Post
by Powerwagonmark » Mon May 28, 2012 11:54 pm
I would definatly use square tube it's easier to work with and it's stronger than round tube. Use 1/4" wall on all the tubing. I made mine out of 1/4 but I made the mistake of making the step out 3/16ths wall and I dented it on a rock. I would put a step because it helps deflect your truck off of rocks adding more protection to the truck.You don't really need gussets on the side but definatly need the gussets on the top and I would make the 1/4 as well. I welded mine to my frame but that's up to you. Good luck on the build.
Here are some pics of my rock rail build
2008 Dodge POWER WAGON
