if so is it a good way to go. If yall think i should just buy a brand new one can someone get me a part number i haven't been able to find a new one yet thanks for the help
http://www.ebay.com/itm/07-08-09-10-11- ... 2619wt_988
Power Steering Box
- stamm20
Power Steering Box
Re: Power Steering Box
I'll call my contact, give me a few and I'll have it with current price.
Pn 68170214AA. List $700 my cost about $460
- stamm20
Alright cool Ummmm what else comes in the kit then the used one I found
- stamm20
Alright thanks for the help I just got it all ordered
- stamm20
Got the upgraded box put in this weekend its alot beefer then the original. Taking it out this coming weekend to test it out
I believe the steering shaft is different and will need to be upgraded. Be sure to center the wheel and tie the steering wheel in the cab down so it can't be turned or the clock spring will be damaged and need to be replaced ($$ and time). You will need the 09 and up pitman arm too as yours will be too small.
- stamm20
It came with the bigger pitman arm and drag link got the steering wheel centered the nest we could its goin to the alignment shop tomorrow to get it set perfect
