EDIT: I have joined the ranks!
Ducky's Dad
Re: Hopefully joining the ranks, opinions please!
Post by Ducky's Dad » Tue Oct 20, 2015 1:10 pm
Start looking for a set of H2 wheels.
Post by olyelr » Tue Oct 20, 2015 1:59 pm
Ducky's Dad wrote:
its first test will be a 1600 mile road trip home...which by the looks of those tires, will be noisy.
Tires look like Goodrich A/Ts, actually very quiet.
They are the BFG KM2 mud terrains. Look to be the 285/70/17's.
I have them on my Jeep in a 35. They are actually quite quiet and smooth on the road.
Ducky's Dad
Post by Ducky's Dad » Tue Oct 20, 2015 2:29 pm
I need a better screen or new glasses. Probably both.
RamGentry
Post by RamGentry » Tue Oct 20, 2015 2:47 pm
Pit Slave wrote:I'd still ask what they did with the factory PW wheels. See if they can give them with the truck, they were not cheap from the dealership when you could still get them before.
Good call, I'll def ask that.
Ducky's Dad
Post by Ducky's Dad » Tue Oct 20, 2015 3:07 pm
There is a set of 2015 PW wheels for sale here in the Classifieds.
Mike-H
Post by Mike-H » Wed Oct 21, 2015 12:16 pm
BP does move the bumpers back for the transport boxes. It'll be easy to tell if the bed has marks from the insert and extra holes for the A/C lines to run to it. Must trucks dont have cut lights, that's a station/assigned vehicle thing. Wheels and tires get swapped on government vehicles all the time as you swap through spares. Or someone swapped them with another vehicle, that alone means nothing. You should see some shadowing if it's had grafics on it. Some trucks are brought in without grafics for specific uses. But I'd imagine in the right light you can see at least where there are no scratches where the grafics were. The bumper spacing and lack of rear seats are common to BP though. But their vehicles usually go back to Texas to be auctioned. Take pics of any witness marks from equipment and if you see any other marks on the truck. Might be able to tell you more after the pics. Where are you picking it up at?
BP, BLM and PCSO all use or have used PWs all could have had rough lives. But depending on the area they came from some fair a lot better then others. He fact the extended rear bumper isn't twisted might mean this one had an easier life. PCSO generally swap to Aluminess bumpers for their search and rescue trucks, but they could swap them with replacement and keep the aftermarket stuff. If the bumpers are new but the rest is scratched that could point you that way. Looking at the bottom of the truck will tell you fairly quickly what kind of life it had. Check the front axle closely. Look for leaks around the tube/ diff junctions. Those get bent and start leaking. Also see if it still has its bumpstops. If not, I'd expect front end damage from hard usage. As soon as the bumpstops go, the front axle is not far behind.
RamGentry
Post by RamGentry » Wed Oct 21, 2015 7:58 pm
Good information. The truck is in phoenix/apache junction AZ. I will absolutely look under the truck and check the diffs, bump stops, and skid plates. My dad decided he wants to make the trip with me so im taking him along for a litttle road trip. He has a great eye for paint work and should be able to pick the body apart pretty quickly.
Mr.Smith
Post by Mr.Smith » Wed Oct 28, 2015 1:27 am
Definitely get the stock wheels & congratulations...cheap enough to build it up right.
RamGentry
UPDATE
Post by RamGentry » Wed Oct 28, 2015 11:12 am
This past Thurs my pops and I took a 1 way flight down to AZ to check out the truck. Out on the test drive I was a happy man, the truck was tight, bumpstops in good condition, skid plates weren't beat up, and everything worked! Then I started picking apart the body and slowly became more disappointed. Couple of holes in the bed from mounting brackets, cracked taillight, dented bumper, no back seat and shot front seats, and the paint was pretty rough. This gave me some ammo though and its all stuff I know I can fix up. Long story short, after 7 hours of negotiation and a call to the cab company to drive us back t the airport, I purchased the truck for $14,100. I think that should leave me with enough room to fix it all up and come out ahead. It made the road trip from AZ to MN ~1,650 miles in 28 hours with no hiccups! Looking forward to giving this truck a great life :cheers: Already started to put some parts together :cash:
-wireless winch controller
-new stock replacement cab (clearance) lights
-new tailights
Looking for a replacement interior and tailgate now, if anyone has suggestions or any for sale please let me know. I have been scouring the internet looking for a deal and have found limited options.
Obviously you guys want PICS:
potato quality pic of the old man and my first PW flex
https://www.dropbox.com/s/5huq5bg4q9wmp ... 9.jpg?dl=0
https://www.dropbox.com/s/2hpjxt9h69lh8 ... 3.jpg?dl=0
SheepdogOutdoorsman
Re: EDIT: I have joined the ranks!
