Post by olyelr » Mon Oct 22, 2018 10:58 pm
Retired BLM Rig wrote:
Mon Oct 22, 2018 10:52 pm
Time to have a training session with your wife so she doesn't turn off the nannies by mistake. :lol:
LMAO :lol:
In her defense, she was just trying to close the garage door.... but if she starts flicking random switches then its her own fault :lol:
Post by Colibri » Mon Oct 22, 2018 11:30 pm
Man, that’s looking great RetiredBLM!!! Can’t wait to see some testing olyelr! Get out in the dirt man!
Fancy fancy on the color instructions btw lol. You’re already far ahead of the pack with that, I thought the industry standard was grainy b&w photocopied shit? Show off :rockon:
Post by Retired BLM Rig » Mon Oct 22, 2018 11:38 pm
Yeah, the wireless RF switch has the cool factor, but there's nothing like a dedicated toggle/rocker switch to avoid confusion.
One of these would minimize accidental engagement.
Post by Retired BLM Rig » Mon Oct 22, 2018 11:48 pm
I tend to be a little OCD. Just trying to do my part to MAGA. :patriot:
Post by Bill2014 » Tue Oct 23, 2018 10:07 am
nice work - very clean - straight forward! :notworthy:
Post by PWJouster » Tue Oct 23, 2018 10:57 am
ill take one!
Post by olyelr » Tue Oct 23, 2018 11:58 am
ill take one!
So will a friend of mine with a cummins truck.
Now, if he can just crack the code on the locker by-pass :twisted:
Post by Retired BLM Rig » Wed Oct 24, 2018 12:23 am
I won't be making anymore of these until there are some test results from the two that are out in the wild to make sure they are safe. I tried to find an inline Jcase fuse holder so I could reuse the factory fuse, but the only quality one that I could find was made by Littlefuse Co. and it comes with 8 Ga. wire which is way too big to interface with the Jcase housing. They have to make it that big in case it's being used for a 60 amp circuit.
The Jcase fuse that gets pulled is a slow blow fuse and the new inline ATC fuse is a fast blow fuse. They are the same 40 amp rating but have different characteristics. There needs to be some slippery surface/dirt road testing, making several ABS activating panic stops to confirm that the ATC fuse is up to the task and can tolerate the surge of starting and running the ABS pump motor. I'm 99% sure it will be fine based on the fact that they always over calculate amperage load with a margin. It probably surges to 20-25 amps at startup and then runs at less than 20.
We'll see. :popcorn:
Last edited by Retired BLM Rig on Wed Oct 24, 2018 1:40 am, edited 1 time in total.
Post by Retired BLM Rig » Wed Oct 24, 2018 1:18 am
The code has been cracked, however the connectors for the T-harness are currently made of unobtainium, unless you want to spend $200 for the factory gold plated terminals.
Female connector and terminals #68137859AA
Male connector and terminals #68137858AA
The last locker bypasses that CajunPW made were $300, this would jump the price up to $500. :jawdrop:
There's a 60 day lead time for the reasonably priced tin plated version but they only sell them in large bulk quantities and they're currently unavailable. This is the last piece of the puzzle that I haven't been able to figure out.
I just want to build a clone and see if it works. :ugeek:
Post by PWJouster » Wed Oct 24, 2018 9:21 am
ill pay $1000 for a plug and play harness for both lockers.
half as a deposit up front...
thats how little time i have on my hands
and ill beta test the kill switch while im at it.
Post by Reloaderguy » Wed Oct 24, 2018 9:28 am
It's worth mentioning that the locker bypass has a similar benefit as the BD 2Lo kit in that since the harness interrupts the actual lockers with relays the locker lights will not flash inop like is common. The BD 2Lo kit will stop your truck from saying it is shifting into 4WD when it isn't.
Post by TankerZak » Wed Oct 24, 2018 10:27 am
I would totally buy both of these, btw.
Post by olyelr » Wed Oct 24, 2018 10:33 am
I am gonna try to get the ABS to kick in hopefully by this weekend sometime. Im thinking it may be fairly difficult without snow.
Post by Bill2014 » Wed Oct 24, 2018 11:04 am
you need to take a trip up the ole dirt road... :poke:
Post by Reloaderguy » Wed Oct 24, 2018 11:08 am
Are the roads that bad in the meat packing district?
Post by olyelr » Wed Oct 24, 2018 1:41 pm
Well damn, that means I would have to get my tires dirty. I dont like getting my tires dirty.
Post by Bill2014 » Wed Oct 24, 2018 3:21 pm
Sometimes you gotta take one for the team!
Post by olyelr » Wed Oct 24, 2018 4:41 pm
Alright boys and girls, I had 4 nice high speed panic stops in the sand with with the abs kicking in as designed. No issues with the suplied fuse blowing, David. The best part was, the fifth panic stop I did with the magic switch flicked in the up position, which resulted in two large trenches dug by the front two tires. Not only did the abs not kick in, but the truck stopped much sooner. You dont say :roll:
Post by olyelr » Wed Oct 24, 2018 4:47 pm
And goldamnit, now my tires are all dirty and I am gonna have to wash the ENTIRE truck again.
Post by TwinStick » Wed Oct 24, 2018 10:11 pm
Will this kit work on our trucks...because our TCPS is different ? Mine is a 3rd gen as well, with a manual shift ? 2Lo sure would be nice for maneuvering the camper on blacktop. Thanks for the reply.
:popcorn:
Post by olyelr » Thu Oct 25, 2018 7:51 am
:popcorn:
According to this site, it only works on the 4.5 gen 3/4 ton trucks.
https://www.dieselpowerproducts.com/p-1 ... -1500.aspx
I would have to think without the cad this would not work.
Post by Reloaderguy » Thu Oct 25, 2018 8:58 am
:popcorn:
Only works with electronic CAD.
Post by Low_Sky » Thu Oct 25, 2018 4:29 pm
Looks pretty clean to me.
Post by Reloaderguy » Sun Oct 28, 2018 8:01 pm
I already had the switch bank mounted and the clutch block off plate drilled so this only took an hour to install. Most of the time was spent monkeying with the switch light configurations.
