Anyway, I had my 'normal' problem with the lockers & swaybar, which I reported before on another forum maybe a couple of years ago. Under nearly all conditions, the swaybar & lockers work great - but if I shut the truck off with the lockers locked & swaybar disengaged, when I start it back up there's about a 50/50 chance that the locker & swaybar lights will all be flashing and the "serv 4wd" light is lit. Normally I work around it by not turning off the truck with the lockers locked, but when it takes you 3 or 4 hours to get your truck unstuck that's a long time to let it sit and idle.
Anyway, I was just wondering if anyone has any new ideas or has experienced this problem. As far as I can tell, it doesn't seem to be an issue with any of the connectors or the lockers themselves...and as I mentioned, everything works great until the truck is shut off.
I did have one new experience this time - at one point after I'd been stuck an hour or so, I got back in the truck and started it to run the air conditioning for a while. At first I had the normal 'serv 4wd' light situation, but after it idled for about 5 minutes or so suddenly the 'serv 4wd' light went out and the locker and swaybar lights stopped flashing and went back to how they were supposed to be. If anything, that made me even more confused by what the problem could be.
On a positive note, I learned that I can jack up the whole front of my truck with my hi-lift using the crosstubes on my brushguard...but I really really really wouldn't recommend doing it unless you're desperate and willing to damage your truck to get unstuck. But, when your front bumper is underground you end up working with what you have.
