Post
by OffroadTreks » Fri Jun 23, 2017 10:59 am
Reloaderguy wrote:I eagerly wait for the tire thread crying about load ratings.
Won't happen. Load ratings are per tire. Wrangler MT/R 40x13.5 Load Range C for example 3195 x 2 = 6390lbs, plenty of load on the rear of the truck. Last time I was across the scales I only had 4620lbs on the rear axle while towing.
Maths are easy.
Post
by Reloaderguy » Fri Jun 23, 2017 11:25 am
We'll see what you say once you actually tow with a C tire. A little squat is in unacceptable but squirmy C rated 40's are. This thread got retarded in a hurry.
Post
by olyelr » Fri Jun 23, 2017 1:45 pm
The 40" Toyo's on a 24" wheel are load range E. And they would be all the rage at the starbucks drive through.
Post
by OffroadTreks » Fri Jun 23, 2017 1:59 pm
olyelr wrote:The 40" Toyo's on a 24" wheel are load range E. And they would be all the rage at the starbucks drive through.
15 inches wide
Post
by OffroadTreks » Fri Jun 23, 2017 2:00 pm
Beadlocks are almost as expensive as a gas cap. I might have to second mortgage my house.
Ramajama
Post
by Ramajama » Fri Jun 23, 2017 8:39 pm
Sorry haven't gone through the whole thread but there's a guy on YouTube who goes by IWrocker. He put one of the higher end 5" rough country lifts for a 2500 on his PW. He had a local shop fab it up to work on the PW. He's got 37s and It looks and performs awesome. You might check it out.
Dude was in the same boat.
https://youtu.be/-K4LGj0V730
Ramajama on Fri Jun 23, 2017 9:00 pm, edited 2 times in total.
2018 RAM 2500 Power Wagon
Ramajama
Post
by Ramajama » Fri Jun 23, 2017 8:54 pm
This is not a lift but it's a pretty sensible set up imo.
https://youtu.be/7J4fbvoBhxs
Post
by Reloaderguy » Sat Jun 24, 2017 12:22 pm
Mike, I'd like to help cut holes in your truck. Can we do a second sunroof when we do the fender? I have a sawzall. Let me know, Que Thx!
Post
by nts007 » Sat Jun 24, 2017 7:56 pm
6 ply tires towing is a very bad idea. Even if the load capacity is the same or better. Even a jump from 10 ply to 8 is hugely noticeable.
Post
by Retired BLM Rig » Sun Jun 25, 2017 12:24 am
You'll always regret it if you don't go all the way to 54's and portal axles.
2008 Quad Cab - Stock
RTI = 655, curb weight = 6081 lbs.
Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®, Abel Components Nanny Kill Switch®, 2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
Post
by OffroadTreks » Sun Jun 25, 2017 9:47 am
Retired BLM Rig wrote:You'll always regret it if you don't go all the way to 54's and portal axles.
Probably right.
