any advice
w2dodge
any advice
Post by w2dodge » Fri Jun 29, 2012 1:10 pm
Memorial Day wknd i had the pw on a turkey hunt...tried to engage the lockers front and back....my truck when driven approx 40 miles + the serv 4wd and rr lights start...and when the truck is off for a few hours the lights go off..i changed front and rear diff fluids, cleaned the mgnts etc,i posted it on d/t..and the lockers engaged after the fluid change...from that Memorial wknd the lights stayed on,so i took it to the dealer..when i got home...sway bar , rear actuator...they say..for 5 weeks had nothing done at the dealer no parts or even tools...bunch of bs..i picked the truck up this morning headed to another deal which i explained everything previous day.....started the pw no lights.. nothing went on for the whole trip..pulled in the lot went on some dirt and everything worked and went on fine ..fast...spoke to the service rep what i did on the lot..i took the pw home...sway bar connection looks good...WTF ...can some one tell me what to look for ...or do..thanks
Re: any advice
Post by TwinStick » Fri Jun 29, 2012 1:28 pm
Usually when it is an intermittent problem, there is corrosion, bad ground or a wire rubbed bare somewhere. But not always. Are you SURE you didn't dislodge the magnets when you cleaned them ? Or maybe a sensor, like the one on the transfer case, goes bad. :cheers:
w2dodge
Re: any advice
Post by w2dodge » Fri Jun 29, 2012 3:25 pm
thanks twin....i left the diff covers off and watch them engage when i did the fluid change,all the connections i checked several times..i used dielectric around the sway bar and other connections...maybe il use one of your blades and chop and cut everything up...losing my patients...
Re: any advice
Post by TwinStick » Sun Jul 01, 2012 5:00 pm
:doh: While it was apart, you didn't touch the connections with anything that conducts electricity did you ? :jawdrop: Gunnipwguy did that & it fried the actuators. Then he was seen doing this ! :angry: :cash:
:secret: Don't use anything that conducts electricity near your locker when diff cover is off. :secret: It may be wise to disconnect the battery before servicing the diffs. Gunni says so. :cheers:
w2dodge
Re: any advice
Post by w2dodge » Mon Jul 02, 2012 4:42 am
I use q-tip around electronics,used prep all in the case.after the cleaning I made sure they engaged,well when the lights go back on straight to the dealer...hes waiting for the tool for the actuator..
Hilldweller
Re: any advice
Post by Hilldweller » Tue Jul 03, 2012 12:00 pm
How are all the connections and grounds to the TIPM?
The problems that I had recently were all traced to a loose connection in there.
It's voodoo in there, btw.
Safety fast,
Bill
w2dodge
Re: any advice
Post by w2dodge » Tue Jul 03, 2012 2:42 pm
[quote="Hilldweller"]How are all the connections and grounds to the TIPM?
It's voodoo in there, btw.[/quote
TIPM ? I checked , well I think all of the connections under the truck,been driving everyday so far with out any rr or 4wdserv lights ...
