Tire? 35's v 37's & Nitto v Toyo
37" Nitto Ridge Grappler installed
Ok, was able to drop the truck off before the movers showed up this morning. 37" Nitto Ridge Grapplers installed, took less than an hr, had them air to -10% max (50psi Max) so about 45psi all around, measured height is right at 36.66", at 50psi they measured around 36.85", EVIC is freaking out of course, no correction available till AEV sells the ProCal or you buy a spendy programmer/tuner, speedo is off by 5mph according to the speedometer app I installed on my iPhone (PW: 35/iP: 39, PW: 40/iP: 45, PW: 45/iP: 50, PW: 50/iP: 56), tires ride great, way softer than the Duratracs (still had 12/32" left, so weren't as bad as I thought), and they are definitely quieter, did some full lock turns in the parking lot & no rubbing so far, didn't notice much braking difference, but I drive like a granny, acceleration took a hit even with 4.88's, MPGs down about .5-1mpg, 1oz,1.5oz, 2.5oz, 4oz were the balance weights, they said the stock tires had over 20ozs glued all around the inside wheel. $1179 OTD installed & balanced, no hazard warranty, After 10 miles, couldn't be happier.
http://www.drivingline.com/articles/bre ... -grappler/
http://m.nittotire.com/light-truck-tire ... ruck-tire/
Re: Tire? 35's v 37's & Nitto v Toyo
Very nice...test the crap out of them..looking for new shoes before the winter
Looks AWSOME. Let us know how they are holding up after a few hundred. Also wondering did you lose any articulation? And let us know after a close look it there is any rubbing issues.
16' Delmoico Red wagon "mods AEM dry air filter, DeeZee tail gate shock, Weather Tech window vents, Flowmaster exhaust, Ruff Country XHD recovery kit, Front window tint, WK Sliders, truexx leaving kit (on order)
Up next diff covers, 4.88 or 5.18 gears, 37in or 35in tires
Looks great man!!
Told ya! Looks great man!
Shoulda gone 35's.
My wife is banning me from this forum . She's accused you ALL of being enablers for an addict.
- yellowranger1
Don't listen to him!^^^ Even he didn't take his own adviceReloaderguy wrote:Shoulda gone 35's.
The 37s look great! When you get a chance, can you snap a closer pic of the front tire? I'd like to see how much it fills up the wheel well. Can't wait to get my 37s on now! You guys are making me antsy!
She's right ya'know.
Looks awesome! Any idea how heavy those ridge grapplers are? going back and forth between the ko2, R/T, and Ridge Grappler lol
2015 Power Wagon SLT
Mine constantly rolls her eyes. I only get the glare when purolator packages show up! Loladeluca73 wrote:My wife is banning me from this forum . She's accused you ALL of being enablers for an addict.
Looks awesome adeluca. Beautiful
Looks great sir! Almost makes me want a new truck
Thank-you!Colibri wrote:Looks great sir! Almost makes me want a new truck
"ALMOST, huh??"
nts007 wrote:Mine constantly rolls her eyes. I only get the glare when purolator packages show up! Loladeluca73 wrote:My wife is banning me from this forum . She's accused you ALL of being enablers for an addict.
If "Purolator" = Canadian version of UPS, then copy, same here...
The weights aren't listed on Nitto's site, but I found the 35's weigh around 72-73lbs, so I'd guess the 37's will run in the upper 70's then, which I'd guess is real close to the Toyo 37' RT'sblack_hawk8888 wrote:Looks awesome! Any idea how heavy those ridge grapplers are? going back and forth between the ko2, R/T, and Ridge Grappler lol
Wow!
Looks very nice
Looks very nice
Tell her just one last small mod and then you'll be done.adeluca73 wrote:My wife is banning me from this forum . She's accused you ALL of being enablers for an addict.
Copy. It's my next phase--shocks, boogies, springs--gonna be a painful one, but gotta do it. Looking at Theuren for either the cheap Overland, their new gas shocks you mentioned, the Kings like you bought, or like the Kings Will bought. Which triggers a new track bar, maybe new long arms or clearanced radius arms, end links (front/rear), steering stab, drag link, ugh this list gets ugly.
It gets ugly, but each time you get in it you'll be grinning ear to ear and it surely feels worth it.
Tire comparison OEM GY 33's v NITTO RG 37's
For those considering increasing tire size when your stock 33" GY Duratracs are worn out, or just want a bigger tire, here's some photos I snapped of the unmounted OEM 33" next to the mounted 37" Nitto Ridge Grapplers (@45PSI of max 50).
With all the available technology could you maybe post a picture that ISN'T sideways??? JK. It looks badass! You have a 2014 right? The diablosport will at least work to change your tire size. When it stops raining check how much of a contact patter you have on those rear tires. My 35's don't have 100% until I hit about 35 psi, my fronts are fine at 50. It is fine for now, but when winter rolls around you are going to want every little bit of rubber you can get on the ground.adeluca73 wrote:For those considering increasing tire size when your stock 33" GY Duratracs are worn out, or just want a bigger tire, here's some photos I snapped of the unmounted OEM 33" next to the mounted 37" Nitto Ridge Grapplers (@45PSI of max 50).
Sent from my Nexus 6 using Tapatalk
Dang, looks small. Should of gone with 40's.
