Where in Montana are you at? I'm sitting over in Missoula but make a lot of trips up north towards Bigfork and then down to the Bighole for Elk Hunting.Chuck Arseneau wrote:ME TOO !!!!!!!!!!!!!!!!!! Should be here end of June !! What color did you go with ??? Im up here in Montana,it will be put to the test !!
New Guy! Ordered 2014 Laramie PW!
Re: New Guy! Ordered 2014 Laramie PW!
- BANGG
As i offered to Young I am available and will do FOR FREE some sagebrush pinstriping to any of your beautiful new trucks!! Im very talented at it. In fact its a specialty of mine!
2011 Ram Hazzard Wagon
- GunniPWguy
LOL! Nice shot! Yeah, I got a lot of funny looks when I took mine wheeling brand new, had it for 3 days, had the 30 day tags on it, and took it to Uwharrie!2wagons1driveway wrote:Ha ha! Ya smart people usually don't wheel the brand new ones....05PWrockcrawler wrote:Sweet welcome to the club. Hope to see you on the trail but that new you won't be wheeling it no time soon lol.
Looking at their actual measured width, the Toyos are typically wider than they are stated to be. Example from when I was looking at tires:GunniPWguy wrote:Just what I have been told. Don't know from experience but, Toyo MTs are some of the widest 35's out there. So you might end up with some front fender and control arm rub.
37x13.50R17 Toyos are 1.9" wider than 37x12.50R17 MTRKs.
We'll any tire that's rated at 13.5" will be wider then a 12.5" by approx 1" no? On my fourth gen I had 315/70r17's on a 4.5" b.s. Wheel and I rubber the inner fender liners at the rear of the fender by the punch welds. I'm not sure about this combo on a stock wheel id imagine you'd be chiseling the inner tread on the control arms but you'd be staying away from the pinch welds!RAM4ROKS wrote:Looking at their actual measured width, the Toyos are typically wider than they are stated to be. Example from when I was looking at tires:GunniPWguy wrote:Just what I have been told. Don't know from experience but, Toyo MTs are some of the widest 35's out there. So you might end up with some front fender and control arm rub.
You are correct for most applications but the Toyo MT is 1.9" wider not 1" like one would expect when comparing a 12.5 to a 13.5 that otherwise fits the same rim size. I think this is what he is trying to point out 2" vs. 1".2wagons1driveway wrote:We'll any tire that's rated at 13.5" will be wider then a 12.5" by approx 1" no? On my fourth gen I had 315/70r17's on a 4.5" b.s. Wheel and I rubber the inner fender liners at the rear of the fender by the punch welds. I'm not sure about this combo on a stock wheel id imagine you'd be chiseling the inner tread on the control arms but you'd be staying away from the pinch welds!RAM4ROKS wrote:Looking at their actual measured width, the Toyos are typically wider than they are stated to be. Example from when I was looking at tires:GunniPWguy wrote:Just what I have been told. Don't know from experience but, Toyo MTs are some of the widest 35's out there. So you might end up with some front fender and control arm rub.
Bingo! Exactly my point! Thanks!azracer wrote: You are correct for most applications but the Toyo MT is 1.9" wider not 1" like one would expect when comparing a 12.5 to a 13.5 that otherwise fits the same rim size. I think this is what he is trying to point out 2" vs. 1".
Ya that makes sense
Not sure if you got your answer. I am currently running 35/12.5/17 toyo m/t's on stock rims. I do not rub the fender wells but I do rub the control arms on both sides.
The fender wells are much harder to cure....ask me how I know lol