Post by SheepdogOutdoorsman » Wed Oct 28, 2015 11:39 am
Nice truck! Glad to have you among the herd!
leo72987
Post by leo72987 » Wed Oct 28, 2015 11:46 am
Nice glad to hear it worked out!! That is a pretty damn good deal I must say! Especially with all the equipment working!
Post by olyelr » Wed Oct 28, 2015 12:13 pm
Heck yeah!
If you are not after a meticulously clean truck that you never plan to wheel or use hard, then I think you made out like a bandit.
The paint looks nice and shiny in that one pic. Plenty good enough for a workhorse!
RamGentry
Post by RamGentry » Wed Oct 28, 2015 12:21 pm
Ducky's Dad wrote:Start looking for a set of H2 wheels.
Do I have to modify the center hole for the 4th gen rams too? I actually found a set for cheap and am seeing lots of info for 3rd gen but not as much on 4th gens.
Post by Colibri » Wed Oct 28, 2015 3:13 pm
Congratulations! :rockon:
vanished
Post by vanished » Wed Oct 28, 2015 4:37 pm
Awesome! My first wagon was BEAT when I picked it up cheap... I put some lipstick on the pig, beat it hard and put it away wet! Was almost more fun than my 2nd cherry wagon... ;)
loveracing1988
Post by loveracing1988 » Wed Oct 28, 2015 5:05 pm
Both the 3rd and 4th gen rams share the same hub diameter, I have 2005 power wagon wheels on my 2014 2500.
gtomike60
Post by gtomike60 » Wed Oct 28, 2015 8:59 pm
Great buy.Congrats.
A few dings and scratches in the paint mean you wont have to worry about it when you go wheeling.
2012
azracer
Post by azracer » Wed Oct 28, 2015 9:08 pm
Sweet!
Love it when folks get a deal on their dreams!
RamGentry
Post by RamGentry » Wed Oct 28, 2015 9:37 pm
Good to know, thanks for the reply. Think I will go for the H2 rims. I like the look and they seem pretty easy to modify...and they are cheap!
RamGentry
Post by RamGentry » Wed Oct 28, 2015 9:40 pm
gtomike60, Exactly! Thanks!
azracer, thanks for the welcome, ive been looking for a deal on one of these for years!
Mr.Smith
Post by Mr.Smith » Thu Oct 29, 2015 2:06 am
Sweet! Sounds like this will be an awesome rig, well done Sir!
PWRider
Post by PWRider » Thu Oct 29, 2015 12:15 pm
I have former BLM rig. Put almost 30k since bought. Few minor cosmetic issues but not a single mechanical problem. Except breaking front axle. But that was self inflicted. Well front prob shaft u-joints were gave out too but that is not unheard of for sure.
Mike-H
Post by Mike-H » Fri Oct 30, 2015 10:25 am
Truck looks great. Glad it worked out for you. Were you able to see any ghosting from the previous graphics? Or any other clues we might recognize to figure out what agency it came from?
Check eBay for seats. A friend at work likes to buy auctioned ex-government vehicles. He finds some of his missing seats there. There's always junkyards and LKQ.com which is salvage parts online.
RamGentry
UPDATE
Post by RamGentry » Fri Oct 30, 2015 12:12 pm
Mike-H wrote:Truck looks great. Glad it worked out for you. Were you able to see any ghosting from the previous graphics? Or any other clues we might recognize to figure out what agency it came from?
Yea there is some ghosting, it did come from border patrol. My dad and I are pretty good with paint stuff and he has already started to correct some of the paint. I think i'll be able to restore it so you dont see any ghosting...otherwise i'll just vinyl wrap the pig.
I've been scouring ebay and local CL and there is some interior parts available but the prices are ridiculous. Right before a bought the truck there was a complete set up for $650 in good condition and after i bought it they were gone. Can't seem to find anything else decent under $1,000! I have found decent seats looking at out of state CL but noone wants to ship, same story with the tailgate.
Overall i'm pretty happy with the progress. I'll post up some pics tonight showing all the extra crap i've been ripping out of the rig...over a hundred lbs. shed already :doh:
Also, I picked up some CL H2 wheels for $225 and hoping to pull the trigger on some 35" KO2's sometime soon but I need to put money into the interior and tailgate first.
Post by Low_Sky » Fri Oct 30, 2015 2:05 pm
This may sound crazy, and I don't know your situation so this may not work for you, but do you even need a back seat? For the many years I owned my Silverado I hauled passengers maybe a handful of times. The other 99% of the time I had the back seat folded up, using the rear of the cab for storage and dogs transport. A crew cab without back seats could make for a pretty awesome flat-floor storage area. If I was still single and had a truck that was already kind of a beater, I would seriously consider it.
