Do all 09's have VVT
PowerWagonP
Do all 09's jave the 383hp VVT? Found a decent deal on one. It was end of February build
2006 PW, 35's, 1" lift, Superchips, Magnaflow, 430km amd counting
72 Bronco Pavement Princess.........
Re: Fo all 09's have VVT
You can check by the vin number, I don’t know if all 09’s do but mine sure does
Re: Do all 09's have VVT
Yes, you can tell by the air intake tube in the front on the engine
PowerWagonP
I did check vin and it does have it. I am buying it. Some sites have it at 355hp and some 383 hp. Thought they were 383 hp in 09?
They are if they’re vvt
Here are the specs for the Power Wagon 5.7 Hemi. Ram 1500 Hemi's may have different hp/torque ratings for some years.
2005-2008 Power Wagon 5.7 - (345 hp and 375 lb.-ft.)
2009 Power Wagon 5.7 VVT - (355 hp and 395 lb.-ft.)
2010-2013 5.7 VVT - (383 hp and 400 lb.-ft.)
Where’d you find the 09 with different power numbers than 10 and on? As far as I know the 09 and on 1500 and 2500 share the same 383 horsepower motor. Even the drive belt system is the same between them, in my work experience they’re identical
I got this information by searching Google for "2009 ram power wagon specs" here's a few results. The 2009 2500/3500 5.7 VVT is a one year only engine configuration, the 2009 1500 5.7 VVT has 390 hp and 407 lb.-ft.
http://www.jdpower.com/cars/Dodge/Ram--2500/2009
"Powertrain
For 2009, Dodge Ram 2500s come with the next-generation 5.7-liter Hemi V-8 engine. Output is up from 345 hp and 375 lb.-ft. of torque to 355 hp at 5400 rpm and 395 lb.-ft of torque at 4200 rpm. It comes with a 5-speed automatic transmission."
https://www.nadaguides.com/Cars/2009/Do ... -4WD/Specs
https://www.thecarconnection.com/specif ... ower-wagon
Well hell, you learned me something, thanks coder!
