New Nitto Ridge Grappler tires (hybrid)
Re: New Nitto Ridge Grappler tires (hybrid)
Hadn't seen that build thread, thanks.
If i was going 37s or 35s and changing rims I'd probably go with an 18x9. Little less sidewall but you're also adding sidewall via tire size.yagovomaltmoor wrote:Hadn't seen that build thread, thanks.
Cooper tires has a few that are mud/snow rated with the snowflake on them.
I had the ST Maxx in an R18 on my Duramax and they are Mountain SnowFlake rated. I think to get mountain snowflake rated you need to be a lot softer rubber. The reason, i believe, I tore through the ST MAXX with good rotations in 35k miles with a diesel...TwinStick wrote:Cooper tires has a few that are mud/snow rated with the snowflake on them.
Toyo RT is 45k mile rated and only M+S and i believe harder rubber. Mountain snowflake wasn't that important to me. I had to give up something. They might have done better on a lighter non diesel truck.
