Tell me about your air bags!
Re: Tell me about your air bags!
Post by RustyPW » Fri May 22, 2015 6:02 pm
I've had the Carli's for a numbers of years now. Never had a problem with them. The brackets on mine are made out of steel, not aluminum. I keep 5psi in them when empty.
fbenross
Post by fbenross » Fri May 22, 2015 6:16 pm
RustyPW wrote:I've had the Carli's for a numbers of years now. Never had a problem with them. The brackets on mine are made out of steel, not aluminum. I keep 5psi in them when empty.
They look great... :poke:
Post by cruz » Fri May 22, 2015 7:54 pm
fbenross wrote: Cruz how do you level your camper when camped, if you don't adj. your air pressure ? and have the jacks off ?
My HIGH TECH solution ...
Blocks of wood and a torpedo level . Most of the time I only need to do one or two wheels and usually I can get it dead level in less than 5 minutes .
When it's time to drive somewhere and return later , I drive off the blocks and leave them there and use them as targets when I return.
Note the left front wheel and the stack behind right rear
Post by RustyPW » Fri May 22, 2015 11:45 pm
They worked good when I was pulling the camper. I only need them now when I have a heavy load in the bed.
and take your stick and rotate on it. :lol:
Post by cruz » Sat May 23, 2015 12:52 pm
Four days earlier I was in San Diego buying my new camper , I drove home and threw a few things together and went up to Yosemite for a shake down cruise .
In this picture I had 45lbs. in the airbags with hardly any gear on board , way too much air .
Now when fully loaded for a long trip I'd have 40lbs. , but for shorter trips it would be 35lbs.
snuffy
Post by snuffy » Sat May 23, 2015 3:17 pm
i like your camper. what brand and model is it? looks great!
Powerwagon Nut
Post by Powerwagon Nut » Sun May 24, 2015 12:54 am
I received the DayStar cradles yesterday and after fitting everything up I notice that the airbag stop (the metal disc) does not bottom out in the taper of the cradle. It is making me nervous...should the base of the airbag rest on the bottom of the DayStar cradle? Or does it matter if it is caught in the taper?
I'm guessing this is just warrantee legalese. http://blog.truckspring.com/post/2014/0 ... r-bag-kits
Cactus Red
Post by Cactus Red » Sun May 24, 2015 10:31 am
Here's how they look inflated:
Powerwagon Nut
Post by Powerwagon Nut » Sun May 24, 2015 2:00 pm
The metal base of my airbag is 6.5" wide, so it doesn't sit all the way in the bottom of the cradle. The edges of the metal disc sit on the taper of the cradle...it am a little concerned given the force involved that the force will all be on edge of the metal disc, and that will be transferred to the taper of the cradle. The force should be evenly distributed on the metal disc to the bottom of the cradle. Im not sure if I need to add a spacer in the cradle. It seems like the empirical evidence from your build shows it will be fine and I'm just being nervous Nancy.
azracer
Post by azracer » Sun May 24, 2015 3:29 pm
Stop worrying you will not have any issues!
I have had mine quite some time and zero issues.
phpBB [video]
Clickable link for Tapatalk
Powerwagon Nut
Post by Powerwagon Nut » Mon May 25, 2015 11:13 am
Roger. What's the worst that could happen? :)
Cactus Red
Post by Cactus Red » Mon May 25, 2015 6:42 pm
It could trigger a 2 megaton explosion...
The bottom of the airbag self centers in the taper; that's why it's there.
So, put the lime in the coconut and drink it all up, and call the Doctor in the morning...
Powerwagon Nut
Post by Powerwagon Nut » Tue May 26, 2015 11:32 am
I don't want a 2 megaton explosion! It seems like the cradles are designed for a smaller diameter airbag. It says useable for any 6" airbag...and the airbags I have are greater than 6" in diameter. If I was designing these things the metal end plate would bottom out in the cradle and be guided into it by the taper. But I'm not designing them, and based on what you guys have seen they work pretty well.
Install will happen in the next few days, I'll post some pictures of what I'm talking about, just have to find the time.
