Winch wire hitting bumper
drew165
Post by drew165 » Thu Sep 24, 2015 9:52 pm
The power wagon winches factory are inside the bumper. Is there anything I can do so when I use the winch that it doesn't drag on the bumper ? Like a fare lead attached to the outside of the bumper?
Stickman
Re: Winch wire hitting bumper
Post by Stickman » Fri Sep 25, 2015 12:31 am
Didn't you already ask this? And we said don't pull on extreme angles and it won't happen?
leo72987
Post by leo72987 » Fri Sep 25, 2015 8:39 am
Honestly they have been using this design for ten years without issues lol. The winch is not designed to be operated at such a steep angle were you're hitting the bumper... However there are indeed options for you. First option buy a good set of recovery gear with snatch blocks which will allow you to change your winch angles... Another is to replace your entire front bumper with a winch bumper however they are heavy and bulky looking and I honestly don't think it' worth it. The only one that i'm aware of that is light a good looking is the one below.
http://www.aluminess.com/dodge/dodge-po ... nt-bumper/
This bumper designed for power wagons meaning it uses the factory winch mount. You would have to call to see if they have a model for your model year but once again a cheaper route would be to just buy some some gear. Me personally I wouldn't go bolting on a hawse fairlead to the front of your bumper... It screams warranty void lol.
drew165
Post by drew165 » Fri Sep 25, 2015 9:42 am
Stickman wrote:Didn't you already ask this? And we said don't pull on extreme angles and it won't happen?
I did but didn't come up with a solution yet, my bad
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Fri Sep 25, 2015 1:13 pm
I think it was determined to be a non-issue. Just pick up the appropriate recovery gear and you shouldn't run into the problem you've mentioned.
drew165
Post by drew165 » Fri Sep 25, 2015 5:24 pm
Ok thanks guys.
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Fri Sep 25, 2015 6:12 pm
drew165 wrote:Ok thanks guys.
You could always do what I did, but it's an expensive option. Recovery gear is your least expensive bet, but even I have the same recovery gear.
drew165
Post by drew165 » Fri Sep 25, 2015 8:20 pm
How much was that bumper? That's nice!!!
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Fri Sep 25, 2015 8:27 pm
That was one of my first mods ... The factory bumpers are too weak for the rocky terrain here in AZ. I think I paid around $2,250 for it. I have Trailready bumpers front and rear ... With the Whiteknuckle Rock Sliders, I'm pretty well armored now ...
Post by RustyPW » Fri Sep 25, 2015 9:43 pm
How strong is that rear Trailready bumper?
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Fri Sep 25, 2015 11:03 pm
RustyPW wrote:How strong is that rear Trailready bumper?
It's pretty solid. The specs are on their website. I'm very happy with the setup.
http://www.trailready.com/bumpers/02_ram.html
drew165
Post by drew165 » Sat Sep 26, 2015 1:53 am
Nice set up!!!
