Oh Montero used to have one for longest time.FordyceCreekTrail wrote:I am in the same boat trying to make this major next leap. BTW I love my 05 Titan.....
Montero.....
Is that you Lloyd?
Alex from year 2000 in Colorado
Montero.....
So rear locker in high range is nice. I have had Powertrax and Detroits in my second gen and the G80 in the Avalanche. (and the e-locker in the F350s at work.)FordyceCreekTrail wrote:. Having 30yrs of wheeling under my belt I have never even considered lockers in high range, nor hassled with bead locks. With the patently absurd capability of the PW I could not imagine needing to air down that low ever.
I too have over 30 years wheeling and I agree with ramv. I think it all depends on what type of wheeling you do . It is advantages for us to be able to lock up in 4-high for the type we do. Our trucks at work also have the e-locker and from about October to well even today we get off the pavement,disable traction control (being sure to hold down the button for 5 seconds to disable the advancetrack) turn the knob to 4-high and engage the rear locker. It stays engaged all day until we see pavement again. Not everyone needs to be able to do that especially with the capabilities of the PW but then it just makes it that more versatile.ramv wrote:So rear locker in high range is nice. I have had Powertrax and Detroits in my second gen and the G80 in the Avalanche. (and the e-locker in the F350s at work.)FordyceCreekTrail wrote:. Having 30yrs of wheeling under my belt I have never even considered lockers in high range, nor hassled with bead locks. With the patently absurd capability of the PW I could not imagine needing to air down that low ever.
The main advantage on road is towing (one tire on ice or pea gravel while starting out. 4hi works too.) Off road, I like running hard on dirt roads in 2wd as well the "o crap moment" when you need to lock up with out the slow roll to low range. As well in the deep wet snow we get in ourneioughborhood (3.5' last weekend.) The locker bypass is probably overkill, but I do like taking one computer out of the loop.
No, its not mePWRider wrote:Oh Montero used to have one for longest time.FordyceCreekTrail wrote:I am in the same boat trying to make this major next leap. BTW I love my 05 Titan.....
Montero.....
Is that you Lloyd?![]()
Thanks!PWRider wrote:Nice rig ramp. Well there is on "small" issue with PW. Wheelhop in soft stuff. That is till you load it at least.
Aaron! What's up man?! Good to see you around, and glad to hear you still have the 2nd gen. Nice Power Wagon!ramv wrote:olyelr wrote:This has got to be the same ramv from back in my pavementsucks days lol. What ablast from the past!
Sounds to me, with your needs, what would be best for you is the power wagon. Good luck on your choice!
Yep!![]()
Still have the blue '01. Lots more dents and broken parts added to the list. Only a few rollovers though.
With the by-pass installed, if I even look at that knob, they lock upReloaderguy wrote:Try disconnecting the smart bar and reconnecting. The locker actuation lag time is not in the lockers.
Exactly, it's not the lockers, it's the dumb bar that can't make a decision. Hahaadeluca73 wrote:With the by-pass installed, if I even look at that knob, they lock upReloaderguy wrote:Try disconnecting the smart bar and reconnecting. The locker actuation lag time is not in the lockers.
ramv wrote:Got it on the smart bar. That makes sense. I have emailed cajunpw, nor response yet but would like to get the bypass asap!
Mine took a while too but since my bypass install they hook up immediately! You can find Cajuns email in the vendor section under the myoung bypass section. Email him and give him some time. He's a workin man with more responsiblites and not gettin as much time as he used too. Took about 4 weeks to get mine. But well worth the wait.olyelr wrote:ramv wrote:Got it on the smart bar. That makes sense. I have emailed cajunpw, nor response yet but would like to get the bypass asap!
Me too, where is his info?
