Also will they start making a super charger for it. Cuz how bad as would a power wagon be with a super charger.
I would go with a Pro Charger instead of going to a Super Charger.jseal5757 wrote:would a roots style for a 6.4 srt fit on the truck. it replaces the whole intake manifold so it should bolt right on.
A pro charger is a supercharger... For a big heavy truck for off road I would rather have the added torque of the roots blower vs the high rpm horsepower of a centrifugal blower.dale dalueg wrote:I would go with a Pro Charger instead of going to a Super Charger.jseal5757 wrote:would a roots style for a 6.4 srt fit on the truck. it replaces the whole intake manifold so it should bolt right on.
There's no boost at idle. A flapper opens under vacuum. It closes under acceleration to provide instant boostRustyPW wrote:A roots blower has boost at idle. A centrifugal blower builds boost higher up the rev range. In a nut shell, it's like a belt driven turbo charger.
How does headers & a half exhaust system boost 30lbf torque & 25HP? Is it just more free flowing & less restrictive , what's the secret sauce here to get 6% increase?Limamikemike wrote:http://www.moes-performance.com/ARH_Lon ... wc-6.4.htm
Long tube headers for 2014+ 6.4. They're hella spendy though
AZ, wow thanks for sharing, I genuinely learned something tonight from reading that, and I'm glad I did, won't be purchasing that header kit now for sure.azracer wrote:I have never been impressed with headers unless it is coupled with an aggressive cam meant for high RPM only use (IE: severe engine lope at idle). In nearly every case where I added headers to a basically stock engine with good cat back exhaust I could not tell much if any improvement with headers added. In a couple cases on the smaller displacement engines I did notice a quite a bit less grunt in the lower RPMs
The Y-pipe on our 3G trucks is a major choke point. When I saw mine after we cut it out I was really surprised at the poor quality and restrictive design. I would bet at the higher RPMs it cut flow by up to 25 to 30%. At first my new Y-pipe back exhaust only sounded good and I was unimpressed while driving home from the exhaust shop in heavy traffic. Where I really noticed the improvement was the 3500 RPM and up range. but that was days later that I discovered that. I found that over the same distance and same location, I could now achieve 100 plus MPH where I was lucky to hit 85 MPH before. My exhaust was the last performance addition I did. I believe the Exhaust had the biggest improvement in higher RPM performance because combined with the other two performance parts it really woke things up. It really warmed up the Diablo tune and AirAid CAI I had already installed. I'm very happy with what the final results are. Is it a race car... No it just runs much better is all. The tuner really helped with the throttle response and eliminated the torque management issues. The exhaust really helped to wake up the engine in the upper RPM range and I believe the AirAid CAI just complimented everything and most of all it cleared my Thuren shock towers where the OEM air box didn't LOL.
Yes I believe the OEM Y-pipe and muffler system is very restrictive and hinders power development in the upper RPM ranges on our trucks (3500 RPM and up). Would I do headers? No! I would just do from the Y-pipe back. IMHO headers only enhance other modifications meant to develop power at maximum RPM. They do nothing under 4000 RPM and can hinder power a bit at the low RPM where a little back pressure is needed. It is sort of like a short runner or long runner intake where do you want your performance gains, off idle or at red line?
IMHO headers are a waste of money and increase the risk of header related exhaust leaks. They also increase under hood temperatures quite a bit. If you run at 5000 RPM all the time and need the extra 10 or 15 HP at maximum RPM... then go for it. Just realize the lower RPM range may suffer some and you may loose a bit of the low end grunt our truck have.
They don't really make one for our 5.7 in a 3G. It is a generic Y-pipe based on the inlet and outlet size of the OEM exhaust. The 5.7 has a 2.5" outlet to the Y-pipe inlet. The OEM single exhaust is like 2 7/8" from the OEM Y-pipe back. So the Magnaflow 10778 Y-pipe is the closest fit with 2.5" inlet and 3" outlet. I had all of my exhaust after the Y-pipe fabricated in 3" to the tail pipe and this is why I selected the Flowmaster 9530560 50 H.D. Muffler - 3.00 Offset IN / 3.00 Center OUT. They make a y-pipe in a 3" in and 3" out as well as a 4" out. Just get the PN# from their site and plug it into Amazon for a price comparison. https://www.magnaflow.com/automotive-pe ... /products/adeluca73 wrote:Has anyone found a genuine y-pipe upgrade for the 6.4 motors like there is for the 5.7 motors? I've looked on mufflex, magnaflow, & flow master and haven't seen one offered.
The car lost no drivability and power under the entire rpm curve improved. The gains were everywhere not just at high rpm points but most were above 3000rpm where a hemi towing a load would certainly live. The issue often is the header design mostly influenced by what dimensions are required to fit, work with existing exhaust systems, etc, which may result in some of this hi rpm power only you speak of. There is science to the length and cross section of each primary and how it returns a negative pressure wave to the exhaust valve which can improve engine power especially if overlap is present in the valve timing which I would presume is most certainly not the case in an oem truck 6.4 camshaft. Programs like pipemax illustrate this via playing with exhaust design parameters. If you really want to understand in detail what I only understand on the surface hop over to speedtalk.com and search. You will read for hours. I would say that the effort required to design a beneficial long tube header for these trucks is probably not worth the time and cost especially considering the heat issues you pointed out.azracer wrote:adeluca73 wrote:The above comment about long tube headers and trap speeds is somewhat correct and is exactly what I was saying. Dual exhaust with long tube headers is for maximum RPM HP. Most good exhaust shops for street use and drivability use a Crossover X or H pipe to try to retain some of the low RPM grunt and drivability, though much of it is lost anyway. I don't see the point in headers or dual exhaust unless you really need maximum HP at maximum RPM and are willing to sacrifice some of the drivability in the form of low end HP and torque loss. Single exhaust properly sized to the motor has always proven to give the broadest performance gains while yes, sacrificing some of the maximum redline performance gains.
