Thuren front coils
stubiePW
Thuren front coils
Post by stubiePW » Tue Oct 27, 2015 5:32 pm
I've been reading and do not want to beat a dead horse, but I want to bring up the front end a bit (no spacers). I don't have the $$ for shocks just yet. I was thinking 3" coils from Thuren. Or should I just go with the 2"?
Like I said, I know it's been covered. I have a 2012 stock minus the thuren control arms. I am hoping to keep the rub on the sway bar down a bit more.
Thanks guys
2011RPW
Thuren front coils
Post by 2011RPW » Wed Oct 28, 2015 12:07 am
2" coils will should level you out (I'm not 100% on this, I've never seen a Hemi/PW with the 2" coils), 3" will require shackles in the back.
I put 3" coils on mine, and I've got the shackles out back, as well, on highest setting. Well worth the money!
Keep in mind, an adjustable track bar is also a must-do, as well.
2011
stubiePW
Re: Thuren front coils
Post by stubiePW » Wed Oct 28, 2015 7:48 am
Did you replace the shocks? Just curious. I guess I need to save up some money and make that happen!
leo72987
Post by leo72987 » Wed Oct 28, 2015 10:08 am
First things first 2011RPW sexy truck!! As to the 2 inch Thuren coils see below with the estimated lift heights I got these numbers from Don and cjc offroad.
-2.5" of lift on 3rd gen Hemis
-2.5" of lift on 2nd gen diesels
-3" lift on 2nd gen gas
-2" of lift on 3rd gen diesels
http://www.cjcoffroad.com/Thuren-2-Soft ... p/tf2c.htm
With that being said I have no info on 4th gen's just that they are heavier... Carli 3 inch and thuren 2 inch coils apparently give power wagons about an inch lift over stock on average as the argument has been that Wagons come with roughly a 2inch lift from Factory with a 1/2 lift from bigger 33 inch tires.. At least this was the rule of thumb with us 3rd gen guys... The Thuren 3 inch coils would give you about 4 inches of lift making a new track bar mandatory. You could probably stick with stock shocks if you used the 2 inch coils. Anything bigger and your shocks will act like limiting straps LOL.
Post by 2wagons1driveway » Wed Oct 28, 2015 11:22 am
Agreed 3" Thuren coils and you should run a new track bar. 3.5-3.75" of lift on a fourth gen truck depending on bumper weight.
Sent from Canada
Kenadian
Post by Kenadian » Fri Oct 30, 2015 6:54 pm
I'm running the Thuren 3" coils adjustable track bar rear shackles boogie bumps and overland shocks annnnd the high clearance control arms. Fit 37" tires with ease. And a heavy ass bumper. Sits pretty good I am on mid height on my shackles
I like to break things !!!
2011TXPowerWagon
Post by 2011TXPowerWagon » Sun Nov 01, 2015 12:55 pm
Kenadian wrote:I'm running the Thuren 3" coils adjustable track bar rear shackles boogie bumps and overland shocks annnnd the high clearance control arms.
That is the exact setup I am planning, well minus the boogies. If buying in stages would you recommend the arms first?
AllanDickerson
Post by AllanDickerson » Sun Nov 01, 2015 1:55 pm
I know this is a 4th gen thread but I just put 3 inch coils and track bar on my 05 and I'm sitting about a 3/8 above level.
Kenadian
Post by Kenadian » Tue Nov 10, 2015 8:56 pm
Yes arms first. Then you can run the 37" at stock height then add as you go. To get more clearance and better ride.
Kenadian
Post by Kenadian » Tue Nov 10, 2015 8:57 pm
That's what I did with mine
2011RPW
Post by 2011RPW » Tue Nov 10, 2015 10:12 pm
AllanDickerson wrote:I know this is a 4th gen thread but I just put 3 inch coils and track bar on my 05 and I'm sitting about a 3/8 above level.
Measuring from Bumpstops? Or fenders? Fender measurements aren't accurate, or so I've been told.
2011
AllanDickerson
Post by AllanDickerson » Tue Nov 10, 2015 10:21 pm
From the fenders. That's where I see the difference so I measured there
Post by olyelr » Tue Nov 10, 2015 10:42 pm
Yeah fender measurements are not always the best place to measure from, but they are a good start.
I have always figured a truck looks "level" if the lower portion of the body between the front and rear tires is at a level plane, or just a touch lower in the front. My jeep is setup this way and the front fenders are an inch higher than the backs. But it looks level.
AllanDickerson
Post by AllanDickerson » Wed Nov 11, 2015 4:31 pm
I'll have to try that and see where I'm at.
AllanDickerson
Post by AllanDickerson » Fri Nov 20, 2015 5:40 pm
I measured the lower portion of the body. I'm about 3/8 high in the front with thuren 3 inch coils on my 3rd gen with a stock bumper. It still tows great, I towed a boat yesterday on a double axle trailer weighing about 7000 pounds.
