What did you do to your power wagon today?
LKelly
Re: What did you do to your power wagon today?
Post by LKelly » Thu Mar 07, 2013 3:36 am
Today I finally got around to popping out the dent in the driver's-side back corner of my truck, and putting my taillight back where it's supposed to go (more or less). Since one of the locating tabs is broken off the taillight, it's not mounted as good as it was...but that's okay, as I'll probably knock it off again anyway. This way it'll be more of a "quick-release" light, and maybe it'll pop off without breaking into pieces. :)
I also took the PW out in the woods and realized that the snow is right at the verge of being too deep - another couple of inches and I won't be able to get around anymore. The snow isn't all that deep, but the repeated freeze/thaw cycles we've had have made it very heavy - and once I start to push it with the front axle it's hard to move around. I can barely move on the level spots, and have to make repeated attempts to climb any hill. Weight in the back would help, and I'll have to add some if we get any additional snow this Spring.
Here's a quick picture I took, though the ruts are hard to see...snow doesn't provide good contrast for pictures. :)
The snow also doesn't help my mileage - I reset the computer before my trip, and when I got back it said I'd averaged 1.9 mpg. :D
chrisjameswagner
Post by chrisjameswagner » Thu Mar 07, 2013 3:45 pm
Booked an appointment to get my new shell installed!
JBM Power Wagon
Post by JBM Power Wagon » Thu Mar 07, 2013 9:27 pm
LKelly wrote:Today I finally got around to popping out the dent in the driver's-side back corner of my truck, and putting my taillight back where it's supposed to go (more or less). Since one of the locating tabs is broken off the taillight, it's not mounted as good as it was...but that's okay, as I'll probably knock it off again anyway. This way it'll be more of a "quick-release" light, and maybe it'll pop off without breaking into pieces. :)
I'd say that picture does do the snow justice! You can see the entire outline of your front axle from it pushing the snow. And in the hard crusty stuff that makes for some tough slogging.
Post by coder » Fri Mar 08, 2013 5:12 pm
Reinstalled my Carli King 2.5 pin-top shocks, I took them over to King to have them rebuilt.
Kings rebuilt and ready to install.
Installed left
Installed right
GunniPWguy
Post by GunniPWguy » Fri Mar 08, 2013 9:02 pm
Peeled off most of the chrome and the chrome bubbles on my grille assembly today. Cut my finger, Sanded, primered, spray painted gloss black with some duplicolor acrylic enamel. Looks OK but not perfect. Like the black on black though. Will be buying a new one someday.
GunniPWguy
Post by GunniPWguy » Fri Mar 08, 2013 9:03 pm
chrisjameswagner wrote:Booked an appointment to get my new shell installed!
:rockon:
Post by TwinStick » Fri Mar 08, 2013 10:19 pm
Filled it up with 30 gallons of gas & got $1.60 off each gallon, $70.77 !!! :rockon: Then got 11 more gallons in gas cans with no discount for $45 & some change. :angry:
w2dodge
Post by w2dodge » Fri Mar 08, 2013 10:28 pm
GunniPWguy wrote:Peeled off most of the chrome and the chrome bubbles on my grille assembly today. Cut my finger, Sanded, primered, spray painted gloss black with some duplicolor acrylic enamel. Looks OK but not perfect. Like the black on black though. Will be buying a new one someday.
I like it..excellent
SilverWagon05
Post by SilverWagon05 » Sat Mar 09, 2013 10:05 am
Took off my front drive shaft, to get it customized to work on my truck.
SilverWagon05
Post by SilverWagon05 » Sat Mar 09, 2013 10:09 am
And yes, while it's off, I am going to replace the front pinion seal. As you can see on the last pic, it is leaking more than just a little bit.
Post by TwinStick » Sat Mar 09, 2013 11:33 am
Just found out my rear driveshaft is squeaking while backing up. It was fine an hour ago but not now ! :angry: 30,800 miles. I guess it's time to install the Spicer Triple lip u-joint i have sitting on my shelf. :rockon:
VA_Wagon Man
Post by VA_Wagon Man » Sat Mar 09, 2013 11:43 am
That's how mine started, squeaking while backing.
