Cool little blurb about our winches on Warn's site!
RAM4ROKS
Post by RAM4ROKS » Fri Jan 13, 2017 11:12 am
Just a couple words but still cool:
https://www.warn.com/blog/2011/10/05/th ... inch.shtml
Limamikemike
Re: Cool little blurb about our winches on Warn's site!
Post by Limamikemike » Fri Jan 13, 2017 11:39 am
I always thought the winch was based on the m15000?
RAM4ROKS
Post by RAM4ROKS » Fri Jan 13, 2017 11:42 am
Limamikemike wrote:I always thought the winch was based on the m15000?
Yes! Notice the wording though:
Per Chrysler's specs, the Power Wagon winch features a 12,000 lb. capacity, similar to a WARN M12000.
So says Chrysler about capacity. (meaning construction (design basis of the winch) is not mentioned at all)
Per Chrysler's specs, the Power Wagon winch features a 12,000 lb. capacity, similar to a WARN M12000. But the Power Wagon winch's drum rotates the opposite direction, and a different control box that includes a low-voltage interrupt (LVI) that'll halt the winch if the vehicle's voltage drops. In addition, this winch comes loaded with 90' of 7/16" of wire rope vs. 125' of 3/8" line on a WARN M12000.
Obviously it is carefully written, it is very clever in that they never actually say what winch build it is based off. But, if you look at all the technical specifications, our winches are very clearly a reverse rotation variant of an M15000.
Post by Reloaderguy » Fri Jan 13, 2017 12:26 pm
My winch drum doesn't rotate in the opposite direction, the winch is turn around backwards.
jtcarlsen67
Post by jtcarlsen67 » Fri Jan 13, 2017 12:34 pm
Reloaderguy wrote:My winch drum doesn't rotate in the opposite direction, the winch is turn around backwards.
Just guessing but maybe that's why FCA asked for them to rotate the other way so that it could be mounted that way for fitment purposes?
2007 Dodge Nitro- Black
2017 Power Wagon- Blue Streak
Post by Reloaderguy » Fri Jan 13, 2017 12:38 pm
I think that was true on third gens. On fourth gens the winch is turned around and pulls from the top of the drum. If you take the winch out you can mount it in conventional winch bumpers. If the winch rotated backwards you would need to rewire the motor and replace the clutch assembly.
Post by RustyPW » Fri Jan 13, 2017 1:12 pm
All the replacement parts come from the M1500. The winch is a M1500 that Dodge lawyers derated to 12000 lbs for liability. :zombie:
Post by DamageWagon » Fri Jan 13, 2017 1:43 pm
"We'll tell them it's a 12,000 pounder, that way they won't try to yank any tree stumps or anything like that."
"Doesn't matter, Bill, some idiot is still gonna have his truck floating above the ground, winch line yanking on one side and an anchor strap on the other."
"Yeah but then he's over GVWR and we aren't liable."
RAM4ROKS
Post by RAM4ROKS » Fri Jan 13, 2017 3:48 pm
DamageWagon wrote:"We'll tell them it's a 12,000 pounder, that way they won't try to yank any tree stumps or anything like that."
Pretty much, LOL! :lol: :lol: :lol:
Post by adeluca73 » Fri Jan 13, 2017 6:22 pm
A few Good Men:
"asked & answered"
Seriously, this has been ball sack beaten back in 2012 time frame, the old timers here (Ace/Pit/Cactus etc) Covered this in extreme detail...look for the threads, it's eye watering detail.
RAM4ROKS
Post by RAM4ROKS » Fri Jan 13, 2017 6:25 pm
adeluca73 wrote:A few Good Men:
"asked & answered"
I know the winch's details have been beaten to death, LOL! It's just cool little blurb I came across while looking to buy a new cable since mine is a bit kinked.
Post by adeluca73 » Fri Jan 13, 2017 6:31 pm
"asked & answered"
Dude, I think you were one of the originals in those M12K/M15K discussions--& also Will with the stump dragging he does!!
RAM4ROKS
Post by RAM4ROKS » Fri Jan 13, 2017 9:36 pm
adeluca73 wrote:
"asked & answered"
LOL! I believe you are correct! :mrgreen:
Post by RustyPW » Fri Jan 13, 2017 11:04 pm
Funny thing is. This will come up again in a few years when the forum gets some new members.
RAM4ROKS
Post by RAM4ROKS » Sat Jan 14, 2017 12:59 am
RustyPW wrote:Funny thing is. This will come up again in a few years when the forum gets some new members.
TRUTH!!! Also, about eleventy billion times on facebook, LOL! :roll: :lol: :lol: :lol:
Post by 04Ram2500Hemi » Sun Jan 15, 2017 10:45 am
LOL- very true.
Question though, how long is the cable on our winch again?
:D
Post by olyelr » Sun Jan 15, 2017 11:17 am
424 feet.
AWST1230
Post by AWST1230 » Fri Feb 16, 2018 9:45 am
I'm going to resurrect this thread and then kill it for good.
The PW winch is a slightly modified M15000 mounted on a bracket rated for 12,000lbs. Hence the 12,000lb rating.
2016 Power Wagon SLT, 35"/12.5"/17" Toyo Open Country MT, 2 x Rigid 10" E-Series behind grille, 2 x Rigid Dually on Backrack, Smittybilt D-Ring on hitch, Uniden PRO520XL modded 25 watt CB w/300 watt 'Lil whip, and PA Horn speaker under hood, Mufflex 3.5" mandrel-bent Delete pipe, 84mm rocket launchers, Phased plasma rifle in the 40 watt range lasers and ejection seats coming soon!
Post by FordyceCreekTrail » Fri Feb 16, 2018 8:50 pm
What size tires will fit my truck again ?
Post by RustyPW » Fri Feb 16, 2018 9:57 pm
I'm I wrong?
AWST1230
Post by AWST1230 » Sat Feb 17, 2018 12:06 am
50"
