2018 Power Wagon issues
Re: 2018 Power Wagon issues
I have a hard time believing this is a legit thread ... is it just me?
I have a hard time believing an engine would just drop a rod without any warning what so ever. I'm a straight up FCA hater these days but still think something is missing.
Mechanics didn’t design, write 10’s of thousands of lines of finite element code, perform countless stress analyses, spend years in the lab formulating new materials & experimenting, build, test, or produce these trucks.
^^^^^Reloaderguy wrote: ↑Fri Jul 27, 2018 2:52 pmWait until you buy a Ford or Chevy and they tell you the same thing. Look at how the Ford 6.0 roll out was handled; Ford fucked over thousands of owners telling them there's no fix or the EGR/Coolant/Head bolt issues were the owners fault. The reality is, as new a vehicle owners, you roll the dice on quality. The manufacturer's warranty is only as good as the service dealer or the OEM wants it to be. Fortunately, your truck is new enough that you have Lemon Laws protecting you. Do some research and find out what your rights are, if it turns out FCA won't or can't fix your truck pay a lawyer to start the Lemon Law process. Just don't fool yourself into thinking this won't happen with another manufacturer.Selloutrr wrote: ↑Fri Jul 27, 2018 1:14 amThank you! They have ran code checks 4 times. I’m not ruling out hardware issues but at the moment Chrysler has a no replacement policy on the radio. It generated a error code but Chrysler has no plans to fix the issue on models prior to 2019. Its this kind of bullshit that makes me no longer want to own a RAM
This is why I own a PW...my F250 King Ranch had 2x $3000 disasters inside 6mo’s, one was that exact problem and Ford wouldn’t cover it under their powertrain warranty.
If even half of this is true, man I feel for you. However, what is the intent of your long winded posts? If you want us to read and engage, consider organizing your thoughts better, properly layout a structure that flows and is spaced correctly, use the right syntax, grammar, tense, and punctuation...this was difficult to read and follow.Selloutrr wrote: ↑Mon Jul 30, 2018 12:03 pmCan’t say I really care about the truck being gas or diesel. AES makes any RAM diesel into a Prospector so it was an option. What I am having a difficult time with is over all shamefully embarrassing fit to finish, and over all lack of accountability toward failing to manufacture a realizable truck. I will NEVER get to have idle time be an issue because I don’t trust taking this truck with it’s knoen issues (Let alone, the unknown ones). Anywhere roadside assistance can’t get to. IMHO the 2018 PW and RAM are a joke. I love what the truck could and should be, but I have zero confidence in the truck or Chrysler’s ability to service it. Which makes ownership no longer something I want to part of. After 7 trips to the dealer and 6weeks without the truck and no resolve to issues. Anyone considering buying a Power Wagon or a RAM in general should look at other options. If you still have to have one. Buy a used one because your NEW warranty is worthless.
Yesterday it failed to come out of park. Not to be sexist but the amount of strength to shift was more then most females could apply. (Just trying to make a visual of the amount of difficulty it takes to shift). Once it pops out of P it sounded like a box of rocks getting shook as it went through the PRND. (I took a video.. but I’m crazy it doesn’t have any issues says RAM...). Later the SXM radio stopped putting out volume. Switched to AM radio and it rebooted my iPhone. I can’t tell you how disappointed I am in this truck but not even the truck but the dealerships and corporate. The dealership can’t “hunt” for the issue they have to follow corporate guidelines. RAM “has no approved fix”. Seriously someone with the ability to read a schematic should be able to pin point the problem in the system diagram and fix this just based on the issues. Bad module, bad CPU, bad wire, bad ground... then meter continuity and look for a pinch wire. The issues all started after a drive down a road with some mild ruts. If this is the “build quality” it’s not off road quality. As for the computer side of things. I also own a Ford C-Max hybrid it is a computer. Zero issues ever! No wait the AC once shut off I took it in and in 30 minutes it was happy again. Even my Porsche Carrera is better built and more reliable then the Power Wagon, because when I have an issue they can fix it and the radio has always worked. All the research and reviews don’t tell you how little corporate cares about the quality of the build. I wish I had known. The last service tech. Basically told me I was crazy, making it up, and had buyers remorse and couldn’t afford the truck... WTF!? First off I bought it in cash out right. Second these issues are real look at the videos. The only things crazy about me is I bought an American truck and drive 5hrs to attempt to have it serviced by someone I thought wasn’t a piece of shit. It’s con isn’t for RAM to assume that because they can wash their hands and not have to swallow the fact their shit stinks. For these reasons I no longer want to own my Power Wagon or another RAM/chrslyer product.
Agreed, i was referring to the "engineers" that arrive at a dealership to "troubleshoot" a problem, not actual engineers that design.
Well, common sense is telling me, that late-2017 / early-2018 when Mexico got the message that the Ram HD vehicle production is moving from Saltillo, Coahuila to Warren, Michigan; quality control went w-a-y down and will continue to do so.
Just think, If our employer said, 'most front-line workers are going to start getting laid off in sixth months to a year, no matter how well their job performance may be', what kind of quality control would be reasonable from that point on?
