TJ02Gopher
Post by TJ02Gopher » Mon Oct 29, 2018 10:49 am
Have you noticed that after using ABS bypass, that you brakes seem better on road?
I made a similar bypass set up on mine, and after turning the ABS system back on, my brakes seem to be more responsive, almost stronger.
Post by Bill2014 » Mon Oct 29, 2018 1:21 pm
It's a real thing. Commonly referred to as the "Observer effect"
Are the brakes any different - probably not. But you are more aware of their performance...
Post by olyelr » Wed Nov 07, 2018 6:47 am
:rockon:
:cheers:
Post by Retired BLM Rig » Mon Jan 27, 2020 3:14 am
I thought I would bring this topic back to life to talk about the other trucks not currently covered by the 2013-18 Nanny Kill Switch. A half dozen 2011-12 owners are waiting for something that will fit their trucks and the same thing is happening with the 2019-20 trucks. I think I know the direction I need to go with the 2011-12 to make it work, I just need to get my hands on one to lay it out and test it.
What about you guys with the 2019 and newer trucks? Have they made any improvements with the "Traction Control Off" button or is it still cutting throttle response even when it's turned off? Have any of you tried pulling the #F2, #F9 or #F11 fuses to check the "start-ability" of the truck with each fuse removed? Does it actually kill the nannies when one of those fuses gets removed?
I don't have a 2019 to test, so if any of you want this to become a reality, it's time to do some hands on testing. Let me know if there's enough interest to move this forward. If you want to know what kind of testing you need to do, just start reading through the early pages of this thread. The goal is to know which circuit to interrupt without cutting into the factory harness, so it's plug and play and easily restored back to stock for warranty compliance.
:popcorn:
waldo
Post by waldo » Mon Jan 27, 2020 8:10 am
:popcorn:
It hasn't really snowed enough for me to run into the TC throttle cutting issue with the 19 yet. I've been able to get up the mountain to my cabin in 4X4 without the need to brute force my way, so far.
I'm sure it still esists.
The other notable nanny they added to the 19 is the door open autopark with the ZF trans. It can be defeated with a short seatbelt extender.
The one positive thing they did was allow the rear locker in 2WD. Still speed limited, but a plus none the less.
Pigpen
Post by Pigpen » Wed Dec 23, 2020 6:21 pm
Here’s a video of me installing and testing the Abel Components Nanny Kill Switch on a 2015 Ram 2500 Power Wagon. Works great!
https://youtu.be/4YTKJ2xtdR4
Thanks again Abel Components!
