Clunking universal?
AceMan
Site Admin
Site Admin
Clunking universal?
Post by AceMan » Fri Jul 06, 2012 7:29 pm
When in 4wd, I'll put in D, and no problem, then shift to N, and I hear a weird clunk, the to R, it's quiet, then I N then to D, no problem, but from D to N, nasty clunk. It does not happen in 2wd.
My dealer tech friend crawled under and couldn't identify the source and said he needs it in the air to get a better perspective. I was there for a short period just stopping by, since he's leaving the dealer to go to another. I'm bringing it on Tue to get it looked at by one of the other guys, I know there, along with possible front calipers (grabs left occasionally), and rear driver side door power lock not working.
Any thoughts on the clunking?
Power Wagon Owner's Club #110
Black '06 PW QC
Image Image Image
Cactus Red
Re: Clunking universal?
Post by Cactus Red » Fri Jul 06, 2012 8:44 pm
Sure sounds like it could be the front CV, but it could be a case of low blinker fluid too...
AceMan
Site Admin
Site Admin
Post by AceMan » Fri Jul 06, 2012 8:52 pm
Front CV? Ok, thanks! :rockon:
Low blinker fluid. I had that checked by the guy behind the counter at the local 7-Eleven. He said it was fine. :secret:
Black '06 PW QC
Image Image Image
Throttle 8
Post by Throttle 8 » Fri Jul 06, 2012 9:00 pm
AceMan wrote:When in 4wd, I'll put in D, and no problem, then shift to N, and I hear a weird clunk, the to R, it's quiet, then I N then to D, no problem, but from D to N, nasty clunk. It does not happen in 2wd.
I had this exact same thing happen six months ago. I am 90% certain that it is a broken wire in the harness at the back door. They did not leave enough slack in the harness, and the wires wear then break. I am told this is a very common occurance. A complete loom is $160., or you can peel back the loom and splice in a new piece and shrink wrap it.
AceMan
Site Admin
Site Admin
Post by AceMan » Fri Jul 06, 2012 11:34 pm
Throttle 8 wrote:
AceMan wrote:... , and rear driver side door power lock not working. ...
I had this exact same thing happen six months ago. I am 90% certain that it is a broken wire in the harness at the back door. They did not leave enough slack in the harness, and the wires wear then break. I am told this is a very common occurrence. A complete loom is $160., or you can peel back the loom and splice in a new piece and shrink wrap it.
Thanks! Is that right where the loom enters the door, or anywhere in the loom inside the door?
Black '06 PW QC
Image Image Image
Post by TwinStick » Fri Jul 06, 2012 11:41 pm
My d-side rear door power lock quit working YEARS ago. I have not fixed it yet. This is great info, thanks guys. I just went & robbed HF a few days ago. I got all the wiring stuff i need to do this job. Coincidence ? I think not .
AceMan
Site Admin
Site Admin
Post by AceMan » Sat Jul 07, 2012 12:02 am
TwinStick wrote:My d-side rear door power lock quit working YEARS ago. I have not fixed it yet. This is great info, thanks guys. I just went & robbed HF a few days ago. I got all the wiring stuff i need to do this job. Coincidence ? I think not .
Coincidence! Yes! LOL!
Posted by Nexus via Tapatalk. Please excuse any misspelling.
Black '06 PW QC
Image Image Image
pdavey
Post by pdavey » Sat Jul 07, 2012 10:34 am
I agree with Throttle 8. Had the same thing happen to me, just replaced a segment of the wire with something slightly longer soldered it and shrink wrapped it, no more issues. 20 minute job.
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Throttle 8
Post by Throttle 8 » Sat Jul 07, 2012 11:09 am
Exactly! It will be somewhere close to the pivot point. If they had made the wires 3 inches longer, there would be no issue!
