Tire? 35's v 37's & Nitto v Toyo
Re: Tire? 35's v 37's & Nitto v Toyo
Nice tires, I like um... 35's?
Tis a joke about those kind of folks. I knew you were looking for bang for buck + performance. With the 4.88's and 37's I think you are going to be happy. I might of gone that route if I wasn't on the road. Hard for me to take the truck down for a week.adeluca73 wrote: FB is not my brand of Burbon, I don't use it. I'm too old to be worried about about trying to impress anyone.
Also, pictures when installed or it didn't happen.
Yup. I thought 37s would be a little too much since I tow a 30ft travel trailer. If it weren't for that, I would have 37s.coder wrote:Nice tires, I like um... 35's?
Copy will post when installed. Funny thing is the first real miles the new 37's will see is towing 6-8k LB trailer from Ohio to Virgina next week. Should have a much better feel if the new tires are shit or not.MikeKey wrote:Tis a joke about those kind of folks. I knew you were looking for bang for buck + performance. With the 4.88's and 37's I think you are going to be happy. I might of gone that route if I wasn't on the road. Hard for me to take the truck down for a week.adeluca73 wrote: FB is not my brand of Burbon, I don't use it. I'm too old to be worried about about trying to impress anyone.
Also, pictures when installed or it didn't happen.Looking forward to the word on new tires.
Beauties, sure like them RT's a lot!!FirerescuePW wrote:
I got RTs...
RPS1030 wrote:37" RTs at the beginning of sunrise on Mingus Mtn, AZ after running Smiley Rock trail yesterday.
Stock suspension? Working good?
- yellowranger1
That looks killer! Can you post a profile pic when you get a chance? Also curious about your suspension setup. I have a set of 37s (ko2 so they're smaller than your RT) for mine and am planning on keeping stock wheels so curious what you did to clear.RPS1030 wrote:37" RTs at the beginning of sunrise on Mingus Mtn, AZ after running Smiley Rock trail yesterday.
joeschmidt
Just ordered 37 toyo m/t's to be mounted this Wednesday the 10th along with thurens springs and white body shocks.
- yellowranger1
Thanks for the response. Hopefully these ko2 don't limit steering too much! If I'm not happy with the fit then I'll downsize to a 35. The 37s were destined for my play truck anyway but figured I'd try them out on the PW.RPS1030 wrote:All stock suspension. It just barely touches the plastic at the rear of the wheel wells when turned mid way and bumps (pulling into driveway). And certainly limits steering angle with the getting into the swaybar/control arms.
Black Pearl
Well i had Nitto TG's on a 2003 w some Carli parts and the were a good tire. Not the best in some situations but ok all round not bad. The new tread on the Nittos looks decent I think. (Competitive market so I believe that most at's will work for most people). With that said our rigs are different than most...
As far as the go RT's I dig mine. Great road manners and the looks are top notch i think. They do rug a little bit on the Thuen control arms at full lock but as tire gets worn down I bet It gets less and less. I bet the KO's will fit real nice.
Now Its time for the aluminess rear bumper so a 37 spare can tag along!! Bet that smooths the street ride out.
Just word to the wise, 37's fit but just expect your inner fender liners to rub like crazy and tear up when you wheel. Ask GTOMike; and his is lifted.
https://youtu.be/XyOWTXWobRM?t=1m0s
My 2010 doesn't rub anywhere. But it barely misses, wonder if it's the hummer wheel offset....
yellowranger1 wrote:Thanks for the response. Hopefully these ko2 don't limit steering too much! If I'm not happy with the fit then I'll downsize to a 35. The 37s were destined for my play truck anyway but figured I'd try them out on the PW.RPS1030 wrote:All stock suspension. It just barely touches the plastic at the rear of the wheel wells when turned mid way and bumps (pulling into driveway). And certainly limits steering angle with the getting into the swaybar/control arms.
The 37 KO2's are basically a large 35" tire. You should be fine.
joeschmidt
Springs, shocks, and 37's . Little rub, but not enough to be concerned
hammer40
Looks good.
black_hawk8888
Do you mind sharing which springs you are using? Any wheel spacers? Those are Toyo MTs it looks like? Truck looks terrific...so hard to find a PW with 37s on stock wheels!joeschmidt wrote:
2015 Power Wagon SLT
About to be another by the end of the day!!black_hawk8888 wrote:Do you mind sharing which springs you are using? Any wheel spacers? Those are Toyo MTs it looks like? Truck looks terrific...so hard to find a PW with 37s on stock wheels!joeschmidt wrote:
Yeah it looks great. I'm curious to know too. We have identical trucks. And this is wetting my appetite.
black_hawk8888
Sweet!adeluca73 wrote:About to be another by the end of the day!!
joeschmidt
Thank you! Thuren pw specific springs with thuren white body overland shocks, no wheel spacers, no trimming of the fender-wells or anything Very slight rub on the passenger radius arm at full lock/turn. Not enough to bother me. Yes they are m/t's 37x12.50 on the factory rim. Had a lot of people say I need a wider rim, but my opinion, they look great, I like to have some tire to rim protection just in case
black_hawk8888
Thanks for the update! How's the power loss/braking with the stock gears and the 37s?joeschmidt wrote:Thank you! Thuren pw specific springs with thuren white body overland shocks, no wheel spacers, no trimming of the fender-wells or anything Very slight rub on the passenger radius arm at full lock/turn. Not enough to bother me. Yes they are m/t's 37x12.50 on the factory rim. Had a lot of people say I need a wider rim, but my opinion, they look great, I like to have some tire to rim protection just in case
joeschmidt
For power loss.. A bit noticeable, probably won't win to many drag races. Lol. Braking.... It seems like it takes a little bit more room to bring it down. But it was all expected anyway.
Adeluca73 can't wait to see yours
Come on Adeluca73. I'm kind of following your build. I need to see how these things look.
and its end of day 6:30 pm eastern so let's go.
16' Delmoico Red wagon "mods AEM dry air filter, DeeZee tail gate shock, Weather Tech window vents, Flowmaster exhaust, Ruff Country XHD recovery kit, Front window tint, WK Sliders, truexx leaving kit (on order)
Up next diff covers, 4.88 or 5.18 gears, 37in or 35in tires
black_hawk8888
Seconded!Jeff50316 wrote:Come on Adeluca73. I'm kind of following your build. I need to see how these things look.![]()
Well Murphy's law struck again. The shop didn't call till noon to bring the truck in & I'm in the middle of moving right now. The house has been full of the packing crew since Monday & with a military move, I have to be present to supervise, & they didn't finish till nearly 7 tonight, after closing time. So the new plan is to drop it off first thing tomorrow morning before the movers show up to load out the house.
