Stock 15 with 37s
israelstanage
Stock 15 with 37s
Post by israelstanage » Sun Oct 08, 2017 10:32 am
Joined the cool guy club and went with 37s this time. Went with the Mt instead of the RT as well. Slight trimming needed on plastic wheel well liner. These tires are super quiet for the level of tread aggression. Way more quiet than the worn out RTs anyway.
IIIOIISTER
Re: Stock 15 with 37s
Post by IIIOIISTER » Sun Oct 08, 2017 3:40 pm
Truck looks sharp! Did you Procal those 37" tires?
'17 Power Wagon
35" Yokohama Geolander G003
Carli
-King 2.5 Pintop
-3” coils
-Front diff cover
Thuren
-Rear track bar
-Rear sway bar links
-King steering damper
israelstanage
Post by israelstanage » Sun Oct 08, 2017 4:32 pm
I did. Started with the actual measurements then did some fine tuning with the GPS on the highway.
Post by Reloaderguy » Sun Oct 08, 2017 4:45 pm
All Toyo's are quiet when you first put them on. Those MT's sing once they have some miles on them. My RT's are decent for a big lug tire but after 15k miles I wouldn't call them quiet.
IIIOIISTER
Post by IIIOIISTER » Sun Oct 08, 2017 7:01 pm
Have a couple questions for ya as I've been considering upgrading the shoes for my 17' PW.
1. Did you notice any MPG drop after putting on those 37s?
2. Do those 37s rub when you lock out the steering wheel to either direction?
Thanks.
'17 Power Wagon
Carli
-King 2.5 Pintop
-3” coils
-Front diff cover
Thuren
-Rear track bar
Post by OffroadTreks » Sun Oct 08, 2017 8:12 pm
This was my experience too. Very quiet. Was surprised, then after about 500 miles, the got louder.
rkgzx9leftcoast
Post by rkgzx9leftcoast » Mon Oct 09, 2017 11:46 am
Truck Looks awesome!! I think Toyo M/t`s are the roundest big tires they make....Nice !!!
israelstanage
Post by israelstanage » Mon Oct 09, 2017 7:14 pm
1. Haven't noticed a drop in MPG but have only driven it a few hundred miles and I had 35s. Definitely a little less responsive with more rubber.
2. Slight rub on sway bar at full lock turning right. Didn't rub when full lock turning left.
israelstanage
Post by israelstanage » Wed Oct 18, 2017 3:45 pm
Ditch pics. Thuren springs up front might be in order.
Post by OffroadTreks » Wed Oct 18, 2017 6:34 pm
The won't make it flex any further. That's limited by the shock.
israelstanage
Post by israelstanage » Wed Oct 18, 2017 7:59 pm
Not looking for more flex. Want the extra inch and half lift up front.
Post by olyelr » Wed Oct 18, 2017 10:24 pm
Might as well at get his white body shocks while you are at it... for more travel.