VA_Wagon Man
Post by VA_Wagon Man » Sat Jul 07, 2012 11:12 am
Where is the wire breaking, in the part that is visible between the door and the b-pillar? Because mine doesn't work either, and neither do my rear door speakers......:sad:
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
Post by cruz » Sat Jul 07, 2012 11:42 am
Probably nothing more than the torque in the driveline unloading, unless it's real harsh I wouldn't worry.
pdavey
Post by pdavey » Sat Jul 07, 2012 11:57 am
VA_Wagon Man wrote:Where is the wire breaking, in the part that is visible between the door and the b-pillar? Because mine doesn't work either, and neither do my rear door speakers......:sad:
Yes it is in the carrier between the door and the b-piller. Just pull back the rubber and you will see where they are broken. I had the same issue with my speaker wire. Ultimately what happened was two of my wires had split. As throttle said they just chinced on materials. An inch or so more and you wouldn't have any issues.
Performance Mods:
Other Mods:
Style/Other Mods:
Throttle 8
Post by Throttle 8 » Sat Jul 07, 2012 1:22 pm
What he said!!!! :cheers:
AceMan
Site Admin
Site Admin
Post by AceMan » Sat Jul 07, 2012 2:01 pm
It is harsh. I don't like it.
And since it's still under warranty, I'll let them deal with the harness or power lock actuator. At this time base on everyone's feedback, I too, think it's probably the harness. It's too hot out there right now to work on it anyway.
Black '06 PW QC
Image Image Image
VA_Wagon Man
Post by VA_Wagon Man » Sat Jul 07, 2012 3:15 pm
I just fixed BOTH rear speakers, power door lock and power window! As the turtles would say, COWABUNGA DUDE!!! :D
Thanks!!
Long Gone:
AceMan
Site Admin
Site Admin
Post by AceMan » Sat Jul 07, 2012 3:53 pm
How long did it take?
Black '06 PW QC
Image Image Image
VA_Wagon Man
Post by VA_Wagon Man » Sat Jul 07, 2012 5:20 pm
Too long in this heat. I guess it was around an hour.... I didn't really time it.
Long Gone:
pdavey
Post by pdavey » Sat Jul 07, 2012 7:40 pm
Just did a write-up on the repair. As VA_Wagon_Man said about 30 minutes to an hour depending on the damage.
http://forum.powerwagonregistry.org/vie ... ?f=2&t=228
Performance Mods:
Other Mods:
Style/Other Mods:
AceMan
Site Admin
Site Admin
Post by AceMan » Sat Jul 07, 2012 9:24 pm
Thanks, Pete. Great write-up!!
Black '06 PW QC
Image Image Image
Post by TwinStick » Sat Jul 07, 2012 9:47 pm
This is a must do then. My rear speaker quit at the same time as the lock. Thanks guys. :rockon:
AceMan
Site Admin
Site Admin
Post by AceMan » Thu Jul 12, 2012 9:34 pm
Clunk update: Torque unloading. Power lock: spliced wire. So everyone was right!
Black '06 PW QC
Image Image Image
ABFargo
Post by ABFargo » Sun Jul 15, 2012 5:00 pm
Cactus Red wrote:Sure sounds like it could be the front CV, but it could be a case of low blinker fluid too...
We get 30-50,000 miles out of early front CV joints. If your truck is in this range, most likely cause.
Last time I checked here, OEM shaft was $750, with shaft from aftermarket around $375.
If on warranty, let Dodge pay, otherwise go for aftermarket (driveline repair shop).
AceMan
Site Admin
Site Admin
Post by AceMan » Sun Jul 15, 2012 10:42 pm
You mean the axle joints?
Sent from my Galaxy Nexus using Xparent ICS Tapatalk 2
Black '06 PW QC
Image Image Image
ABFargo
Post by ABFargo » Wed Jul 18, 2012 2:18 am
Nope, front driveshaft.
Early d-shafts had no grease zerk.
Gen 4 front d-shafts have a needle zerk, allowing the centering ball in the CV to be greased, prolonging life.
Re: front axle u-joints, normally get 50-70,000 out of them as well.
Good front axle shaft upgrade is RCV replacement axle shafts. (minor thread jack)
Post by FirerescuePW » Wed Jul 18, 2012 1:42 pm
ABFargo wrote:Nope, front driveshaft.
If you are talking about a grease zerk on the double cardan joint, PWs have always had them. I have an '05, and there is even a warning decal on the rad support directing mechanics to find it and grease it.
Sent from an undisclosed location.
