Sounds pretty reasonable to mecoder wrote:If you are under warranty everything is covered. If not, they will charge you 1 hour labor for diagnostic time then deduct that from the cost if you have them do the work. I have paid them to diagnose something before then fix it myself for a lot less, depending on the situation.LagunaH1 wrote:I heard recently that many manufacturers don't pay the dealership techs for diagnostics time. -If thats the case with RAM, then I can see how the dealership in some cases will want to have their time covered one way or the other when spending time diagnosing
Engine Trouble
Re: Engine Trouble
2016 RAM 2500 Power Wagon SLT
NR6E
NR6E
Re: Engine Trouble
I don't specifically know how Fiat Chrysler does it, but having worked for Nissan many years I can say the tech gets shafted on warranty work every time. When corporate is footing the bill the work is billed at a very reduced rate and diagnostic time is usually not paid to the tech. Warranty jobs typically pay around 1/3 what the same job would pay if a customer was covering the bill. Everyone in the shop avoids warranty work if they can lol.
Re: Engine Trouble
Good luck with the new long block. I'm sure you'll get many more reliable miles out of the truck and you won't be adding oil between changes.
Mod's:
305/70/17 Toyo AT2 tires
Weathertech Floorliners
TSC Toolbox
Carli Diff Guard
Mod's:
TSC Toolbox
Carli Diff Guard
Re: Engine Trouble
I found out more information regarding the engine failure. It dropped a valve seat on the #5 piston, after a warm startup while previously running normally apparently is not uncommon in 2003-2008 5.7 Hemi's. Once the seat drops down the cylinder it breaks into pieces and cause piston/cylinder damage and loss of compression. Some guys try to hone the cylinder and replace the heads and bad piston. Youtube has several videos on this.
