Need new shocks opions?
008wagon
Post by 008wagon » Thu Oct 16, 2014 8:05 pm
Got a stock 2008 quad cab power wagon it has 53000 miles on it noticed that one of the shocks is leaking any opions on what to buy and where . I tow a boat a lot and go off-road some also if that matters
Re: Need new shocks opions?
Post by nts007 » Thu Oct 16, 2014 10:17 pm
I love my bilstein 7100s. They are a big step up from the 5100 series and arnt as pricy as going up to kings. But there are a lot of options. Search the carli shock packages up at 8lugtruckgear.com also there are stock and slightly improved shocks but then they will be no better than the stock if not worse. Hoping some of the fellows who have run the majority of the upper range ones will chime in
Ducky's Dad
Post by Ducky's Dad » Thu Oct 16, 2014 10:44 pm
FWIW, when I bought a used Tundra recently, it needed new shocks. I wanted Bilstein 5100s but could not get them quickly so we put on a set of ProComps. I have never been a fan of ProComp, and I'm still not. The half-ton Tundra with IFS and ProComps and 33s rides worse than the PW on stock suspension with 35s. Comfort considerations aside, the Tundra exhibits a lot more bump steer than it did on its original shocks, and more than any other truck I have owned. I can only attribute that to the jounce control in the ProComps. Both Tundra and PW are rolling Toyo AT-IIs.
When the PW needs shocks, they will probably be Bilstein 7100s. Seems like the best bang for the buck on that truck, and worth holding out for.
Cactus Red
Post by Cactus Red » Thu Oct 16, 2014 11:36 pm
The 5100's are a good solid shock, substantially better than the stockers. 7100's are better yet, but double the cost. Fox IPF is in between those two, and are rebuildable. So, it's really up to your budget - with shocks, $$$ really does make a difference.
Sent via Carrier Pigeon
Post by adeluca73 » Fri Oct 17, 2014 1:18 am
I know this has to be asked 1000 times but...what's the difference between stock Bilstein and 5100? What's the jump in spec to 7100's?
Post by FirerescuePW » Fri Oct 17, 2014 6:28 am
See Coder's comparison here:
http://forum.powerwagonregistry.org/viewtopic.php?t=
Juday
Post by Juday » Fri Oct 17, 2014 8:25 am
I think when the time comes (and it's going to be soon since two of the stock shocks are blown and leaking oil), I'll be going with the Thuren Fox 2.0 shocks. I'm not looking for the desert racing shock tuning as found on Carli's shocks. I just want something to give me a smooooooth ride and stop the crab walking on the highway's potholes that are unavoidable. Hopefully the Fox 2.0 shocks will solve that problem?
2012 RAM Power Wagon
hodge-xj
Post by hodge-xj » Fri Oct 17, 2014 10:24 am
Fox 2.0 IFP non resis or 5100s. 8 lug truck gear carries them both in package deals and the foxs are a tad more expensive then the 5100s. When I get the coin ill be swapping my 5100s for them and ill do a comparison. Either way is a step up from OEM. I think the 5100s are a little harsh but I like a softer suspension feel which from what I hear the Fox's are softer. I like the fact that the foxs are rebuildable and valveable. Granted they aren't a super tunable desert shock like the kings, but if you really dont like the valving or you blow a seal you can have them fixed to your liking. To me thats worth the extra cost over the sealed bilstein units. Give George at 8 lug a call. He's awesome to deal with
Juday
Post by Juday » Fri Oct 17, 2014 1:01 pm
You know that ride feeling with about 200 pounds in the rear of the bed? That's how I want my truck to ride ALL THE TIME!
hodge-xj
Post by hodge-xj » Fri Oct 17, 2014 1:21 pm
So keep 200 pounds back there all the time :) honestly aside from maybe playing with tire pressure a bit the unloaded ride of these is darn nice. I swapped from stock 2500 diesel leafs to pw leafs and it was a huge improvement. When I think my truck rides like shit I just take a spin in my unloaded 50k gvwr work truck and it makes me appreciate the dodge all over again lol.
Post by coder » Fri Oct 17, 2014 6:57 pm
FirerescuePW wrote:See Coder's comparison here:
Link did not work try this one: http://forum.powerwagonregistry.org/vie ... =112#p1724
Post by coder » Fri Oct 17, 2014 6:59 pm
adeluca73 wrote:I know this has to be asked 1000 times but...what's the difference between stock Bilstein and 5100? What's the jump in spec to 7100's?
Same basic shock w/different finish and stiffer but somewhat more generic valving.
Post by RustyPW » Fri Oct 17, 2014 10:52 pm
I've had my 7100's for about 3 yrs now. Love them. :mrgreen:
Post by adeluca73 » Sat Oct 18, 2014 12:34 am
Awesome feedback guys, thanks. Do the 7100's have external resvoirs you have to drill & mount to the frame? And is there specific PW valve rates in the 5100's like Bilstein does for the stocks?
stamm20
Post by stamm20 » Sat Oct 18, 2014 12:35 pm
I went with the fox 2.0 performance shocks they were about middle of the road on price. I havent wheeled with em yet but they ride good on the road. I got em from polyperformance.com
stamm20
Post by stamm20 » Sat Oct 18, 2014 12:37 pm
adeluca73 wrote:Awesome feedback guys, thanks. Do the 7100's have external resvoirs you have to drill & mount to the frame? And is there specific PW valve rates in the 5100's like Bilstein does for the stocks?
They sell adapters for the reservoir that mounts off the outside bolt on your shock tower then just two hose clamps
Cactus Red
Post by Cactus Red » Sat Oct 18, 2014 1:51 pm
The 5100's I used (PN's are in my build thread) are stiffer than stock. That helped to reduce the sloshing with the swaybar disconnected. They also improved handling over washboard roads. I will be upgrading shocks in the next few months - the 5100's now have close to 60000 miles of hard use on them. At this point I'm considering Fox remote res shocks after using the non res 2.0 IPF's on our JKUR. The Jeep handles the rough stuff better than it did with the AEV tuned 5100's, and they were pretty good to start with.
Post by 2wagons1driveway » Tue Oct 28, 2014 9:00 pm
Should probably just put Carli dominator 3.0's on it. Lol
Sent from somewhere your not
Skyd Ram
Post by Skyd Ram » Thu Oct 30, 2014 2:27 pm
The 7100's that most guys are talking about is actually the Carli Performance 2.0 shock package with Hemi valving. It works on the 03-12 trucks only though.
Post by Will » Thu Oct 30, 2014 3:21 pm
I have the Rancho's Power Wagon specific 9000's and like them. I did all 4 and the steering for less than $400 last year.
Adjustable and have a 90 free ride to try them out.
RS999044 0" Front Power Wagon
RS999058 0" Rear Power Wagon
http://www.gorancho.com/shock_lookup.ph ... D&x=46&y=9
008wagon
Post by 008wagon » Thu Oct 30, 2014 3:51 pm
I went back with the stock ones . Found a set that were eight years old but only had 250 miles on them . Guy bought the power wagon the. Lifted it and took the stocks off and put in storage . 150 dollars for new shocks can't beat that
Post by Will » Thu Oct 30, 2014 4:19 pm
Nice
2011RPW
Post by 2011RPW » Fri Oct 31, 2014 10:49 pm
I'm running Thuren Overlands. Very pleased with them.
2011
