Wheel hop, axle wrap...
Re: Wheel hop, axle wrap...
Pretty much any vehicle that I have ever owned could be made to go into a traction slip hop resonance with the right combination of conditions - predominantly driven by traction and power output. In the two years with my 2014, I have only experienced serious hop once - and cleared the resonant condition by flooring it because it would have been unsafe to stop at the time. Most of the time we can let off the gas a little, regain traction, and continue on without losing much momentum. So my solution won't be to change the truck - but to learn how prevent it or quickly adjust and drive through it. I'm not gong to obsess about the hop - and certainly won't throw any money at it
This issue has been around long as I can remember. Anyone here ever do a hole shot with a '70's mid size cheby with a coil spring end rear? You're lucky to keep your teeth in your mouth. Everything is a compromise in ride, handling, traction, braking, load capacity, etc.
All I know is my Power Wagon is a bad son of a bitch hahaha
Bill2014 wrote:Pretty much any vehicle that I have ever owned could be made to go into a traction slip hop resonance with the right combination of conditions - predominantly driven by traction and power output. In the two years with my 2014, I have only experienced serious hop once - and cleared the resonant condition by flooring it because it would have been unsafe to stop at the time. Most of the time we can let off the gas a little, regain traction, and continue on without losing much momentum. So my solution won't be to change the truck - but to learn how prevent it or quickly adjust and drive through it. I'm not gong to obsess about the hop - and certainly won't throw any money at it
X3RustyPW wrote:This issue has been around long as I can remember. Anyone here ever do a hole shot with a '70's mid size cheby with a coil spring end rear? You're lucky to keep your teeth in your mouth. Everything is a compromise in ride, handling, traction, braking, load capacity, etc.
Have you ever seen the wheel hop on a 3 axle concrete mixer trying to back up a dirt incline. I've seen a few over zealous drivers snap an axle or two, lose a driveshaft or blow the differential.
Was at the dealership looking around today and spied...
- dodgeman324
Ooo, it's so pretty and clean. I wish I could get my undersides that clean again. But, what are you spying? The bilstein looking shock at the top of the diff? Do those things actually help?
Former Vehicles:
1998 Dodge Ram Quad Cab
Former Vehicles:
Yes, that shock, that's a regular cab 2500 6.4 tradesman, had a utility bed but the guy says they order them bed delete and them put the bed on.
Is that diff breather just dangling in the air.
Looks like it's clipped to the bracket
PWRider wrote:Is that diff breather just dangling in the air.
The problem is the bracket sucks. I've already had mine come off of it twice before I zip tied it.Will wrote:Looks like it's clipped to the bracket
Your ol girl is down for the count because you pounded on her too hard and then you go out and start looking for love in other places
olyelr wrote:Your ol girl is down for the count because you pounded on her too hard and then you go out and start looking for love in other places
I'm looking at all options...RustyPW wrote:olyelr wrote:Your ol girl is down for the count because you pounded on her too hard and then you go out and start looking for love in other places
So you're running around looking up skirts lol
Sorry to dredge up old thread but I see people have tripled up the Bilstein anti-hop shock. Has anyone tried replacing it with a single, equivalent travel 3.0 or 2.5 Fox or King shock?
Never heard of it but you certainly could.
Figuring out the valving could be tricky. It sounds promising.
King and Fox have dynamometers in their shops to test existing valving. They could test the factory shock and provide a stiffer valving profile. Or you could just go straight to a .020" stack and see how it does.FirerescuePW wrote:Figuring out the valving could be tricky. It sounds promising.
Or add 2 more to the existing like me...DamageWagon wrote:King and Fox have dynamometers in their shops to test existing valving. They could test the factory shock and provide a stiffer valving profile. Or you could just go straight to a .020" stack and see how it does.FirerescuePW wrote:Figuring out the valving could be tricky. It sounds promising.
Or just let a little air out of your tires.
Way easier too...Reloaderguy wrote:Or just let a little air out of your tires.
