BFG KO2 Thoughts
14PowerWaggy
Re: BFG KO2 Thoughts
Post by 14PowerWaggy » Thu Sep 08, 2016 1:09 pm
pdavey wrote:My Nitto Trail Grapplers 35x12.5x17 lasted me 50,000 miles. Yes, 50K. Go with those. You get a great ride and great value.
Dang... I'm impressed... I've got about 14K on my 37x12.5 Nitto Trail Grapplers and I'd be surprised if I get another 14K out of them... Not wearing evenly at all and I keep em rotated every 4K... Not bad riding tires though...
shacke
Post by shacke » Thu Sep 08, 2016 1:22 pm
Unrelated to this post but what part of GA are you in shacke? I'm in Lilburn and rarely see any other wagons around...
In the Canton/Woodstock area up 575. I have seen two (2) other PWs in this area, but they are certainly rare.
Regards,
2016 Laramie PW: Delmonico Red with packages 22J, ESA, DFP, PRV, APA, *VL, -X9, GFA, ADC, XMF, XBM, XAM, RA4, LPL
Completed Mods: Factor55 Winch Hook (Red), OptiCoat Pro Plus, Decked Drawer System, ARE MX OTR Topper, AEV front and rear diff covers, Magnaflow 19200, EBC Extra Duty rotors and brake pads, DeeZee tailgate assist
What's Next: Suspension, AEV Prefilter
Boomerttl
Post by Boomerttl » Thu Sep 08, 2016 2:34 pm
Sure is a lot of centerline flash on those new bfg's :roll:
First wagon 05 bright white,my second wagon 15 Laramie granite crystal
Sweet5ltr
Post by Sweet5ltr » Thu Sep 08, 2016 2:38 pm
Love my K02's!
I started a thread here not too long ago, about a slickdeal' I found at Sears that had an entire 35x12.5r17 set installed on my wagon' for $980 with an additional $100 cash back. Granted, I purchased this truck with 3,000 miles on it and the original owner tossed the Duratracs for KO's ( :angry: ), so I can't really compare the factory tires to these. Honestly, these KO2's excel in practically every condition I use the truck in, but the original KO's were absolutely terrible (IMHO) if that says anything. 35's seem to be the perfect 'all around' size for this generation PW, and the load rating still matches the trucks towing capabilities, so its a win-win all around. Very little road noise as well, which was another plus with the K02's.
37's and some :cash: to Thuren when the warranty expires :patriot:
Redman1973
Post by Redman1973 » Fri Sep 09, 2016 9:59 am
That is surprisingly low mileage. I have had two sets of the Nitro mud grapplers. Started out with roughly 15k miles on OX when I bought her and within 5k miles of owning her I put on my first set of mud grapplers. I just turned 97k miles, and recently gave my second set to my daughter with roughly half of the tread left. I would not have thought the mud grapplers would get better mileage than the trail grapplers... Dang.
I never go over 65 mph, so I wonder if high speeds affect wear that much?
Sent from my KYOCERA-E6560 using Tapatalk
Power Wagon Registry #47
- Thuren steering upgrade
- Snorkel
"The" Wifes Car
"Liam" 2019 Power Wagon
My Toy
"VISCO K" 2019 224 Blackjack
hammer40
Post by hammer40 » Fri Sep 09, 2016 11:31 am
Sweet5ltr wrote:Love my K02's!
I took advantage of that same deal, thanks again!
bdk
BFG KO2 Thoughts
Post by bdk » Fri Sep 09, 2016 8:39 pm
Aired down my tires to 48 psi last night but they look a little low and the stupid low pressure light is on so I think I'm gonna take them back up a few pounds. At 48 psi they measures a little over 33 1/2 which is a little disappointing but it's probably for the best, i did it mostly because the 285's just looked too small and I'm really pleased with the look of the 315's. Towing performance shouldn't be affected much and I still think it will give me a better 70-75 mph cruise rpm, which was the other goal. The tires ride really nice and are very quiet so overall I'm very pleased with my purchase. I'll try to update this thread as I put miles on the tires and encounter different environments
GeorgeofGeorgia
Post by GeorgeofGeorgia » Tue Aug 08, 2017 1:41 pm
bdk wrote:Aired down my tires to 48 psi last night but they look a little low and the stupid low pressure light is on so I think I'm gonna take them back up a few pounds. At 48 psi they measures a little over 33 1/2 which is a little disappointing but it's probably for the best, i did it mostly because the 285's just looked too small and I'm really pleased with the look of the 315's. Towing performance shouldn't be affected much and I still think it will give me a better 70-75 mph cruise rpm, which was the other goal. The tires ride really nice and are very quiet so overall I'm very pleased with my purchase. I'll try to update this thread as I put miles on the tires and encounter different environments
Do you still have those tires on?
Are you still happy with them?
I'm thinking of getting a set myself.
Post by nts007 » Tue Aug 08, 2017 11:53 pm
I have trail grapplers on right now. Do not like them. Half worn at 25k km. Rotated every 5k km. Horribly squishy compared to pretty much every other tire I've used in the last 6 sets. Air them up a bit and it goes rock hard and twitchy. They do not tow well. They are only ok on gravel and ok in mud. I would never buy them again. If I didn't get them for half price I would never have done them. The cooper st maxx is way better all round. The hankook dynapro mt is far better in mud. Neither of those two chipped out this bad on gravel and both lasted 70k+ km with tread left.
Also the trail grapplers have a horrible left radial pull and it doesn't matter which tire is where. First tire I've had that pulls like this.
FordyceCreekTrail
Post by FordyceCreekTrail » Wed Aug 09, 2017 9:44 am
Nitto Trail Grapplers were the cheap tire that came on my wifes 15 4 Runner. They are ok, far better then many other stock tires. But not a stand out. BFG is far better
Post by olyelr » Wed Aug 09, 2017 5:03 pm
FordyceCreekTrail wrote:Nitto Trail Grapplers were the cheap tire that came on my wifes 15 4 Runner.
Wha? You buy it used then? Toyota doesnt even put an A/T tire on there off road packaged small vehicles anymore, let alone an M/T.
Explorin Sonoran
Post by Explorin Sonoran » Wed Aug 09, 2017 5:07 pm
I've had mine for a week and they are way quieter than the Duratracs. Seem to do fine off road, already loaded them up with mud (unintentionally).
No me gusta el barro
2016 Power Wagon Tradesman Granite Crystal Metallic
FordyceCreekTrail
Post by FordyceCreekTrail » Wed Aug 09, 2017 6:31 pm
Its the TRD Pro. The only one that gets you a tire for anything more then the mall.
Post by olyelr » Wed Aug 09, 2017 6:35 pm
Yeah, I thought those new ones come with some lame passenger type tire. Definitely not Nitto Trail Grapplers.
