Superchargers
Superchargers
Hi guys can we make a list of what superchargers are available for our trucks.
Year of trucks:
2005-2008; procharger https://www.procharger.com/truck-superc ... _ram_truck
Not sure about any roots/ roots hybrid offerings. Thought Whipple was offering a few years back not sure though. Magnauson magna charger?
Year of trucks:
- 08TwinStickPW
Re: Superchargers
I don't think the procharger will work due to our winch mount.Weststsh wrote:Hi guys can we make a list of what superchargers are available for our trucks.
Year of trucks:
I have also read that drivability suffers as the supercharger kits are really intended for high performance and not as much focus on slow trail use (what our trucks are intended for).
At the end of the day you are better off (driveability wise) building the motor, like a stroker with a good matched cam.
Tunes
Tunes
Re: Superchargers
Yes this is true for a centrifugal supercharger such as the procharger, which is like a belt driven turbocharger. The roots hybrids like the magna and Whipple build boost at low rpm and would benefit the 09-13 crowd.08TwinStickPW wrote:I don't think the procharger will work due to our winch mount.Weststsh wrote:Hi guys can we make a list of what superchargers are available for our trucks.
Year of trucks:
I think more or less the stoker and centrifugal supercharger would have a comparable linear HP and torque curve.
With the procharger the heat exchanger are all mounted high in the radiator, don't think the winch would be an issue. Could be wrong though, don't think anybody with a power wagon has boosted yet.
Re: Superchargers
Edelbroke system looks promising for sure! Lots of r and d in different climates. Roots style also
Sent from somewhere your not
was very interested in this one for awhile but funds are there for it right now! Sent from somewhere your not
Re: Superchargers
Yeah edlebroke is another good option for 09-13 crowd. Yeah another thing lots of these superchargers are rated for only 0 and above. My thing boils down to having more passing power when trailering to make a quick pass, since most of the hwy in BC are single lane when heading north.
Re: Superchargers
Nitrous!!! Sry I couldn't help myself. I had to throw that in there
Re: Superchargers
Boost doesn't "run out".nts007 wrote:Nitrous!!! Sry I couldn't help myself. I had to throw that in there
Re: Superchargers
I like boost. I just don't like relying on 91 minimum
Re: Superchargers
I'm just being annoying. I know the limitations of nitrous. I've run a couple cheater systems before.Mule wrote:Boost doesn't "run out".nts007 wrote:Nitrous!!! Sry I couldn't help myself. I had to throw that in there
Re: Superchargers
I've read that forged internals are required for forced induction on the Hemi's?
2011
Re: Superchargers
I think if you keep boost down around 5-7lbs the stock internals would be okay... Just my reasoning though...
Re: Superchargers
Sweet someone install one 0.0
Re: Superchargers
If you keep them to 7 psi they'll be fine.
2006 Power Wagon. "Stockish"
Re: Superchargers
Lol I'll listen to 06 he seems to know how much they'll take lol
- R0NAN
Re: Superchargers
I've read that in general, the internals are quite robust. The weak link is the piston rings. If your gonna change them out, you may as well get better Pistons as well.
Re: Superchargers
Id imagine that's true... And you mine aswell bore it up while your there... And install a better cam... And forged rods lol etc etc
Re: Superchargers
Most of the supercharger kits keep boost to around 6psi.
Re: Superchargers
I've sure been thinking about this lately. Was going to simply throw in a cam, bigger throttle body and open the exhaust but a mild supercharger does sound nice.
Re: Superchargers
Seems easier and faster to just slap a charger on.... Especially ones that come with tuners already... Pretty simple. Hardest part is plumbing intercooler piping and water pumps etc...
"Escalators are never really broken...their just stairs for alittle while... "
Re: Superchargers
Yes, the supercharger would be an easy bolt on. I just worry about the tranny holding it.
Re: Superchargers
Ya me too... You think being the same internals as the 68re it would hold 500ft lbs no problem...... Could be wrong but I thought the newer six speeds were very robust compared to the 5's and the 4's
