Best dual battery setup
Ducky's Dad
Re: Best dual battery setup
Post by Ducky's Dad » Wed Dec 21, 2016 12:00 pm
Also keep in mind that with a dual battery setup, if one battery dies it will take the other with it.
Not if they are properly isolated. On my truck I can physically remove the starting battery, put it on the curb, and still start and drive the truck on the house batteries. If the main battery takes a dump, I can just disconnect it and keep driving.
When you upgrade your wiring, don't forget to upgrade the ground cables. Also a good idea to add more ground cables for some redundancy.
Post by DamageWagon » Wed Dec 21, 2016 12:16 pm
I'm not talking about one battery running out of juice leading to the other one dying. I mean if one completely dies, and is attached in current with the other battery, they will both die. But if they are completely isolated during normal operation, you are correct the second battery will be fine.
Post by DamageWagon » Wed Dec 21, 2016 12:18 pm
Also, what are you referring to when you say adding ground cables? Do you mean from the battery to the frame, or from equipment to the frame? Or from equipment to the battery?
Post by Reloaderguy » Wed Dec 21, 2016 12:46 pm
DamageWagon wrote:His is my point. Your second battery isn't ever feeling a 600amp load. In fact, at that distance, I don't even think you have enough wire gauge at that distance to get enough wattage anyways. Let's be clear that your primary battery is feeling the load of the winch. Your secondary battery is feeling less than half of that load.
Let me also throw out there that before anyone starts throwing a bunch of money at buying big-amp equipment, you should first cut off those dinky battery terminals and put some legitimate mil-spec style connectors on there, with real battery life on the wire. This gives you the benefit of it being super easy to add additional wires off the battery in the future. Image
The reason I didn't move the winch with my current configuration is because I could potentially melt the cables. 4/0 cable triple the cost. The back battery probably won't feel the peak load but the cables will. I plan on upgrading the alternator and ground cables to 2/0, I have the cable and terminations, just need to find the time.
At any rate, I am running a BS 7622, I bought it for the automatic switching and voltage sensing features. It happens to be rated for 500A continuous (with 4/0 cables).
Post by TwinStick » Wed Dec 21, 2016 6:31 pm
DamageWagon wrote:Also, what are you referring to when you say adding ground cables? Do you mean from the battery to the frame, or from equipment to the frame? Or from equipment to the battery?
I have always had a parasitic drain on my truck since it was new. Dealer could not find it. When I had my aftermarket stereo put in my truck, they said i had a ground issue & I had to fix it before they would install. So, i took off all the factory grounds, wire wheeled the contact points till they were shiny, ground through the paint & primer, reattached them & sprayed with Fluid Film. Then, I added a bunch more. 2 Ga welding cable, soldered my own ends on. Battery to fender, battery to frame, L fender to frame, R fender to frame, bed to frame-both sides, cab to bed, cab to frame-both sides. I think it is now the most grounded truck in the history of trucks.
Still have the parasitic drain. :sick:
Ducky's Dad
Post by Ducky's Dad » Wed Dec 21, 2016 10:20 pm
Yes. See TwinStick's post above.
Ducky's Dad
Post by Ducky's Dad » Wed Dec 21, 2016 10:27 pm
My '05 is fully grounded and isolated, yada yada yada. Has all the symptoms of parasitic drain, i.e., primary battery drops OCV like tossing rocks in a pond. I have tested the drain and have had professionals test the drain, and it always comes in between 35 and 55 ma. Dealer Service Manager says that's right where my truck should be. The only theory anyone has come up with is that the aftermarket alarm system is pinging the body module intermittently and that is draining the battery. Maybe so, but I installed the alarm for a reason and I don't want to disconnect it. Alarm manufacturer says that's impossible. I dunno.
Post by DamageWagon » Wed Dec 21, 2016 10:43 pm
Right. I asked before he answered the question... lol
I ask because it is possible to add grounds the wrong way. The way he did it should have no downsides, other than effort and adding wires Image People screw up when they start wiring in things like lights, radios, speakers, etc. and they run a ground to the frame. Then they end up with 7 different powered grounds to the frame. This is a big cause of static in your radio. One of our fire engines had the Code 3 system wired to the frame, and every time we turned the lights on we couldn't hear the radio anymore hahaha. Guess how fast that got fixed...