Thanks again for all the info.
Powerwagon Nut
Post by Powerwagon Nut » Thu May 28, 2015 10:37 pm
I installed the bags today. It took me a little longer than normal because I'm slow. ;) I put them in without lifting my truck at all, which might have been a little extra work. I have the upper bracket bolted in and the lower bracket loosely mounted.
Powerwagon Nut
Post by Powerwagon Nut » Thu May 28, 2015 10:41 pm
I compressed the airbag to get it into the cradle and through the mounting holes on top.
Powerwagon Nut
Post by Powerwagon Nut » Thu May 28, 2015 10:46 pm
Alignment was a bit off on the passengers side. I tried both positions, neither were ideal.
Powerwagon Nut
Post by Powerwagon Nut » Thu May 28, 2015 10:50 pm
Ran my airlines together to the back of the truck.
Powerwagon Nut
Post by Powerwagon Nut » Thu May 28, 2015 11:23 pm
I put the schrader valves next to the license plate lights so I wouldn't accidentally kick them.
Powerwagon Nut
Post by Powerwagon Nut » Fri May 29, 2015 12:25 am
The passenger side bag, under load ( my camper), at 52 psi right now. The silver disc is still visible on one side. It didn't pop out while I was test driving it and I did some sways and sharp turns at speed. Hopefully it will center itself eventually.
Post by cruz » Thu Jun 04, 2015 6:25 pm
snuffy wrote:i like your camper. what brand and model is it? looks great!
SunLite 690 by SunValley . They, like a lot of the smaller RV manufacturers bit the dust around 2009 -2010 .
I wanted the smallest hard-side camper that would still fit the PW and look like it belonged there .
I'm 6' tall and wanted a full queen bed and standing head room .
The build quality isn't top of the line , but it does have a lot of good equipment . At $10,700.00 brand new It was also the cheapest , though price was not the determining factor . Over the past few years I've seen them for sale used on internet RV sales sites as low as $6400.00 .
sharkey069
Post by sharkey069 » Sun Feb 21, 2016 8:53 pm
Greetings
I have a 2014 Power wagon with rear coil springs. When I use my Forest River Camper the truck sags more than 4 inches. What type/brand air lift kit should I use to level the truck ?
Also does anyone have any suggestions on anti sway equipment? I'm looking at Hensley and Proride . Has anyone had experience with either one?
azracer
Post by azracer » Mon Feb 22, 2016 3:35 am
Powerwagon Nut wrote:Alignment was a bit off on the passengers side. I tried both positions, neither were ideal.
I think your air bag needs to be mounted in the back hole (nearest the bumper). That Daystar cup needs to be parallel to the frame/air bag mount and not the springs like it looks like in the picture. I had a similar fit until I realized the cradle was not parallel to the air bag mounting surface. Dump any air in the bag and loosen the u-bolt holding the axle mount and wack it into alignment with a rubber mallet.
Post by Reloaderguy » Mon Feb 22, 2016 10:42 am
azracer wrote:I just dump all or nearly all the air (3>5psi) and the truck articulates as if it were essentially stock.
I see no need to put them in a vacuum. However the instructions clearly state to keep them at a minimum of 5psi. I assume this is so they will act more like a progressive bump stop and to maintain the shape of the bags. The 5psi may be too much for doing high speed stuff because once the bag is compressed all the way the air bag may give you some kick on rebound. For all other uses on road or off road 3>5psi is fine IMHO.
The minimum pressure is to prevent the bellows from rubbing each other.
azracer
Post by azracer » Mon Feb 22, 2016 2:18 pm
The reason I said dump all the air is to allow for him to adjust the mount and relocate the bag in the rear hole. I still maintain that 3 to 5 psi is a good idea for an unloaded truck. He needs to fix the passenger side and to do that he will need to dump all the air first.
Chiprat1
Post by Chiprat1 » Tue Feb 23, 2016 12:26 pm
05PWrockcrawler wrote:I have Firestone airbags with daystar cradles that work great.
Same here...
2006 Power Wagon
5th Wheel hitch
:winchmob:
