3rd Gen removing 6" lift and leveling ?'s
Re: 3rd Gen removing 6" lift and leveling ?'s
Post by RustyPW » Sun Apr 24, 2016 9:19 pm
Before you swap out the control arms, springs, track bar bracket, and pitman arm. Check the bump stops, the sway bar brackets, or links, and brake lines. That stuff may have been changed too.
adamdh1
Post by adamdh1 » Mon Apr 25, 2016 2:22 pm
Thanks. I took a look and I will need to swap out bump stop extensions and sway bar links. There's brake line extenders so that shouldn't be too bad.
whitey
Post by whitey » Tue Apr 26, 2016 7:43 am
I just threw my original parts in a shed when I got my lift. I can see what's in the box. I am sure it will have a majority of what you are looking for.
adamdh1
Post by adamdh1 » Tue Apr 26, 2016 3:25 pm
That would be awesome whitey.
whitey
Post by whitey » Tue Apr 26, 2016 9:20 pm
Looks like I have the upper and lower control arms, front and rear springs, Maybe all of the hardware (not sure), sway bar end links. I have the original track bar but I think its bushings are loose. I'm not sure if the pitman arm is in the boxes somewhere but I can check tomorrow. Honestly I have destroyed so many steering parts I'm not sure what I will find for steering.
Keep in mind that I was wheeling my truck a few days after I got it and wheeled it often. So I can't say the bushings are great but I don't recall any looseness from the control arms or rear springs before I got my lift. My truck is an 06 quad cab by the way. Let me know if you want pics. And how you want to get your hands on the parts.
whitey
Post by whitey » Tue Apr 26, 2016 9:38 pm
Post by olyelr » Wed Apr 27, 2016 12:22 am
Boom. See thats what Im talking about.
Way to help a brother out, whitey!
adamdh1
Post by adamdh1 » Wed Apr 27, 2016 9:10 am
Thanks whitey. PM sent. I'm interested in everything except the rear springs. I think Fastenal might be the easiest and cheapest if there is one near you.
adamdh1
Post by adamdh1 » Thu Apr 28, 2016 10:29 pm
So I am swapping some suspension components in a couple weeks with a stock ram 2500/5.7 and haven't completely locked down coils. Are there some replacement coils out there to buy that will get me to stock PW height?
Post by Colibri » Thu Apr 28, 2016 11:33 pm
I haven't forgotten about you Adam! It's been a hectic week here, I'm sorry for the delay. I'll get you some pics and a shipping quote tomorrow though!
adamdh1
Post by adamdh1 » Fri Apr 29, 2016 11:32 am
Okay, thanks Colibri. Whitey is looking into shipping as well. I did find someone over on DT that would ship them, but it's a bit expensive.
Post by Colibri » Fri Apr 29, 2016 3:58 pm
Got them out of storage today and brought by ups for a quote, looks like around $80 bucks to your zip code.
adamdh1
Post by adamdh1 » Sun May 01, 2016 11:43 pm
Colibri, PM sent
Post by Colibri » Mon May 02, 2016 12:03 am
Gotcha! I have a set of daystar leveling spacers for the front, if you want them I'll throw em in the box for free?
Post by Colibri » Thu May 05, 2016 8:37 am
And found the stock swaybar end links as requested
adamdh1
Post by adamdh1 » Thu May 05, 2016 4:28 pm
Colibri,
I believe I have some coils and links on the way from Whitey. If that doesn't work out, I will let you know.
Post by Colibri » Thu May 05, 2016 4:31 pm
Cool, good luck getting her squared away!
whitey
Post by whitey » Fri May 06, 2016 12:47 am
springs and sway bar end links where already sent by me yesterday - 5/4/16 through Fastenal.
adamdh1
Post by adamdh1 » Mon May 09, 2016 2:22 pm
Confirmed they are on the way and should be here this week. Thanks again whitey!
