Wheel hop, axle wrap...
Re: Wheel hop, axle wrap...
Post by Bill2014 » Thu Feb 25, 2016 3:50 pm
Pretty much any vehicle that I have ever owned could be made to go into a traction slip hop resonance with the right combination of conditions - predominantly driven by traction and power output. In the two years with my 2014, I have only experienced serious hop once - and cleared the resonant condition by flooring it because it would have been unsafe to stop at the time. Most of the time we can let off the gas a little, regain traction, and continue on without losing much momentum. So my solution won't be to change the truck - but to learn how prevent it or quickly adjust and drive through it. I'm not gong to obsess about the hop - and certainly won't throw any money at it :D
Post by RustyPW » Thu Feb 25, 2016 4:29 pm
This issue has been around long as I can remember. Anyone here ever do a hole shot with a '70's mid size cheby with a coil spring end rear? You're lucky to keep your teeth in your mouth. Everything is a compromise in ride, handling, traction, braking, load capacity, etc.
Post by Will » Thu Feb 25, 2016 5:18 pm
All I know is my Power Wagon is a bad son of a bitch hahaha
Post by cruz » Thu Feb 25, 2016 5:44 pm
Bill2014 wrote:Pretty much any vehicle that I have ever owned could be made to go into a traction slip hop resonance with the right combination of conditions - predominantly driven by traction and power output. In the two years with my 2014, I have only experienced serious hop once - and cleared the resonant condition by flooring it because it would have been unsafe to stop at the time. Most of the time we can let off the gas a little, regain traction, and continue on without losing much momentum. So my solution won't be to change the truck - but to learn how prevent it or quickly adjust and drive through it. I'm not gong to obsess about the hop - and certainly won't throw any money at it :D
RustyPW wrote:This issue has been around long as I can remember. Anyone here ever do a hole shot with a '70's mid size cheby with a coil spring end rear? You're lucky to keep your teeth in your mouth. Everything is a compromise in ride, handling, traction, braking, load capacity, etc.
X3
Have you ever seen the wheel hop on a 3 axle concrete mixer trying to back up a dirt incline. I've seen a few over zealous drivers snap an axle or two, lose a driveshaft or blow the differential. :lol:
Post by Will » Mon May 09, 2016 5:26 pm
Was at the dealership looking around today and spied...
dodgeman324
Post by dodgeman324 » Mon May 09, 2016 5:51 pm
Ooo, it's so pretty and clean. I wish I could get my undersides that clean again. But, what are you spying? The bilstein looking shock at the top of the diff? Do those things actually help?
Former Vehicles:
1998 Dodge Ram Quad Cab
Post by Will » Mon May 09, 2016 5:53 pm
Yes, that shock, that's a regular cab 2500 6.4 tradesman, had a utility bed but the guy says they order them bed delete and them put the bed on.
PWRider
Post by PWRider » Mon May 09, 2016 6:43 pm
Is that diff breather just dangling in the air.
Post by Will » Mon May 09, 2016 6:56 pm
Looks like it's clipped to the bracket
loveracing1988
Post by loveracing1988 » Mon May 09, 2016 9:04 pm
PWRider wrote:Is that diff breather just dangling in the air.
Will wrote:Looks like it's clipped to the bracket
The problem is the bracket sucks. I've already had mine come off of it twice before I zip tied it.
Post by olyelr » Mon May 09, 2016 9:52 pm
Your ol girl is down for the count because you pounded on her too hard and then you go out and start looking for love in other places :lol:
Post by RustyPW » Mon May 09, 2016 10:40 pm
olyelr wrote:Your ol girl is down for the count because you pounded on her too hard and then you go out and start looking for love in other places :lol:
:lol:
Post by Will » Tue May 10, 2016 6:23 am
:lol:
I'm looking at all options...
Post by nts007 » Tue May 10, 2016 11:19 am
So you're running around looking up skirts lol
agpilot
Post by agpilot » Sat Jun 10, 2017 9:19 am
Sorry to dredge up old thread but I see people have tripled up the Bilstein anti-hop shock. Has anyone tried replacing it with a single, equivalent travel 3.0 or 2.5 Fox or King shock?
Post by DamageWagon » Sat Jun 10, 2017 12:12 pm
Never heard of it but you certainly could.
Post by FirerescuePW » Sat Jun 10, 2017 4:47 pm
Figuring out the valving could be tricky. It sounds promising.
Post by DamageWagon » Sat Jun 10, 2017 4:55 pm
FirerescuePW wrote:Figuring out the valving could be tricky. It sounds promising.
King and Fox have dynamometers in their shops to test existing valving. They could test the factory shock and provide a stiffer valving profile. Or you could just go straight to a .020" stack and see how it does.
Post by adeluca73 » Sat Jun 10, 2017 6:11 pm
Or add 2 more to the existing like me... :mrgreen:
Post by Reloaderguy » Sat Jun 10, 2017 7:21 pm
Or just let a little air out of your tires.
Post by adeluca73 » Sun Jun 11, 2017 6:44 pm
Reloaderguy wrote:Or just let a little air out of your tires.
Way easier too...
Post by Bill2014 » Mon Jun 12, 2017 7:16 am
:doh: oh no :lol:
