Ticking on startup
Bakes
Ticking on startup
Post by Bakes » Fri Nov 18, 2016 10:22 am
Hey....so my 2013 PW with about 52K miles has been making a ticking noise for about 20-30 seconds on startup the past month. Valve slap?? It goes away after a short period. Anything I should be doing on this? My last Ram 1500 that also had the 5.7 had about 115K miles on it and never made this noise.
Thanks
Bakes
waldo
Model Year: 2019
Re: Ticking on startup
Post by waldo » Fri Nov 18, 2016 10:38 am
Is it just the normal "Hemi Tick" or worse? Might be a bad drain back flapper in the oil filter.
2007 and 2019 Power Wagons
Post by Will » Fri Nov 18, 2016 10:51 am
Change the oil. Mine had a tick when the dealer was changing the oil, now I do it myself with Mobile and a Mopar filter and it's quiet as can be.
ggbull
Post by ggbull » Fri Nov 18, 2016 2:01 pm
Exhaust manifold bolts broken. Happened to me with 65000kms
Bakes
Post by Bakes » Fri Nov 18, 2016 3:47 pm
Thanks for the replies.....The ticking is RPM related and goes away completely after 20 seconds or so.
I will try replacing the oil filter....but would that be RPM related?
Chromolykid
Post by Chromolykid » Fri Nov 18, 2016 4:07 pm
I've heard several cases of the exhaust manifold stud breaking... Rusted out from dripping moisture off the condenser if I'm not mistaken. Has anyone figured out or heard of a way to prevent it? I've considered trying anti-seize on the stud but it probably won't last long.
“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
Dethloff Swaybar Spacers
AEV Procal
Post by olyelr » Fri Nov 18, 2016 9:06 pm
Chromolykid wrote:I've heard several cases of the exhaust manifold stud breaking... Rusted out from dripping moisture off the condenser if I'm not mistaken. Has anyone figured out or heard of a way to prevent it? I've considered trying anti-seize on the stud but it probably won't last long.
FLUID FILM!
Post by RustyPW » Fri Nov 18, 2016 9:30 pm
FLUID FILM!
:rofl:
Post by DamageWagon » Fri Nov 18, 2016 10:05 pm
FLUID FILM!
Oh dear.