Anyways, I feel like everybody is on the right track here. If you run a big blue sea ACR and big gauge wire between good batteries, so long as you hook things up logically you are generally going to come out happy and with a well running system. I think our host here just needs to decide exactly what he wants to do and should be good to go!
Post by TankerZak » Thu Dec 22, 2016 4:58 am
I see you guys are way into this discussion but I wanted to understand a bit more the use case.
I use a travel trailer with dual 6v deep cycle batteries in series for 12v 240 amp hours. I also have some nice zamp 120 watt solar panels that hook up pre-wired to the trailer and a remote start Champion 3500-4000 gas generator.
That being said i don't think i have a need for a second battery, unless I'm missing something?
I do believe i got 160 amp stock alternator. Its like the only upgrade i couldn't on my 16 PW Laramie with when and how i bought it. With all the knowledge here do you guys think with that setup i should be looking to grab the 380amp alternator upgrade? I think that might be my biggest electrical weakness. 380 amps would be nice for charging the house batteries on the trailer when we travel (i believe it charges through the pigtail?). And obviously i think the base alternator is under spec for the winch possibly also even with the truck running while winching in progress. Thoughts guys?
Post by olyelr » Thu Dec 22, 2016 6:30 am
The '16s come with the 220 amp alternator as base, with the option of dual alternators for a total of 380.
I think the 220 amp is probably plenty adequate for most peoples usage. With a lot of aftermarket electrical upgrades along with winching often, the dual upgrade would most likely be worthwhile. I believe it is pushing $700-$1000 to add it after the fact, though. Ticks me off, cause it is like a $300 option when ordering.
Post by TankerZak » Thu Dec 22, 2016 10:40 am
olyelr wrote:The '16s come with the 220 amp alternator as base, with the option of dual alternators for a total of 380.
Ugh, I'll check for the 220 then on my build sheet! Wouldn't be the first thing I'd learned and I'd be pretty comfortable with that I think.
Post by DamageWagon » Thu Dec 22, 2016 11:09 am
If nothing is broken, what's there to fix? Your trailer sounds pretty set up on its own. You are half correct on the pigtail supplying power to the trailer. Technically it can, that is what it is wired for, but the wire gauge from the front of the truck to the batteries in the trailer tends to be so small that there is so much resistance by the time you get to the trailer batteries it doesn't really charge them. Anyways, unless you have had problems I would find somewhere else to spend your money.... Kings baby
Post by olyelr » Thu Dec 22, 2016 11:15 am
TankerZak wrote: Ugh, I'll check for the 220 then on my build sheet! Wouldn't be the first thing I'd learned and I'd be pretty comfortable with that I think.
I almost didnt buy my truck because of the lack of dual alternators. Almost ordered one instead, which would have been the same as the truck as I have now (except with the dual alternators). Then the 8-10 week wait started going through my mind, and the fact that I really probably dont NEED the two alternators in the first place, I just wanted them cause it was an option. So I succumbed and bought the one I found a few states away. Still glad I did!
I figure if I ever get to the point where I am really regretting not having the two alternators, then I will just spend the bucks and install the second one.
Post by TankerZak » Thu Dec 22, 2016 4:38 pm
Thats exactly what happened to me except I would of had to order a truck that hadn't been fully released yet (2017). I didn't get the second alternator and i ended up with a few things i didn't want. Cargo camera, power adjustable pedals, cargo camera, keyless start n go, etc. But with ordering to get stuff i didn't want it would have cost me more money. Seemed silly and some stuff I've grown to like.
But if the default alternator is 220 amp then I'll just ignore it unless it becomes an issue. I'm more comfortable at 220 than 160 with the winch that's for sure.
Post by TankerZak » Fri Dec 23, 2016 7:06 am
How sure on we on the 220 AMP alternator and how could i check? My VIN decoder and build sheet all say 180 AMP...
Powerwagonmark
Post by Powerwagonmark » Fri Dec 23, 2016 10:55 am
Been wanting to do a dual setup for years. In the spring I will be doing one.
http://www.ironman4x4.com/category-prod ... ry-systems
http://www.4wheelparts.com/Electrical/D ... &t_pt=5250
2008 Dodge POWER WAGON
Post by olyelr » Fri Dec 23, 2016 11:25 am
Tanker, sorry but i may have given you a line bull crap! I think the standard on the pw is 180 amp, with the option for the 220 or duals for 380. If you dont see the 220 upgrade on your build sheet, then you probably dont have it :doh:
Post by TankerZak » Fri Dec 23, 2016 2:29 pm
Doh..
