Sounds reasonable. the plug does have 5 prongs in it though?Trouble Maker wrote:The problem is probably it is probably designed to work with the 3 wire Warn controllers and not the 5 wire the newer Warns like ours come with. Plug is the same but the internal wiring is slightly different.
Warn remote.
- GunniPWguy
Re: Warn remote.
- GunniPWguy
Re: Warn remote.
Did you have to do anything to it for it to work right Mule?Mule wrote:Wow.... I spent like $30 on the wireless one at Harbor Freight. It works fine. :dunno
http://www.harborfreight.com/wireless-w ... 69229.html
Re: Warn remote.
NoGunniPWguy wrote:Here the badland harbor freight el cheapo version is. Seems pretty substantial! I am assuming the green wire is to ground the receiver? Install instructions don't clarify. Anyone know for sure? Thanks in advance for any replies.horn.
No no no no no
the green wire is the antenna
that just dangles
don't ground that out
I did have to add a ground wire on the solenoid pack... the previous owner hacked up a lot of stuff on the truck that i've had to unf**k, so I don't know if that was part of his "wiring job" or if there was something goofy going on with the original winch controller. TBH i'm not sure how it could have worked without that wire, so I assumed it was something the previous owner broke.GunniPWguy wrote:Did you have to do anything to it for it to work right Mule?
Think it was the brown wire that connects to the coil of all 4 relays in the pack I had to tie to chassis ground, then everything worked.
Relays in the wireless receiver (or switches in the wired one) switch +12 to a pair of solenoids on the winch. Without a ground on those solenoids, that 12v has nowhere to go and nothing happens...
https://mule.smugmug.com/12k-winch/i-5M ... 770-XL.jpg
I still have no idea what the box is on the back of the winch.
https://mule.smugmug.com/12k-winch/i-Bb ... 035-XL.jpg
Re: Warn remote.
Mule that small box is the over voltage protection module. Dodge had warn put those on the truck per their spec... When voltage on the truck reaches below threshold it turns off the winch until proper voltage is reached again.
- GunniPWguy
Re: Warn remote.
Good info. Thanks. Pretty much hijacked this thread with Harbor freight crip crap.
shoulda woulda coulda.
Re: Warn remote.
I believe it is actually called a LVI = (Low Voltage Interupt ). Meaning- if the voltage dips below a certain point, it shuts down. They (3rd Gens anyways) also have a TPS = (Thermal Protection Switch/Shutdown). There was an easy $1.99 NAPA plug that allowed you to bypass this switch on 3rd Gens. If you even look at ours too hard, it would shutdown LOL
, hence the reason for the TPS bypass.
Re: Warn remote.
Yep that's what it's called LOL Forgot the fancy name for it haha and yes the Thermal Protection over ride is a must!! I did it on the control module when I replaced my winch motor with a normal warn unit.
Re: Warn remote.
I had forgotten that I also ran a redundant ground. While using the wired remote I was having intermittent issues with the winch not working in either direction, (I hadn't yet gotten the wireless yet). I tried the thermal bypass but it was still having issues. I tried the redundant ground and problem solved. I later picked up the wireless and it just worked. I now have the Warn remote as I ran over the remote from harbor freight and the Warn one was on sale at Amazon ($59 I think). I hoped it would have longer range and better battery life but it is about the same. Seems every time I go to use it the batteries need replaced and I'm forced to use the wired remote. I admit I don't use it very often though. I only have used it to move boulders and yank out trees and such. I do like the wireless when it works though.GunniPWguy wrote:Did you have to do anything to it for it to work right Mule?Mule wrote:Wow.... I spent like $30 on the wireless one at Harbor Freight. It works fine. :dunno
- GunniPWguy
Re: Warn remote.
Redundant ground from what to where? Thanks AZazracer wrote:I had forgotten that I also ran a redundant ground.GunniPWguy wrote:Did you have to do anything to it for it to work right Mule?Mule wrote:Wow.... I spent like $30 on the wireless one at Harbor Freight. It works fine. :dunno