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
bones
Post by bones » Sat Mar 09, 2013 6:36 pm
Well I took it on the 110 mile round trip to work last week since the forecast was a huge snow storm. Didn't even see a snowflake, so probably a waste of $25 in gas. Today took my summer tires (285-75-17 BFG M/T's on the stock PW rims) to get balanced. Removed my winter tires (35x12.5-17 Hankook Dynapro MT's on stock Dodge steel rims) to mount the summer tires. Got her all washed up and ready to go.
2012 PW - gone
2005 PW - gone
'03 Kawasaki Prairie 650
Post by TwinStick » Sat Mar 09, 2013 10:01 pm
:rofl: $25 for a 110 mile trip ??? Lucky you. In my truck, it would have cost me $43.56 for gas to go 110 miles. :cheers:
JBM Power Wagon
Post by JBM Power Wagon » Sat Mar 09, 2013 11:47 pm
I went out for a wheeling trip with a group of Jeeps. Snow was deep and crusty so if I lost momentum it was hard going in places. The 3000lb lighter Jeeps had a much easier time then me!
We were moving pretty quick on the trail so I didn't get very many pictures. I did, however, end up with a sway bar that won't reconnect and knocking my steering alignment off!
We went through one water hole with a lot of ice in and around it and my front axle hit the drivers side bumpstop really hard. And because I have procrastinated in applying Fluid Film and dielectric grease to my sway bar and locker connections I think another water hole is what messed up my sway bar.
Guess that means some time in the garage tomorrow!
bones
Post by bones » Sun Mar 10, 2013 7:45 am
TwinStick wrote::rofl: $25 for a 110 mile trip ??? Lucky you. In my truck, it would have cost me $43.56 for gas to go 110 miles. :cheers:
I was just guessing :D Not sure what it cost. I know I did put $80 in it when I got home.
2012 PW - gone
2005 PW - gone
chrisjameswagner
Post by chrisjameswagner » Sun Mar 10, 2013 3:53 pm
Shells on!
bones
Post by bones » Sun Mar 10, 2013 4:18 pm
What brand shell and how much did you pay?
2012 PW - gone
2005 PW - gone
chrisjameswagner
Post by chrisjameswagner » Sun Mar 10, 2013 5:33 pm
"What brand shell and how much did you pay?"
Century - High C is the model
Upgrades:
Carpeted Headliner
Removable Slider Bulk Window Head
3 slot 12 volt block
Tracker II rack on shell
Paid - $1800
There is a noticable difference in how the truck drives -Not as bouncy on the freeways, no "sideways" jump when hitting potholes, etc. Not as spry from a dead stop with my usual throttle application. I'm sure all due to the additional weight (I also dropped in a carpet kit). I picked up 1-2 tenths of mpg based on the OBC readings. Hopefully next week I can get it in the dirt and see if there are any major (negative) differences there. I'm expecting better traction, bottoming out sooner, and the shell not coming dislodged when flex or rocking is induced :doh:
So far I am pleased but the real test is in the dirt.
RAM4ROKS
Post by RAM4ROKS » Mon Mar 11, 2013 11:02 pm
Finally got and installed my personalized plate!:
VA_Wagon Man
Post by VA_Wagon Man » Thu Mar 14, 2013 10:34 am
^:mrgreen:
Long Gone:
GunniPWguy
Post by GunniPWguy » Thu Mar 14, 2013 10:43 am
chrisjameswagner wrote:Shells on!
That is a mighty fine looking topper. I like the roof racks. If you have never had one before, you will become attached to it. I use mine all the time to keep stuff safe and dry. It is also a pretty comfy one nighter space to sleep in the summer.
chrisjameswagner
Post by chrisjameswagner » Thu Mar 14, 2013 12:36 pm
Thanks! Yeah, I plan to do my sleeping back there when out. I'm heading down to Santee right after this message to get a set of Aluminess sliders installed - they finally came in!
chrisjameswagner
Post by chrisjameswagner » Thu Mar 14, 2013 6:39 pm
And they're on...
Countryman93
Post by Countryman93 » Fri Mar 15, 2013 1:42 pm
currently building a headache rack for the wagon, not pretty like the store bought ones but atleast it has some memories with it my gfs 3yr old daughter is helping me haha
05 Dodge Powerwagon
cobra cb with 4ft firesticks