The only issue my 15' has had was it required a PCM reflash & update. It's been perfect other than that.
Another reason for most owners to wait until the 2020 model.
37's and some
to Thuren when the warranty expires
37's and some
I just checked all my engineering diplomas—they unfortunately didn’t designate whether I was an actual engineer or a troubleshooting engineer.stooper wrote: ↑Fri Aug 31, 2018 11:59 amAgreed, i was referring to the "engineers" that arrive at a dealership to "troubleshoot" a problem, not actual engineers that design.![]()
Or a Refuse Engineer.adeluca73 wrote: ↑Tue Sep 04, 2018 11:16 amI just checked all my engineering diplomas—they unfortunately didn’t designate whether I was an actual engineer or a troubleshooting engineer.![]()
- Rodeoflyer
Agreed...the 18’s seem to have all the problems.Sweet5ltr wrote:Well, common sense is telling me, that late-2017 / early-2018 when Mexico got the message that the Ram HD vehicle production is moving from Saltillo, Coahuila to Warren, Michigan; quality control went w-a-y down and will continue to do so.
The Mexicans are sabotaging trucks. It’s all Trumps fault according to CNN
my 18 is relatively perfect.. for what it is.
sketchy uconnect behavior
cracked cab lights
crappy shifting
10k miles and rear diff fluid was shot
but i trash it, and im positive i would have buried a raptor by now.
every truck, every brand, there are lemons and losers. powerwagons individually feel like they are solid as a rock, and built better then mass spec diesels and 5.7s.
the list of issues
my 2013 audi S6 was flawless
my 2014 BMW x5 50i, rattled mercilessly and had tech issues
2012 and 2016 jeep JKs, dont get me started.
2018 Ram powerwagon is perfect even with the EPA-DOT-NHTSA regulations shoved in its gullet. we just need mass scale engine/transmission tuning among us.
i was not going to find what i was looking for anywhere else. POWERWAGON
P.S @Selloutrr you just got a bad apple, sorry
cracked cab lights
crappy shifting
the list of issues
No real issues other then the shitty tires.
WARNING NSFW - But I do wonder, if this is the same guy, lolololololol
I would say that the guy is up-set. Think i would be too.
Lmao! Yea his temper escalated slightly, but who's wouldn't? I bet twinstick would keep his shit together no prob
Dude is gonna have a stroke, lolol
“My manager is willing to extend three free oil changes. Does that work for you?”
- HammerTime
- Model Year: 2017
It's an exception and not the norm. I've had 3 Power Wagons now, all 3 were/are great trucks with no issues besides some recalls.Bbqman151 wrote: ↑Wed Aug 01, 2018 9:33 pmI am thinking of buying one within the next year. I truly hope this is just a case of bad luck with this one. I know it's gotta suck having all those issues with a brand new truck. I'm like Numbnuts though. When I hear stories like this, it really makes me hesitant to spend close to 50k on a truck if they're just making junk. Somebody please tell me this is an exception and not the norm.
2010, 2013, 2017.
I will eventually get another I'm sure, but it will be a while as I'm starting to put more $$ into retirement plans as I'm getting up there a bit...
I'll probably keep it for at least 5 or 6 more years. (1 year gone already!!! Yikes.)
Now, I have noticed that when I park my truck on a hill the transmission can be a little hard to shift out of park into reverse or drive. However, that's been the case in all my trucks over the years. Do i hear a clunk once in a while? Yep. Same as every other truck I've ever owned. LOL, I even hear a little clunk once in a while in my Hellcat Challenger. Mechanical stuff clunks once in a while...
Anyway, if I hated my rig as much as some of ya all, I'd definitely get rid of it and buy a Ridgeline. LOL, if you get a chev or ferd be prepared for disappointment!
2017 White/Black Power Wagon
That was volcanicBoldAdventure wrote: ↑Mon Sep 10, 2018 1:42 pmWARNING NSFW - But I do wonder, if this is the same guy, lolololololol
That guy sounds like me. I was waiting for the manager to tell him it was his fault because of his shocks.adeluca73 wrote: ↑Fri Sep 14, 2018 1:47 amThat was volcanicBoldAdventure wrote: ↑Mon Sep 10, 2018 1:42 pmWARNING NSFW - But I do wonder, if this is the same guy, lolololololol
That guy's original problem is caused by a bad connector behind the monitor.
Yes. It sounds like the majority of his problems were from the radio change-out.
Well, you could have bought a ZR2.
Chevrolet Colorado Side Curtain Airbags Keep Deploying On Easy Off-Road Trails
- Rodeoflyer
A good lesson here is if the truck doesn’t have everything you ordered it with DO NOT let the dealer ‘make it right’. Cancel that order and order another one
If the steering wheel air bag doesn't kill you. And the seatbelts doesn't burn you up. Now the side curtain air bags will sucker punch you in the side of the head.KevinABQ wrote: ↑Fri Sep 14, 2018 1:46 pmWell, you could have bought a ZR2.