Post by DamageWagon » Fri Dec 23, 2016 2:34 pm
I wouldn't stress about things like that until you kill your battery doing something you do often. If you use your winch 30 times a year, then worry about it. If you've never used your winch, or use it rarely, or don't have 3 radios in your cab.... Don't worry about power until it realistically becomes a problem. Buying a good battery is the best measure to start with
Post by TankerZak » Fri Dec 23, 2016 6:24 pm
DamageWagon wrote:I wouldn't stress about things like that until you kill your battery doing something you do often. If you use your winch 30 times a year, then worry about it. If you've never used your winch, or use it rarely, or don't have 3 radios in your cab.... Don't worry about power until it realistically becomes a problem. Buying a good battery is the best measure to start with Image
These came with a bad battery? I think at 180 I'm comfortable until it presents an issue. 220 would have been better. I wonder how they get to the 380 AMP max. Is it a 180+ something? Might be cheaper to go to dual than rip and replace.
Post by TwinStick » Fri Dec 23, 2016 7:00 pm
The way i see it on the 2017's gassers : if you just have the single alt, it is 220 amps. If you get the dual alt option, the main one drops to 180 amps & the aux alt is 220 amps, for a total of 400 amps.
If you get the CTD: Single alt is 220 amp. Dual alt option is also 220 amp, for a total of 440 amps.
You can not get 440 amp dual alt's on a gasoline powered new Ram.
I did not see a need for dual batteries either, until i used the winch, for about 30 min or more. Truck was brand new, had to winch myself through 4-5' of snow & there was only 1 tree to use. It was almost a 90* angle. I could only go 1-2 turns of the drum, then had to disconnect, respool, rehook, 1-2 turns, repeat, over & over & over again, so i did not kink/crush my cable. Truck was running the whole time, battery light came on, lights went dim. I ended up shutting lights off, sitting in the truck, reving it up to 2-3000 rpms, for a while, then get out & do it some more. What a royal PITA that was.
Now I have dual batteries and a 270 amp alt.
IMHO, dual alt's & 440 amps should be standard on the Power Wagons. The winch alone, at full load, draws 440 amps.
:idea: :idea: :idea: :idea: :idea: Hmmmm, winch draws 440 amps.......dual 220 amp alt's = 440 amps.........seems like a no-brainer to me ! But what do I know, I just have a HSchool diploma. :lol: I am sure Ram has a reason to have inferior electrical systems on the 3rd Gens, & the 4th Gens. :lol:
Post by olyelr » Fri Dec 23, 2016 7:23 pm
Pretty sure the pw comes standard with 180 amp. The dual alternator option is 380 amps. I believe it is the 220 amp upgraded one with a 160 amp.
Post by TwinStick » Fri Dec 23, 2016 7:47 pm
So, then, the 180 amp is standard, there is a 220 amp option, and there is the dual 380 amp total which drops one down to 160 amp from 180 amp ? That just sounds wrong, so I am sure that's what RAM did ! LOL :lol:
Just like my old employer then. What ever made sense & was the right thing to do, they would do the exact opposite ! :lol: I am sure they didn't want to spend $10 more & just make it like the diesel, 440 amps total.
http://www.ramtrucks.com/hostc/bmo/CUT2 ... powertrain
Post by TankerZak » Fri Dec 23, 2016 8:16 pm
TwinStick wrote:So, then, the 180 amp is standard, there is a 220 amp option, and there is the dual 380 amp total which drops one down to 160 amp from 180 amp ? That just sounds wrong, so I am sure that's what RAM did ! LOL Image
Just like my old employer then. What ever made sense & was the right thing to do, they would do the exact opposite ! Image I am sure they didn't want to spend $10 more & just make it like the diesel, 440 amps total.
Yeah, that's what i was trying to figure it out. Is the stock 180 AMP a logical step with a bolt on for duals later in the 6.4 Power Wagon. Or am i ripping out the 180 for whatever makes up the dual alt solution for a lot more cash.
I mean that story really got to me. If i have a winch i better be able to use it. And if that takes dual alternators, or dual alternators, and dual batteries, and a new air box to make it all fit than so be it.
Post by olyelr » Fri Dec 23, 2016 8:59 pm
Problem is they dont have new air boxes out for the new trucks yet.
